 Has anyone replaced halyards with the mast up ?
SKS
Initially Posted - 07/19/2016 :  18:18:52  Show Profile
Both my main and jib halyard are fairly used.
I want to replace them.
I have the all rope halyards mounted internal to the mast.
I was thinking of sewing the end of the new halyard to the old one and just pulling it through.
Seems like a simple technique, I was wondering if it is really as simple as it sounds.
Thoughts anyone ?
Response Posted - 07/19/2016 :  18:28:42  Show Profile
Simple in principle . . . sewing end-to-end is pretty surefire. I'd be reluctant to use tape because of the increasing amount of weight as you pull the new halyard up the mast.
Beware of wires that go to the steaming light (perhaps you have a conduit) + the hardware that connects to the spreaders.
What diameter lines are you running?
1989 C25 TR/WK, #5822
1973 McVay Minuet 19
1975 Jester 12
1981 C25 SR/SK, #2428
1981 C22 SR/SK,
Tanzer 16
Sunfish
Edited by - OJ on 07/19/2016 18:29:37
Response Posted - 07/19/2016 :  18:36:27  Show Profile
That's the way to do it. If you need to measure the old line, you can first sew a cheap messenger line to it, pull it through and measure the old line.
Lee Panza
Response Posted - 07/19/2016 :  18:52:26  Show Profile  Visit Lee Panza's Homepage
Interesting timing; I'll be doing just that this weekend.
I'm planning on doing a simple sewn sheath-within-sheath splice. Remove some core (maybe a foot or so) from both the existing halyard and the new one, and then pull (with a fid) the core-less sheath from the new halyard inside the empty space in the end of the existing one (so the exposed yarn-ends on the outside will be following through the sheaves instead of snagging), and then drop a few stitches of siezing twine through the overlapping sheaths. I'm not intending to use tape, but a turn or two of twine just above the yarn-ends should prevent them from unraveling. Should just take a few minutes to set up. Like OJ says: "Simple in principle."
So, if you want to wait 'till next week I'll let you know if practice matches principle.
Lee Panza
SR/SK #2134
San Francisco Bay
(Brisbane, CA)
Response Posted - 07/21/2016 :  14:32:24  Show Profile
I always butt stitch the lines together with serious thread.
Edited by - pastmember on 07/21/2016 14:42:58
Response Posted - 07/22/2016 :  07:24:08  Show Profile
I'm with Frank. No need to do any fancy splicing. Just butt-sew and then put a small piece of tape over the stitching to reduce the diameter a little. And pull gently!
Chief Measurer C25-250 2008
San Antonio, Texas
cshaw
Response Posted - 07/22/2016 :  07:33:39  Show Profile
The sew and tape is exactly the way I have done it through the years, including the measurement like Steve suggested.
Chuck Shaw
Confetti
Cat 25, hull#1
1976 FK/TR
Response Posted - 07/22/2016 :  07:52:03  Show Profile
Butt stitch . . . I will add that one to my nautical vocabulary. Is that similar to the Bobbitt weave?
1975 Jester 12
1981 C22 SR/SK,
Tanzer 16
Sunfish
Response Posted - 07/23/2016 :  18:59:49  Show Profile
I have used the 'butt stitch' method in the past, as this is an easy pull, and it has always worked well....BUT....I really like the concept of cutting out the core and overlapping the old external jacket over the new, with a few security stitches...kinda like the basket grips for pulling electrical wiring - would totally do that when replacing the halyard on the roller furling.
Jerry
Lee Panza
Response Posted - 07/24/2016 :  21:26:13  Show Profile  Visit Lee Panza's Homepage
OK, Steve; the new halyard pulled through very easily. I'd say the splice wasn't really necessary, but I didn't want to take the chance. I have a lot of lines and cables in my mast, and I didn't want to take any chance on losing an end in there. I was particularly concerned about the connection making it through the sheaves on top. The splice took seven minutes, and nearly half of that time was the stitching. I would imagine the sewn butt-splice would take at least as long as I spent on the lock stitches and the minimal whipping, so the sheath-within-sheath splice added less than five minutes. Five minutes for the piece of mind that nothing could go wrong. By the way, the splice also went through the exit plates and the clutch without any noticeable resistance. So Steve, go for it! Simple in principle, simple in practice.
Lee Panza
SR/SK #2134
San Francisco Bay
(Brisbane, CA)
SKS
Response Posted - 07/27/2016 :  14:45:52  Show Profile
I tried the rest, this worked the best.
Took the core out for a foot or so on each rope to guide around the turns.
Nice technique, with little loss of the replaced rope.
Unfortunately, this whole procedure took better than an hour. I tried a couple of different butt splice techniques before removing the core. otherwise it would have taken about 15 minutes or less.
Edited by - SKS on 07/27/2016 17:11:12
