 minimum HP motor for a 25
77Gypsy
Initially Posted - 03/12/2003 :  09:46:43  Show Profile
i have an 8hp elec/start now. i sail in the chesapeake, with a strong current, what would be the minimum HP you would suggest?
Thanks!
Steven de Filippis
77 catalina 25 - Gypsy
Response Posted - 03/12/2003 :  11:53:37  Show Profile
I wouldn't go lower than an 8hp and no higher than a 9.9hp. I have read in this forum of people using 6's, but, to me, this seems a little underpowered(unless you just use it as a kicker on a small, calm lake).
The C25 manual states,
<b>RECOMMENDED OUTBOARD ENGINE</b>
<i>"An outboard engine of 7.5 to 10 horsepower should be adequate to propel the Catalina 25 at hull speed under usual conditions.
A larger engine will not increase hull speed and may add additional unnecessary weight in the stern.
Long shaft engines are preferable, however, standard length shaft engines should be adequate for most conditions."</i>
I've used my 8hp in currents, wind, waves, weather, and it has performed well and if I ever had to replace it, I would most likely get another 8hp.
<img src="http://im1.shutterfly.com/procserv/47b2cc32b3127cce92e981259d130000001010" border=0>
North Star SR/FK
Response Posted - 03/12/2003 :  12:13:29  Show Profile
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote>standard length shaft engines should be adequate for most conditions. <hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote>
Catalina should eliminate the above statement from their manual. Very few C-25 owners would agree with it. You really need a long shaft motor. It doesn't take much of a chop to make a standard shaft motor cavitate.
Response Posted - 03/12/2003 :  12:28:12  Show Profile
Good point, Steve. I should've stressed that also.
North Star SR/FK
Response Posted - 03/12/2003 :  20:39:02  Show Profile
Make that extra-long (25" and above) or whatever it takes to get the anticavitation plate 4-5" below the static waterline.
Edited by - dave bristle on 03/12/2003 20:46:56
mroettersr
Response Posted - 03/13/2003 :  00:13:36  Show Profile
Steven,
I have a Honda 8 long shaft and I sail on Lake Erie. I have had problems with cavitation in the chop we frequently get on the Lake. My next motor will be the extra long shaft even though the motor weighs significantly more. Having the prop loose its grip while the boat pitches is no fun. However, once moving at a few knots, the stern seems to settle down more and there is little problem. The motor seems to have enough H.P. to move the boat at or near hull speed.
Mike Roetter
'83 C25 #3568 SK/SR
Marblehead on Lake Erie
