 Which Anchor for FL Keys and Bahamas
albert
Initially Posted - 03/13/2003 :  22:49:09  Show Profile  Visit albert's Homepage
I'm planning to participate in the Bahamas Flotilla 2003. What ground tackle is recommended for Florida Keys and Bahamas.
Albert Iturrey
al@comhertz.com
<i>Abacus'</i>: http://www.comhertz.com/abacus
Response Posted - 03/14/2003 :  00:51:35  Show Profile  Visit Leon Sisson's Homepage
Albert,
I haven't actually taken my Catalina 25 to the keys or the Bahamas yet, but then again, I'll stick my neck out and say that I doubt that very many on this board have. Having gotten that disclaimer out of the way, here's my choice of ground tackle for cruising the east coast of Florida.
On the bow I have a Danforth (a Fortress would be nice) and a copy of a Bruce. Each is one size larger than recommended by the manufacturers. The Danforth has 20' of 3/16" chain and 300' of 3/8" nylon double braid. The Bruce clone has 30' of 1/4" chain, and 250' of 7/16" nylon double braid. Both rodes are terminated with eyes spliced around nylon thimbles. Both ends of the galv. chains are terminated with galv. shackles secured with SS safety wire. Bitter ends are tied off to something substantial in the locker with 3/16" or 1/4" lanyards a foot or two long. I have an adjustable divider in the anchor locker to keep the rodes separated. On the stern rail, I'll carry a standard size Danforth or close copy with a few feet of chain and 100' of 3/8" nylon double braid. The stern anchor will be holstered in a piece of 3" PVC pipe clamped to a stern rail stanchion for quick use. The stern rode will be in the cockpit locker ready to run from a bag or bucket, with the bitter end secured. I also will be carrying at least one spare large Danforth style with some chain and 100' of 3/8" or 1/2" nylon stuffed somewhere in the bilges.
I look forward to reading what others have used, or would use, down there.
I know you have an autopilot. Got your VHFs, GPS, large fuel & water tanks, cruising guide and chart kit, compasses, dinghy, passport, well insulated ice box, etc.? It sounds like an excellent adventure! Have you also considered the Abacos? That looks like some mighty fine C-25 cruising to me.
Gloss
Response Posted - 03/14/2003 :  06:45:18  Show Profile
Hey Leon,
Thanks for sharing with us your ground tackle information.
One more question. Do you have any of these anchors mounted on a bow roller? I have been thinking of mounting a bruce, or plow on a bow roller, but haven't seen any other 25's with this setup. I wonder if it would get in the way of the locker door opening.
I also sail the keys and the upper gulf of Mexico. I have found that my Danforth is not worth a darn in grass.
Frank Gloss
89WK/TR
Response Posted - 03/14/2003 :  08:48:44  Show Profile  Visit Leon Sisson's Homepage
Frank,
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote>I have been thinking of mounting a Bruce, or plow on a bow roller, but haven't seen any other 25's with this setup. I wonder if it would get in the way of the locker door opening.<hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote>Yes, the 22# Claw (Bruce copy) is on a roller. I use the combination stem fitting bow roller from Catalina. This size <i>almost</i> interferes with the locker lid. I cut about a 1"x2" notch in the front lip of the locker for rodes, and I drilled a retaining pin hole in the Claw which, combined with the Catalina roller, positions the anchor so that it doesn't either fall over the bow or prevent the locker from opening. It's a tight fit, but works well. The roller is key to making the heavy Claw easier to use than the Danforth, which hangs under the pulpit.
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote>I have found that my Danforth is not worth a darn in grass.<hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote>Yes, that's my reason for Danforth/Bruce combination - they compliment each other. The Danforth excells in soft bottoms where the Bruce might not hold as well. The Bruce works in hard sand, grass, gravel, rocks, etc., and resets reliably, where as those aren't strong points for the Danforth.
<img src="http://www.trailersailor.com/uploads/c25_bow_01j.jpg" border=0>
Response Posted - 03/14/2003 :  11:01:17  Show Profile
Man, if I had a setup like that, the powerboats in the slips around me would have holes in their topsides! <img src=icon_smile_evil.gif border=0 align=middle>
Response Posted - 03/14/2003 :  11:14:16  Show Profile
Leon, that sure is a heck of an anchoring armentarium! (But I wouldn't want to take it all racing...) That's more than we use on the 50' Catamaran at the Texas coast.
Derek
Response Posted - 03/14/2003 :  12:44:35  Show Profile
Leon has the base's covererd very well. I'm planning for the April flotilla as well and I think part of the ground tackle desisions are based on what you have now and what you will anticipate needed for the future.
For example, my 16.5 lb claw which is sized for 24-30 foot boat on a 200 ft 1/2 inch rode with 15 ft of chain may be a little light for this trip. I have a 10 lb mushroom that I will use a snatch block and lower down the rode to increase the effectiveness of the claw and it will also serve to buffer the seas as we likely will spend two nights at anchor on the banks crossing to the Berry Islands.
Because of reversing tides on the shallow banks... the bahamian mooring is the anchor scheme of choice. Two anchors 180 degrees to each other off the bow. This places a need of course to have two suitable anchors and enough rode to support both.
Arlyn C-250 W/B #224
N/E Texas and Great Lakes
JimB517
Response Posted - 03/14/2003 :  12:48:48  Show Profile  Visit JimB517's Homepage
Hi, I spent 4 months cruising in the Keys and the Bahamas in 2001 (not on my C25) www.indiscipline.org Click on Cruise 2001 to see all our adventures from Key Largo to Georgetown in the Exumas and back.
The bottoms in the Bahamas are all sand and you don't need anything but a couple of nice 15 to 20 lb Danforths. I would have at least 30 feet of chain on them. It's easy to get the anchor hooked on a rock or find yourself "anchored" in 4 inches of sand over hard rock so back down hard and dive on them and check them. If you find only 4 inches of sand you've got to move!
The "Bahamian Moor" is when you put out two anchors, one off the bow and one off the stern, but lead BOTH rodes to your bow. This is essential in the small Cays because you'll often be anchored in 15 feet of water between two sand bars or coral heads with about 30 feet of swinging room. Tides in the Bahamas are about 3 feet so always be in at least 9 feet of water (whatever the tide) and you'll be OK. Tidal currents and winds will reverse in the middle of the night.
Be prepared for anchoring in 30 to 35 knots of wind. A front passes through about once per week in the winter/spring.
In the Keys if you are anchoring in the mangroves it will be all mud bottoms. A 25 lb CQR on a lot of chain will hold your boat well in the mud. The danforths are useless. But in the Keys there are lots of cheap marinas, hotels with docks, Tiki bars, and other places to tie up. We anchored out there very seldom. In the mud, getting as much wight as possible on the bottom is essential. Also back down slow and give it time to sink in.
Since the CQR will not stow very well, you should probably carry this one on your bow roller as your principal anchor, with a 20 lb Dan next to it. Keep a 15 in the lazerette as a backup or for the Bahamian moor.
By the way, the key to doing the "moor" is to set your bow anchor like normal. Put out a huge amount of scope, as much as you can until your stern is over the place where you want the 2nd anchor. Carry it from the bow to the stern and drop it in. Take up on the first rode while letting out on the 2nd until the boat is where you want it to sit. Try to leave both rodes fairly slack. It takes about an hour to get it right. Remember to dive on them unless your sure they are really dug in.
In some of the bigger storms I had all three anchors out and never dragged or had a problem (other than rolling). For my 20,000 lb powerboat I had a 45 lb CQR on 100 feet of chain and 300 feet of 7/8 inch, a 25 lb danforth on 50 feet of chain and 200 feet of 3/4 inch and a 15 lb danforth on 15 feet of chain and 200 feet of 1/2 inch. In one big storm with all 3 anchors out it's almost impossible to adjust all three rodes so the boat is lying to them evenly. In fact, the 15 lb danforth was taking almost the whole load. When it was time to bring it in I found it was about 10 feet down in the sand!
Indiscipline 1978 FK #398
John Mason
Response Posted - 03/14/2003 :  13:44:28  Show Profile
Anyone have experience with the Bulwagga anchor? It did well in the Practical Sailor anchor tests.
http://www.noteco.com/bulwagga/
John Mason
<img src="http://www.users.qwest.net/~jamason/ali.jpg" border=0>
pronounced "Ali Paroosa"
1982 - FK/SR #3290
Response Posted - 03/15/2003 :  08:58:21  Show Profile
Jim, great report on anchoring in the bahamas...and I am liking your site and enjoying reading your fantastic cruise account.
Thanks for sharing!
