 New instruments - old holes
Initially Posted - 05/30/2015 :  17:25:47  Show Profile
Removed old instruments in preparation for installing new . . . and the old holes are a considerably larger than the new instruments (even slightly larger than the new faceplates)
So I basically need to fill in the old holes and re-drill smaller ones. The bulkhead is roughly 3/4" thick.
I plan to plug the holes with layers of fiberglass and top off with gel coat.
Anyone have other suggestions, experience?
1989 C25 TR/WK, #5822
1973 McVay Minuet 19
1975 Jester 12
1981 C25 SR/SK, #2428
1981 C22 SR/SK,
Tanzer 16
Sunfish
Edited by - OJ on 05/30/2015 17:31:17
Response Posted - 05/30/2015 :  17:54:38  Show Profile
You could cover all the old holes with a piece of starboard, and then attach the new instruments to the starboard.
Response Posted - 05/31/2015 :  11:45:16  Show Profile
I agree with Steve, Much simpler and is what most would do. Unless your an expert with fiberglass and matching colors the fiberglass repair would probably be very noticeable and in an area that is frequently viewed.
Response Posted - 05/31/2015 :  12:02:03  Show Profile
Originally posted by Steve Milby
You could cover all the old holes with a piece of starboard...
...or teak. I, too, would not try to fill and then re-cut. (I'd probably use Starboard.)
Response Posted - 05/31/2015 :  14:03:08  Show Profile
Thanks guys, project pix to follow . . .
1975 Jester 12
1981 C22 SR/SK,
Tanzer 16
Sunfish
Response Posted - 05/31/2015 :  19:07:24  Show Profile  Visit shnool's Homepage
Pictures worth a thousand...
C&C 32 Smith Mountain Lake Virginia
Response Posted - 06/08/2015 :  17:52:53  Show Profile
10 layers of fiberglass so far and have filled only 2/3 of the depth of the holes
Ordered 18 and 24 oz. roving weave from JD.
All this only to drill new (smaller) holes
Found a sign maker with an XY cutter that is going to make templates (at 115%) that will match the exact shape of the instrument bezels
Pix to follow.
1975 Jester 12
1981 C22 SR/SK,
Tanzer 16
Sunfish
Edited by - OJ on 06/09/2015 16:48:48
Response Posted - 06/10/2015 :  04:03:46  Show Profile
I filled my deadlight with the thickened gflex, still gotta gelcoat over it. Done a lot of glass work but not much gelcoat.
maybe your could put a waxpaper and board over it and leave an opening at the top and pour it in to fill it.
West Systems G/Flex Thickened Epoxy Adhesive
just an idea, rather than laying up all that glass.
Edited by - redeye on 06/10/2015 04:05:00
dasreboot
Response Posted - 06/10/2015 :  04:56:16  Show Profile  Visit dasreboot's Homepage
I changed my cheoy lee 36 from large windows to small ports. plywood on the inside, layed in alot of roving and epoxy. covered with release fabric and plastic and sucked it down with a shop vac. (put a hole in the hose so it gets some air to cool the motor). then came the fairing and painting. A LOT of work. Not sure I would do it again.
Todd Lewis
Eowyn 87 TR/WK C25 #5656
ARWEN 84 TR/SK C25 #4031
www.mainsailsailingschool.com
Response Posted - 06/10/2015 :  10:44:32  Show Profile
Originally posted by dasreboot
. . . A LOT of work. Not sure I would do it again . . .
I'm approaching that threshold
1975 Jester 12
1981 C22 SR/SK,
Tanzer 16
Sunfish
Response Posted - 06/10/2015 :  16:03:29  Show Profile
That's why there is plywood sandwiched between two skins of fiberglass. I'm really surprised that you took this route for the repair. I hope your really, really good at matching gelcoat because that is what you will constantly see in that location.
Response Posted - 06/10/2015 :  16:20:36  Show Profile  Visit britinusa's Homepage
Router really nice clean edges around the old holes and then gel coat in an obviously different color (Grey, Black, Blue, whatever) and put your new holes in that. It might look really sharp.
Joint Decision. (Sold)
PO C250WB 2005 Sail # 841.
Moved up to C34 Eximius
Updated August 2015
NautiC25
Response Posted - 06/11/2015 :  14:08:32  Show Profile
I'm taking the easy way out. Installing 6" marine speakers, then mounting new mast-mounted gauges later. I'm tired of blasting the cabin speakers just so I can hear it out in the cockpit.
1989 C-25 TR/WK #5894
Miss Behavin'
Sittin' in LCYC on Canyon Lake, Texas
Response Posted - 06/16/2015 :  18:54:12  Show Profile
Gel coat is stupidly expensive - so I am going the StarBoard route. Sample template I had made to cover old/large instrument holes:
24 ounce roving weave filled the holes much faster:
1975 Jester 12
1981 C22 SR/SK,
Tanzer 16
Sunfish
Edited by - OJ on 06/16/2015 19:41:17
Response Posted - 06/16/2015 :  20:01:42  Show Profile
Coremat might have been even faster--about 1/6" thick. Defender sells it by the yard--you might be able to get some scrap from a fiberglass fabricator.
The Starboard plate looks good--the nice thing is it works like hard soap, with ordinary wood tools.
Edited by - Stinkpotter on 06/16/2015 20:02:33
Response Posted - 06/17/2015 :  07:24:18  Show Profile
Or you might make a mold with the new hole in the middle, essentially a doughnut or collar, to fill the gap.. that way you could lay it up laying flat before inserting.
Might use Kitty hair for the mold.
Anyhoo OJ that looks great.. Your gonna have the strongest mounts in the industry...
Edited by - redeye on 06/17/2015 07:26:00
Response Posted - 06/17/2015 :  14:24:19  Show Profile
Yeah, I let the store manager at WM initially talk me into what he had on the shelf - stupid me!
Picked up one more sample template today - should do the trick - pix to follow.
1975 Jester 12
1981 C22 SR/SK,
Tanzer 16
Sunfish
Edited by - OJ on 06/17/2015 14:27:02
glivs
Response Posted - 07/08/2015 :  17:16:00  Show Profile
Just curious how your project turned out...
Response Posted - 07/10/2016 :  15:01:32  Show Profile
Responding to glivs question a year and two days later
Thanks for the above input!
Project summary:
Practicing to get the correct sizes:
Holes made by previous owner(s) were not the same size:
For filling old (oversized) holes:
After about 10 layers:
Re-drill 2 old holes, 1 new:
Thickness of bulkhead:
Coating edges with epoxy:
Bezels I had made to cover old, oversized holes:
Making sure bezel doesn't shift while drilling each hole:
Bezels ready to accept displays:
Speed display installed:
Thru-deck for wind wane. Soldering 22 AWG wires into pots + heat shrink = TEDIOUS
Raymarine makes very high quality products:
1975 Jester 12
1981 C22 SR/SK,
Tanzer 16
Sunfish
Edited by - OJ on 07/10/2016 15:23:59
Sailynn
Response Posted - 07/24/2016 :  00:27:39  Show Profile
Looks great. Thanks for the pictures too.
Lynn Buchanan
1988 C25 SR/WK #5777
Sailynn
Nevada City, CA
Tomas Kruska
Czech Republic
Response Posted - 07/26/2016 :  01:56:46  Show Profile  Visit Tomas Kruska's Homepage
OJ, really nice clean work!!
Btw. why you haven't bought that tri-data display instead of two separate speed/depth displays? Less holes and maybe a little cheaper.
Or get i70 series display and have all the data in one unit :-)
Dalpol Phobos 21, 2013, Sole Mio, hull #27, current adventures - We sail Phobos 21
PO of Catalina C25, 1978, High Anxiety, hull #701, SR, FK, L-dinette, inboard diesel Volvo Penta MD2010C w/saildrive - more info
Edited by - Tomas Kruska on 07/26/2016 06:43:47
Response Posted - 07/26/2016 :  09:27:34  Show Profile
Hi Tomas and thanks for the compliment. I considered the tri-data display but drilling a third hole required less skill!
Response Posted - 07/26/2016 :  17:22:39  Show Profile
Why have one gauge when you can have three! The more the better. Ever look at the dash display in a 747? It's a cool factor. The only thing that could make it better would be if they were analog with vibrating needles!
Response Posted - 07/26/2016 :  17:58:10  Show Profile
1975 Jester 12
1981 C22 SR/SK,
Tanzer 16
Sunfish
glivs
Response Posted - 07/27/2016 :  18:25:50  Show Profile
Well done!
Akenumber
Response Posted - 08/21/2016 :  12:34:57  Show Profile
Yes very nice. It killed me just to turn an old 4in hole into a 5 x 7 for a chartplotter.
Ken
San Diego
84 C25 SR/FK 4116
The KRAKEN
