 charging batteries/wiring diagram
smosh
Initially Posted - 03/29/2016 :  13:55:00  Show Profile
Happy Spring, all! Now begins getting my boat ready for splashing. This is my second season with her- last spring was just doing the bare minimum to get her in the water, then taking the season to figure out what to upgrade and repair.
I found that the batteries do not charge. I've a newish Honda that has an alternator and shows green while running, leading me to believe the motor is outputting current. I charged the two new batteries in my garage at the beginning of the season, but in September or so, the power ran out. So I charged again with shore power. Now I need to figure out what's missing or not working.
Does anyone have a schematic for what a two battery system (with alternator or solar charging capacity) should look like? I've got a Guest orange 1-2 switch and the stock switch panel. Everything functioned last summer, but i don't think the system charged.
Thanks!
1979 C25 - Hull #1000
Currently "Phoebe"
Response Posted - 03/29/2016 :  14:34:46  Show Profile
Does this help? It will help us provide more accurate answers if you will indicate the year your boat was built, it's hull number, whether it's a C25, and if it's a standard or tall rig. Members usually include that info in their "Signature." Look at the signatures of some of our members, for examples. You can create your signature by clicking on "Profile", in the upper right-hand corner of the webpage.
The following info is for a pre-1988 C25.
smosh
Response Posted - 03/29/2016 :  17:06:48  Show Profile
Thanks, Steve. I'm not sure why my Association info never propagates to the message board, as it seems to do for you. Anyway, I added my boat to my .sig.
I'm sure the battery setup isn't stock, so i figure any charging system wouldn't be anyway. In the next few days I'll pull the tarp off and climb into the lazarette to scope out the jumble of wires. A previous owner added radio and a 12v outlet. I guess I have to figure out -what- the wire coming from the motor should go to!
Currently "Phoebe"
Response Posted - 03/29/2016 :  17:23:15  Show Profile
Incidentally, those schematics came from the owners' manual. You can download one if you'd like. It contains a lot of good information. You can find it by clicking on "Manuals & Brochures" on the upper left side of this webpage.
tpothen
Response Posted - 03/29/2016 :  17:59:13  Show Profile  Visit tpothen's Homepage
Is the green light by the pull start? I only ask because all the Smaller Honda's I've seen, the green light is the oil pressure light. The only way to see if the outboard is charging is to hook up a battery and put a volt meter to it.
"Myasis Dragon" 77' C25/SR/SK/Din.
www.svmyasisdragon.com
Peregrine
Response Posted - 03/29/2016 :  19:47:10  Show Profile  Visit Peregrine's Homepage
I take it you are trying see if your engine is charging the batteries.
The diagrams above will not help you they are just from the batteries to the on board systems.
You need a diagram from the engine alternator to the batteries.
Try the following search in Google.
"Charging batteries from an outboard wiring diagram"
You'll find a few diagrams and posts.
I'll be pulling the cover off Peregrine next week and will try to draw out how mine works. Yours may be different.
John Gisondi
Peregrine
#4762
Response Posted - 03/30/2016 :  17:26:34  Show Profile
Both John's and Tpothen's advice is good.
To check whether your battery is charging with a digital multimeter or DMM (easier than an analog VOM), set the meter to 20 VDC. Place the red lead of the DMM to the positive terminal and the black to the negative terminal.
Measure the resting voltage with all the equipment turned off. A battery reading between 12.7 to 12.8 VDC is fully charged. If it reads below 12.0VDC it's definitely discharged by several tens of Amp Hours.
Start the motor. A battery that's charging will measure in the 13.6-14.3VDC range depending on a number of factors. If the voltage is still less than 12.6VDC, it's not charging.
A fully discharged battery being charged at 6 Amps will recharge in about 7-10 hours.
SKS
Response Posted - 03/31/2016 :  09:42:20  Show Profile
I have a wiring diagram. I can't figure out how to add pictures or files, or I'd post it.
If I could get an email, I'd send it to you.
Response Posted - 04/03/2016 :  10:10:46  Show Profile
SKS,
Seems you're just down the road from me in Norwalk CT.
To post a pic on this forum, start by posting it on a photo site like the Catalina Gallery here, or picasa, flickr, etc.
Get the jpg URL and put it between the html expressions:
[ img ] - start of the expression and skip the spaces
[ /img ] - the end of the expression and skip the spaces
Between the expressions you'll find something like http://www.gallery.flickr.com/24$srm5&1evQ28$.jpg as the URL for the image.
If you want to email the diagram send it to bruce 2 sail at aol dot com. Hope to see your boat one of these days...
SKS
Response Posted - 04/03/2016 :  20:16:54  Show Profile
By George, I think I've got it. Although to be honest, it's somewhat tedious.
Response Posted - 04/05/2016 :  20:13:46  Show Profile
Michael,
This looks like a good system except you can inadvertently switch off the alternator while the motor is running. That would fry your alternator or regulator. The diagram does not indicate any battery fuses (within a foot or two of the battery positive terminal). If the actual circuit on your boat indeed has no inline fuses, I'd suggest you install them ASAP.
