 Cockpit Scupper Improvement
wanderer13
Initially Posted - 10/31/2015 :  15:49:23  Show Profile
Hello everyone,
After several seasons of scupper frustration, I decided to improve upon the original Catalina design of the cockpit drainage scuppers. I was having repeat trouble with leakage and with streaking on the transom from dirty drain water. I also found the issue of standing water in the recessed area directly in front of the scupper tubes to be questionable.
After much thought and research on this forum, I decided to remove the recessed area and install new scupper tubes that could be fitted vertically, yet still drain completely.
I decided to go with the Marine-East Cyclodial L-shaped through hull. It requires some minor cutting/modification to fit this application but it otherwise worked great.
https://www.marineeast.com/a_sch/sch_det.asp?cid=05&pid=05_03
The original bronze through hulls cut out pretty easily with a dremel. The hole needed to be widened to 1 7/8", which was accomplished easily with a deep-set hole saw. The insides of the holes were coated with unthickened epoxy.
To remove the recessed area, I ground out the area to bare fiberglass and built it back up with with layers of fiberglass roving and matting until it was about 1/8" from level with the deck. After I installed the through hulls, I faired it out with thickened epoxy.
Here's the final product:
The through hulls were bedded with Life Seal. It drains the cockpit faster than it can be filled with a hose. No more standing water in the cockpit - and no more drip lines down the aft end of my boat!
Critiques welcome!
1981 Catalina 25 FK/TR
LVjimmy
Response Posted - 11/01/2015 :  10:21:18  Show Profile
Looks Great and good documentation of the modification.
Response Posted - 11/01/2015 :  10:44:07  Show Profile
Dual exhausts! Now for some chrome tips... I thought about using those fittings to replace the brass tubes (that had cracked and were leaking) years ago, but then I couldn't find them any more.
Edited by - Stinkpotter on 11/01/2015 10:46:18
sethp001
Mainsheet C-25 Tech Editor
Response Posted - 11/01/2015 :  13:37:06  Show Profile
Good idea!
Seth
"Nomad" 1980 Prindle 16
Response Posted - 11/01/2015 :  16:01:10  Show Profile  Visit delliottg's Homepage
Nicely done!
David
C-250 Mainsheet Editor
Sirius Lepak
zeil
Response Posted - 11/01/2015 :  23:13:17  Show Profile
Would it be worthwhile to prevent "oopsies", by adding screens?
Henk & Johanna
Akenumber
Response Posted - 11/05/2015 :  19:19:19  Show Profile
Has anyone replaced the original brass with new brass ones?
Ken
San Diego
84 C25 SR/FK 4116
The KRAKEN
