 Teak
Sailorgal
Initially Posted - 08/05/2016 :  16:55:16  Show Profile
Hatch is checked off the list...a boat wright in our shipyard adapted a hatch he had...works great! We will need a weatherboard now...will order from Catalina Direct....we are debating doing the bright work ourselves v.s. Getting new pieces...grab rails, companionway teak trim, etc....there are some deep grooves in that wood! How do you all make that call? It's a Catalina 25 1984....after All!
Thanks, K
Response Posted - 08/05/2016 :  19:35:29  Show Profile
I can make this suggestion. Remove the brightwork and sand off the crust. You should then find some decent wood under there. Also save some of the clean sawdust - you can use it with wood glue to fill in gaps and defects in the finish.
Or... You could buy new teak, but when you get ready to throw out the old pieces, ask yourself are they really trash?
Response Posted - 08/06/2016 :  07:24:10  Show Profile
I agree with Bruce, I think you will be amazed at how well the teak looks after a little cleaner/brightener, A little sanding and a few coats of varnish. I wouldn't remove any pieces, To time consuming. It takes less time to tape it off. Keep in mind it's a boat that is outdoors and not your indoor furniture. Follow the ten foot rule. If it looks great from ten feet away then go sailing!
dalelargent
Response Posted - 08/06/2016 :  09:24:04  Show Profile
Hah! 10 foot rule. I love it!
1989 c25 WK/TR #5838
1998 Catalina 36 mkii
1983 Vagabond 14
Response Posted - 08/06/2016 :  09:50:33  Show Profile
...and the "It's a boat for _____ sake!" rule.
Response Posted - 08/07/2016 :  07:40:45  Show Profile
I have a 1980, that had ben badly neglected for @10 years prior to me, and the teak never had varnish. That said, teak is a very forgiving wood and as stated, when cleaned and brightened using various scrub brushes and even a bronze-wire brush, the teak will sparkle. I use teak oil (no varnish) and every year scrub with a light brush, let dry and then apply teak oil and the wood still looks great (great based on the 20ft rule, really, really good when closer). If you choose to varnish, clean and prep well, apply the many coats of varnish (or sealer and varnish) and the teak will look "new" . . . . and be much smoother that you may think possible.
Peter Bigelow
Rowayton, Ct
Response Posted - 08/07/2016 :  09:22:13  Show Profile
A lady who detailed boats for a living on the Gulf Coast told me, that in a marine environment Cetol will last longer and look better over time than varnish. If she was asked to use varnish it cost twice as much and she applied 14 coats!
Chief Measurer C25-250 2008
San Antonio, Texas
Response Posted - 08/07/2016 :  09:36:22  Show Profile
The advantage with Cetol, in my experience, is ease of maintenance. You can easily touch up worn areas and add dress coats with just some light sanding. Varnish becomes a problem when it (eventually) cracks and peels--the only real solution is to remove it entirely and start over.
Another option some friends of mine use is Semco, a "sealer" that adds less color and looks more like unfinished teak, but resists the mildew that makes black streaks in teak. They've been happy with it for some 20 years.
Response Posted - 08/07/2016 :  11:31:58  Show Profile
14coats really isn't that much. Walk around any marina and ask the guy with the shiny wood transom how many coats of varnish he has on and he will likely say upwards of. 30.
Sailorgal
Response Posted - 08/07/2016 :  15:08:31  Show Profile
Good point Voyager! I'd say no....
Sailorgal
Response Posted - 08/07/2016 :  15:10:50  Show Profile
Ok, I'm convinced...ill put the cleaner to it and the palm sander and then cetol....it does look good.....
K
Response Posted - 08/08/2016 :  06:40:44  Show Profile
If you chose to leave the teak in the boat, be careful with teak cleaner and brightener solutions. I've seen permanent run marks on the aluminum port light trim rings where the cleaner ran down the sides of the cabin top.
Post pix too!
1989 C25 TR/WK, #5822
1973 McVay Minuet 19
1975 Jester 12
1981 C25 SR/SK, #2428
1981 C22 SR/SK,
Tanzer 16
Sunfish
TCurran
Response Posted - 08/08/2016 :  10:02:48  Show Profile
Or...get use to the grey and just go sailing
Tom Curran
1981 Capri 25 Hull #101 "Dirty Debbie"
1988 Watkins 30
PAFB, FL
Edited by - TCurran on 08/08/2016 10:03:14
