 LED Nav Lights
Initially Posted - 06/18/2016 :  15:11:05  Show Profile
I've checked Aqua Signals website for LED nav light fixtures more than once and I've never been able to locate any that will fit our boats.
Does anyone have a source for LED nav light fixtures. I already have a LED bulb in my Aqua Signal 25 fixture on the bow but have a problem keeping it working. Just want something that's made for LED.
Association Member
Andiamo
'89 SR/WK #5862
Kemah,TX
Edited by - GaryB on 06/18/2016 15:11:27
Response Posted - 06/18/2016 :  22:16:23  Show Profile
What's the problem? Bad connections or incorrect color temperature?
I've tried several LED lamps in my bow nav light fixture. The Dr LED Polar Star LED light works like a charm. See Link
I've also used a 41mm festoon LED bulb with dimpled slip-on connector adapters. These adapters convert the pointy festoon contacts into dimpled connections matching the fixture's contacts. An early version I tried generated tons of RF interference on my FM radio and weather radio. The replacement bulb fixed that.
Response Posted - 06/19/2016 :  04:00:56  Show Profile
If the problem is that the Led bulb is heavier and keeps loosing contact I remember a member on the forum put a small Zip tie around the tabs in the fixture that created more pressure on the bulb contacts and was successful in keeping the bulb in good contact.
Response Posted - 06/19/2016 :  06:37:24  Show Profile
You're right Scott the Polar Star is pretty hefty so it can get dislodged by pounding wave action. Tape or ties can help. But the 2nm six-LED festoon bulb works fine and weighs not much more than the original incandescent bulb.
Response Posted - 06/19/2016 :  08:19:27  Show Profile
I've got the Dr Led bulb now (it does work well and is bright) and while I could try the above recommendations I still need to replace the fixtures anyway and I was hoping to find new fixtures that were specifically made for LED bulbs.
Part of the concern is if by chance I were involved in an accident at night could I be held accountable if I were using a Coast Guard approved LED bulb in a fixture that is not Coast Guard approved for use with a LED bulb, only an incandescent bulb?
Association Member
Andiamo
'89 SR/WK #5862
Kemah,TX
TCurran
Response Posted - 06/19/2016 :  08:33:37  Show Profile
I use lights from here (anchor, steaming/deck combo, bi color nav)...https://store.marinebeam.com/uscg-certified-led-nav-lights/
I like the quality and the fact that they are a sealed unit, hard for the elements to get to the internal connections. The only connections are the red and black wires, which are external to the units.
Tom Curran
1981 Capri 25 Hull #101 "Dirty Debbie"
1988 Watkins 30
PAFB, FL
Response Posted - 06/19/2016 :  08:41:29  Show Profile  Visit OLarryR's Homepage
The Lopolight is a red/green combo LED nav light fixture that is USCG approved and has been out for several years or more. Do a search in Yahoo do see those that sell it. ...but it is pricey.
Larry
Response Posted - 06/19/2016 :  20:10:35  Show Profile
Thanks Tom. They do look nice. Can you advise which model numbers you use?
Association Member
Andiamo
'89 SR/WK #5862
Kemah,TX
Edited by - GaryB on 06/19/2016 20:11:21
Response Posted - 06/19/2016 :  20:13:02  Show Profile
At $380 a piece or more I think I'll pass.
Who makes your anchor light, Orca or something like that?
Association Member
Andiamo
'89 SR/WK #5862
Kemah,TX
Response Posted - 06/20/2016 :  04:26:12  Show Profile  Visit OLarryR's Homepage
My LED photo-diode anchor light is made by OGM (Orca Green Marine). It is USCG approved. I have had it quite awhile now - Just checked my mtn log on my website - It was installed JUN'06.
The Lopolight...well I did say it was pricey. I had considered it years ago...and kept on considering it. Now at $380 - Wow ! That seems a lot more than in the past.
Larry
TCurran
Response Posted - 06/20/2016 :  04:49:34  Show Profile
[/quote]
[/quote]
Bi-Color nav - https://store.marinebeam.com/led-bi-color-navigation-light/
Anchor - https://store.marinebeam.com/led-all-around-anchor-light/
Steam/Deck Combo - https://store.marinebeam.com/led-masthead-foredeck-combination-light/
The folks I sail with say there is no problem seeing me at night, the red/green lights stand out, which, to me, is the most important part...be seen!
The deck light is nice, because it's LED i don't mind leaving it on when I anchor in a busy area.
I'm waiting for my stern light to start giving me a problem before I replace the unit, it's currently a Aqua-Signal with an LED bulb.
Tom Curran
1988 Watkins 30
PAFB, FL
Response Posted - 06/20/2016 :  19:03:21  Show Profile
I may have looked at different lights than what you looked at.
Association Member
Andiamo
'89 SR/WK #5862
Kemah,TX
Response Posted - 06/20/2016 :  19:04:29  Show Profile
[/quote]
[/quote]
Thank you Tom! Just placed an order for the Bi-Color and Stern lights.
Association Member
Andiamo
'89 SR/WK #5862
Kemah,TX
Edited by - GaryB on 06/20/2016 19:13:27
Response Posted - 06/23/2016 :  10:10:15  Show Profile
Has anyone found a LED replacement for the incandescent cabin lights?
Jerry
Response Posted - 06/23/2016 :  19:21:48  Show Profile
Lights arrived today. Wow, they are sooo bright!
A little expensive compared to the Aqua Signal 25's but man the construction and quality are so much higher I feel they are well worth the extra money.
Now the next question. The outer insulation is thick and I'm wondering how in the heck am I going to be able to feed it through the bow pulpit and stern rail?
Association Member
Andiamo
'89 SR/WK #5862
Kemah,TX
Edited by - GaryB on 06/23/2016 19:22:23
Response Posted - 06/23/2016 :  22:27:59  Show Profile
Jerry, the original incandescent light bulbs in the cabin are similar to automotive bulbs 1156, which is a taillight bulb. The bulb has a "bayonet" base with two equally spaced pins to hold the bulb in the fixture. These bulbs are not as bright as 1157 bulb, which is a combo taillight and brake light bulb. This has two base contacts (one for the taillight and one for the brake light), and offset bayonet pins to align the base contacts, which don't match the light fixture.
I was able to file off one of the bayonet pins and solder the two contacts together to allow me to use the 1157 bulb in the fixtures. Another difficulty is that for some reason, the Catalina wiring diagram connects positive to the socket and negative to the base. This is the reverse of an automotive socket which has positive on the base and negative on the socket. This requires you to rewire the fixtures before the LED will work.
All that said, many people have purchased LED fixtures and replaced the old fixtures with the new ones.
On Passage, I replaced the two main fixtures (over the starboard settee and over the port dinette table), with LED fixtures. These work very well. I left the rest of the fixtures along and replaced the incandescent bulbs with 1157 LEDs. I used warm white LEDs that work fine.
Response Posted - 06/23/2016 :  22:33:10  Show Profile
Gary, Are the cables permanently attached to the fixtures or can you replace them with thinner cables?
I would not advise splicing cables at the fixtures.
Edited by - Voyager on 06/23/2016 22:34:41
TCurran
Response Posted - 06/24/2016 :  04:10:24  Show Profile
Yup...they are bright. Was out the other night with a couple other boats, I thought one of the lead boats was using a spot or flashlight to light up a manatee marker, nope, it was my red/green bow light illuminating it from ~1/4 mile.
I had enough of the old wire to make the splice on the outside (shrink wrap connectors and self- fusion silicone tape). I did this for the same reason you're describing, it was the easy way out but not as neat. Figured I could spend hours on the boat fishing wires or cut, splice, and go sailing.
Tom Curran
1988 Watkins 30
PAFB, FL
Response Posted - 06/24/2016 :  17:10:00  Show Profile
Bruce - The wires are permanently attached inside the fixture so no way to replace with thinner wires.
Tom - Glad to hear they are bright out on the water. That's exactly what I was hoping.
I'll try to fish the wires down into the cabin but if they harass me at all... I've got a brand new set of wire cutters and strippers and will make quick work of getting them up and running.
Edit: HA! No pun intended
Were you able to use the supplied screws to mount yours to the bracket or did you have to improvise?
Association Member
Andiamo
'89 SR/WK #5862
Kemah,TX
TCurran
Response Posted - 06/25/2016 :  04:30:44  Show Profile
Pretty sure I used the screws, but had to drill new holes (full disclosure - I installed the LEDs on my Watkins, not a C25 or my Capri). I'll double check when I'm on the boat later today.
Tom Curran
1988 Watkins 30
PAFB, FL
Response Posted - 06/28/2016 :  13:40:38  Show Profile
I kinda figured you were referring to the Watkins.
Association Member
Andiamo
'89 SR/WK #5862
Kemah,TX
TCurran
Response Posted - 06/29/2016 :  09:47:40  Show Profile
Gary...sorry I forgot to post my findings. Yes, I was able to use the supplied mounting screens, but had to drill new holes in my mounting bracket, they were 90 degrees off. Hope your install is going well.
Tom Curran
1988 Watkins 30
PAFB, FL
Response Posted - 06/30/2016 :  17:38:46  Show Profile
Thank you Tom! I'm hoping to get a chance to work on the lights and clean up the boat this weekend.
Association Member
Andiamo
'89 SR/WK #5862
Kemah,TX
