 Removing vinyl boat name, boat numbers
doublereefed
Initially Posted - 05/03/2016 :  08:40:20  Show Profile
What's the easiest way to remove PO boat name? I will also need to remove the registration numbers... it looks like all are vinyl.
-Richard
'95 C250 WB #61
Midway, UT
zeil
Response Posted - 05/03/2016 :  09:16:16  Show Profile
Use a heat-gun or hairdryer
Henk & Johanna
Response Posted - 05/03/2016 :  14:42:05  Show Profile  Visit delliottg's Homepage
What he said. We used a Harbor Freight heat gun on it's lowest setting to remove the previous name & out of state registration. Then used polishing compound to remove the "ghosting" from the dissimilar weathering due to sun exposure. If you know exactly where to look, and the light's right, you can actually pick out the previous two names of our boat.
David
C-250 Mainsheet Editor
Sirius Lepak
doublereefed
Response Posted - 05/03/2016 :  22:03:55  Show Profile
Perfect. Thank you!
'95 C250 WB #61
Midway, UT
doublereefed
Response Posted - 05/20/2016 :  20:17:39  Show Profile
$12 Harbor Freight head gun worked a charm. I used a rag with a little acetone on it to wipe off the sticky edges, then washed it down with water.
Thanks for the tip,
-Richard
'95 C250 WB #61
Midway, UT
