 Where do you mount your mast wire thru-decks?
Initially Posted - 07/02/2015 :  08:08:36  Show Profile
Adding wind instrument which requires another thru-deck near the base of the mast. Where do you install your thru-decks in relation to the mast tabernacle?
1989 C25 TR/WK, #5822
1973 McVay Minuet 19
1975 Jester 12
1981 C25 SR/SK, #2428
1981 C22 SR/SK,
Tanzer 16
Sunfish
Response Posted - 07/02/2015 :  17:14:26  Show Profile
I only have 2. One is the factory mast lights deck plug on the port side and the second is in front of the mast for my radio wire. Find a place that you aren't going to kick with your foot if you intend on using a deck plug. My mast light plug is beat up from being kicked. The radio wire isn't a deck plug. The wire passes through the deck (water tight thru-deck) and has the connection inside the boat in the head ceiling. It is much more forgiving to being kicked.
Edited by - islander on 07/02/2015 17:19:46
Response Posted - 07/02/2015 :  17:20:07  Show Profile
I mounted mine close to the one for the mast light wires. That way, I only had to remember that there was only one area where I had to be careful of where I stepped.
Response Posted - 07/03/2015 :  10:38:09  Show Profile
Steve,
Perhaps you are a member of the CRS club?
1975 Jester 12
1981 C22 SR/SK,
Tanzer 16
Sunfish
Response Posted - 07/03/2015 :  12:06:21  Show Profile
Steve,
I googled "CRS Club" because I never heard of it, and google took me to a chatline where someone described it as a "dive-bar strip club with no dancers," in Tazewell Tennessee. They said "CRS" stands for "C (cut) R (rape) S(stab)" I trust that isn't the CRS Club to which you're referring.
By mistake, a buddy and I stopped in such a place many years ago, in my college days, but shortly thereafter we crawled out the door on our hands and knees, right after the fight and the shooting started. Ah, those were the days!!!
Response Posted - 07/03/2015 :  13:55:20  Show Profile
I just learned this one the other day myself.
Can't Remember Sh%$
Association Member
Andiamo
'89 SR/WK #5862
Kemah,TX
cat25
Response Posted - 07/07/2015 :  11:59:02  Show Profile
Could probably mount a ss drink holder upside down to protect the plug. Then you need something to protect your toes.
Ken
Chenango~
1990~TR~WK~C25~#6022
Candlewood Lake, Ct
upnorth-mn
Response Posted - 07/08/2015 :  09:07:44  Show Profile  Visit upnorth-mn's Homepage
How do you run the coax for the radio antennae inside the boat for a clean looking install?
Up North - C25 SR/SK Traditional w/Pop-top #2172 / Lake Pepin
upnorth-mn@nym.hush.com
she's an old boat he says / with gate valves as seacocks / cracked and weathered teak / and sails misshapen / from close hauled tacks upwind
Response Posted - 07/08/2015 :  09:39:10  Show Profile
The cable/wire runs through the deck with a cable clam. The connection is inside the boat out of the weather. The cable clam is not my photo but is for illustration, The connection photo is mine.
