 Stick on Velcro
pearson39b
Initially Posted - 02/26/2015 :  11:38:27  Show Profile
OK, so this isn't really a C-25 question, but I've been so impressed by the varied boating expertise expressed here, I thought it worth a gamble someone may be able to help me with a decision about using self adhesive velcro/
My other boat is a trawler (yeah, a power boat) and the rear of my bridgedeck cover is anchored on the paiinted aluminum arch with 2" velcro and common sense fasteners. The Velcro's holding in shear, so it's pretty solid. I've got the sunbrella off for cleaning, patching and treatment, and now it's time to replace the old stick-on hook, which had been holding very well in some spots, no so well in others.
My question is, should I supplement the stick-on adhesive with more adhesive, like silicone, or might that interfere with the existing adheshive?
Yeah, I know this is a long shot, but what the hey...
Sailor Jerry
C-25 "Sea Song"
1978, SK, Std.
Pepin, WI
Response Posted - 02/26/2015 :  12:10:14  Show Profile
There are two kinds of adhesive-backed velcro available. Standard, and industrial strength. You can learn more about it by googling "Industrial strength velcro." As I recall, industrial strength velcro is sold by Walmart. I'd suggest you try it first. If it doesn't hold, I suppose you could try to adhere it with some other kind of glue. It doesn't adhere forever, but if you have to replace it after a couple of years, that probably wouldn't be too much hassle. I made some sunbrella grab rail covers that were held on by velcro, and they stayed on through a hurricane, so the stuff generally works well.
Response Posted - 02/26/2015 :  18:54:30  Show Profile
I agree with Steve. Just be sure to give it 24 hours at room temp before stressing it, that includes bending and folding. Keeping pressure on it for that time would be helpful, bonding to fabric is always problematic.
Dave B. aboard Pearl
1982 TR/SK/Trad. #3399
Lake Erie/Florida Panhandle
pearson39b
Response Posted - 02/27/2015 :  09:04:51  Show Profile
Goggled the velcro and verified that I do have the industrial strength variety, Steve. So I've applied it without supplemental adhesive, because l also got a recommendation from Home Depot to use a heat gun to make it stick better. We'll see if it holds up.
Thanks for the help.....
Sailor Jerry
C-25 "Sea Song"
1978, SK, Std.
Pepin, WI
Response Posted - 02/27/2015 :  09:35:27  Show Profile
The heat gun sounds like a good idea. Thanks for passing it along!
Response Posted - 02/27/2015 :  14:07:54  Show Profile  Visit britinusa's Homepage
From experience, I have found that it's best to make the fixed area of velcro larger than that on the removable part.
eg. On our Bug Screen under the bow hatch, I have 1/2" velcro hook tape sewn onto the insect screen. I have Self adheasive 1" eye tape on the underside surround of the hatch. The concept was that the wider tape would adhere better to the fiberglass liner.
As far as keeping pressure on the tape adhered to a tube, I have used webbing wrapped around the tube and velcro.
Joint Decision. (Sold)
PO C250WB 2005 Sail # 841.
Moved up to C34 Eximius
Updated August 2015
