 9.9 Mercury repair bill! @#$#@
theshepirate
Initially Posted - 05/15/2015 :  11:20:46  Show Profile
We have 2001 9.9 mercury long shaft on our 25' Catalina. We bought it with the boat five years ago. Toward the end of last season, it started missing after running for 30 minutes. We treated the fuel, a little better for a small amount of time.
When we put the boat up on the hard in the marina, we requested that they service the motor and fix the sputtering problem and change the impellar as it has been about 3 yrears since we put in a new one.
Alos change the spark plugs, we supplied the new ones, as we bought them as we originally planned to do it ourselves.
When the bill came in, this is what it said:
Water kit/impellar=98.00
tighten and clean carberator, don't know if they removed it or just sprayed,
change spark plugs with ones provided,
Labor 3 3/4 hours Total= 427.00
Does this sound fair or inflated?
TheShePirate
Response Posted - 05/15/2015 :  11:29:48  Show Profile  Visit britinusa's Homepage
$87 an hour.
Pretty cheap for a mechanic.
Do mechanics provide a review before they do the work similar in process to a car mechanic?
Joint Decision. (Sold)
PO C250WB 2005 Sail # 841.
Moved up to C34 Eximius
Updated August 2015
Response Posted - 05/15/2015 :  12:51:21  Show Profile
The marina at Canyon Lake's labor charge is $95 an hour. I had the 4hp 4-stroke serviced and it cost $271.
Chief Measurer C25-250 2008
San Antonio, Texas
theshepirate
Response Posted - 05/15/2015 :  13:16:10  Show Profile
Thanks guys,Guess its about the same labor wise all over.
No they did not give me the estimate, i guess because I told them to fix it in the first place. Should I ask him if he changed the fuel filter?
TheShePirate
panhead1948
Response Posted - 05/15/2015 :  17:00:54  Show Profile
I just had my 7.5 Honda serviced. New impeller, new water pump housing, new plugs, change oil. change lower unit oil, and clean and adjust carb 427.00.
RAG Sailor
Response Posted - 05/15/2015 :  21:30:40  Show Profile
Originally posted by britinusa
$87 an hour.
Wow. You were ripped a new one. I just brought mine in on Saturday. Last years service was $125. I expected this year to be the same. Got a call Wednesday and was told an impeller should be dowe every 2 years. I braced my self thinking it a big job. She said your size engine...$25. This is an authorized Merc dealer, too!
Good to be back at sea!
Tomas Kruska
Czech Republic
Response Posted - 05/16/2015 :  05:00:47  Show Profile  Visit Tomas Kruska's Homepage
Holy cow, $87 an hour is cheap??
The average "marine" motor service starts here from $40.
I think I'm gonna move to US and start servicing outboards
Dalpol Phobos 21, 2013, Sole Mio, hull #27, current adventures - We sail Phobos 21
PO of Catalina C25, 1978, High Anxiety, hull #701, SR, FK, L-dinette, inboard diesel Volvo Penta MD2010C w/saildrive - more info
Kper
Response Posted - 05/16/2015 :  05:41:53  Show Profile
I had the exact same work done to our 9.9 Seahorse about 4 weeks ago. The marina ran it through their account with the repair shop and with the discount it was still $340 so $427 sounds about right for our area.
Kyle
'86 SR/SK/Dinette #5284 "Anodyne"
In the barn where we found her...
Response Posted - 05/17/2015 :  06:12:48  Show Profile
Exactly because of those costs I've always encouraged working on your engine yourself, however now with the newly designed engines I'm not sure this is still a good option.. I bought a manual with my new Evinrude ( teeHatSue ) and the beginning of each chapter shows special tools needed ...
A friend of mine recommended I purchase an additional carb.. TO switch out.. with costs like that it sounds like and option..
ANyhoo.. trying to get my head around maintenance on this new engine and it sounds like change the oil, plugs, clean the carb, change water pump impeller, ( test thermostat ?? )
or pay a mechanic $450 every other year.
Hmmmmm.....
Personally I think the rippoff is the mechanic saying they will do the "diagnostics" and let you know what the costs will be, when often it sounds like it is simply a clogged carb jet...
At least that's what I keep hearing. But, lets not degrade the value of a good mechanic.
In the mean time ... I'd look for another mechanic.. I know I've spent a LOT of time researching mine. And different ones for different jobs.
Anybody need the original weed eating prop??
Edited by - redeye on 05/17/2015 06:57:55
Response Posted - 05/17/2015 :  07:25:37  Show Profile
Originally posted by RAG Sailor
...Got a call Wednesday and was told an impeller should be dowe every 2 years. I braced my self thinking it a big job. She said your size engine...$25. This is an authorized Merc dealer, too!
For $25 including labor, I'd have someone do it every year. However, the vast majority of mechanics will charge much much more for an impeller job.
In general, I want to caution all of you about taking mechanics' recommendations for frequency of impeller jobs, spark plugs, etc. They are used to dealing with powerboats that run their engines full time, so they may recommend replacing certain items more frequently than needed. Sailboats put much fewer hours on their motors, so impellers will last a lot longer. Eventually they'll get hard and crack, but my mechanic tells me you can get a lot more than 2 years out of one with the light use of a sailboat auxiliary motor. He also said spark plugs last 5 years or more - the stuff about replacing them every year is just marketing fluffery.
YMMV.
Edited by - TakeFive on 05/17/2015 15:47:16
Response Posted - 05/17/2015 :  07:33:59  Show Profile
My 5 hp carb is just $55 so having one to swap out because of jet fouling in 4 stroke engines sounds like a reasonable thing to do. Had I not gone electric I would have ordered one for this season.
Response Posted - 05/17/2015 :  15:33:53  Show Profile
Hmmm...$25 sounds like the price for the impeller kit, Not the labor.
Response Posted - 05/18/2015 :  18:58:01  Show Profile
$25 for the part sounds about right. Labor in Ohio when I had work done a couple of years ago was $90/hour. In Florida that same year for another job that I chose to farm out it was $115. Basic servicing of plugs, both oils, impeller, and installation of a good fuel/water separator/filter is an easy home job. I run a tank full with carb cleaner mixed in and spray the carb once a year. "Mechanic in a can" might or might not do anything, but it doesn't hurt on an annual basis.
Dave B. aboard Pearl
1982 TR/SK/Trad. #3399
Lake Erie/Florida Panhandle
RAG Sailor
Response Posted - 05/19/2015 :  09:54:21  Show Profile
No, that's how much more they said it would cost me above the original engine service (oil change, lube, etc. - no spark plug needed yet). again, this is rural Tennessee, not Port Washington, LI (where I used to keep my boat (35 years ago). These are the salt of the earth people and really know their business...it just costs less to live here, a lot less!
Response Posted - 05/19/2015 :  12:49:32  Show Profile  Visit shnool's Homepage
Ok, so I did my own impeller job, found the parts online for $28 (Ebay baby)... took me about an hour to properly remove the lower unit (cause I hadn't even done it on this motor)... I have a 7.5hp long shaft 2 stroke Evinrude circa 1983.
Then it took me at least another hour to figure out how to get everything aligned perfectly to get the unit all back together. So my layman work (non experienced) took 2 hours. YOU tell me what a good mechanic that has done this a thousand times would take to do the job... keep in mind 1 hour minimum is usually charged.
I know pictures or it didn't happen... Note the impeller missing a tooth (by the way others were cracked)... the water stream from the motor was still good though (just proves you can't tell by that).
C&C 32 Smith Mountain Lake Virginia
Edited by - shnool on 05/19/2015 12:53:23
Tomas Kruska
Czech Republic
Response Posted - 05/20/2015 :  03:34:48  Show Profile  Visit Tomas Kruska's Homepage
Great, now you are skilled to do it even for your friends :-)
Response Posted - 05/20/2015 :  09:07:33  Show Profile  Visit shnool's Homepage
I got lucky... my outboard doesn't require unlocking the gearshift lever, it just presses in. Although I'd say aligning the water tube, gear shift, and bolts together was a REAL bear. What I was MOST worried about was the gearshift didn't want to align correctly and I read where you had to be in THIS gear, or NEUTRAL, or REV, to align the spline. Turns out you had to be in neutral, and moreover, you had to align the bolts, and press the gearshift back in by slowly and evenly tightening the bolts. I was worried that was too much pressure, but apparently necessary to get it all to fit. I also can't figure out why the bolts have to be so far recessed... no socket or box wrench fits it, you can only use an open end box on it, you know, a thousand 1/8th turns, on 2 bolts.
The one I gotta bone up on is pulling the carb and cleaning it. But I'm here to tell you if I can change the water pump, ANYONE can.
Edited by - shnool on 05/20/2015 09:08:45
RAG Sailor
Response Posted - 05/23/2015 :  19:39:48  Show Profile
Okay, picked up my 2009 9.9. Here are the costs: $150 oil change and lube all fittings; $21 new impeller; $125 installation fee for impeller. That's the total cost.
Response Posted - 05/24/2015 :  07:54:59  Show Profile
You got hosed in my opinion. $150 to change the oil? I can get an oil change in my truck with 7 quarts of Mobil 1 for $85.00 and they check all the other fluids and air up my tires!
You might have 1 quart of oil in your engine and it's not Mobil 1 and it takes maybe 1 minute to lube all the fittings.
The water pump is probably about right.
Association Member
Andiamo
'89 SR/WK #5862
Kemah,TX
Response Posted - 05/24/2015 :  14:17:39  Show Profile
Hmmm, I thought you said $25 all-in cost for the impeller. So much for salt of the earth. Sounds like you were really ripped a new one.
I'd be looking for a new dealer if I were you. To be initially told $25 all-in, then they charge you $146 is unacceptable. And $150 for an oil change is totally absurd.
Response Posted - 05/24/2015 :  14:28:55  Show Profile
I won't say any more..
Response Posted - 05/24/2015 :  15:31:33  Show Profile
[quote]Originally posted by britinusa
Me thinks you mis-heard or she mis-read...
