 Magazine rack on hull wall
dalelargent
Initially Posted - 09/17/2016 :  16:33:14  Show Profile
So, a friend just bought a C-25 and I was helping him launch. I noticed he has a magazine/chart rack on the starboard wall, just aft of the settee, and now I have to have one.
How do I mount it? I bet some of you have one there, too. I am scared to death of drilling into that hull wall..... :). How thick is it? How do I get screws to hold well in the fiberglass?
I am looking at the seateak products WM and Dedender sell....
1989 c25 WK/TR #5838
1998 Catalina 36 mkii
1983 Vagabond 14
Response Posted - 09/17/2016 :  16:40:08  Show Profile
There's the hull and there's interior liner. In some places there's a gap between the two . . . in other places there's no gap.
Where will the rack touch the liner?
1989 C25 TR/WK, #5822
1973 McVay Minuet 19
1975 Jester 12
1981 C25 SR/SK, #2428
1981 C22 SR/SK,
Tanzer 16
Sunfish
Response Posted - 09/17/2016 :  20:05:45  Show Profile
If in doubt, epoxy, 5200 or 4200. Glue blocks to the bulkhead and screw into them.
Dave B. aboard Pearl
1982 TR/SK/Trad. #3399
Lake Erie/Florida Panhandle
Bladeswell
Response Posted - 09/17/2016 :  21:49:38  Show Profile  Visit Bladeswell's Homepage
Hello Again,
Sounds like he is a good friend. So why not just ask him if it would be all right to remove one of the mounting screws so that you could see the size and length. Its certainly not going to come crashing down if you remove just one screw. Personally, I would mount it to one of the bulkheads instead. Best of luck.
Bladeswell
Response Posted - 09/18/2016 :  08:41:57  Show Profile
As OJ says, you'll be mounting it to the liner or cabin-top liner--both are separate moldings from the exterior. The hull liner includes the "furniture", cabin sole, etc. If you drill very carefully until you pierce it, you can then feel inside with a piece of wire. Most likely, if you pick screws that project 1/4" out of the holes in your rack, you'll have ample "bite" without encountering the hull (which, by the way, is a pretty thick hunk of fiberglass!)
Edited by - Stinkpotter on 09/18/2016 08:42:45
Response Posted - 09/18/2016 :  09:33:06  Show Profile
Short fat screws...
Edited by - pastmember on 09/18/2016 09:35:46
Response Posted - 09/18/2016 :  09:38:04  Show Profile
Double your fiddle rails...
sethp001
Mainsheet C-25 Tech Editor
Response Posted - 09/19/2016 :  21:23:21  Show Profile
I'd like to third what OJ and Dave said.
Seth
"Nomad" 1980 Prindle 16
sethp001
Response Posted - 09/19/2016 :  21:24:57  Show Profile
And wow, Frank - the wood on the interior of your hull looks fantastic! What is it? How did you attach it?
Seth
dalelargent
Response Posted - 09/21/2016 :  12:07:00  Show Profile
Hi all,
Thanks for the quick replies...and sorry for my slow response. Work swept me away....
Yes, amazing wood panel in your quarter berth, Frank.
I think I will try the idea of pulling a screw from the other boat and see what was used. The difficulty is access as we are often at the lake at different times.
While I would love to mount the rack to a bulkhead, the cockpit bulkheads are already spoken for....and I want it to be very close to the cockpit as I intend to place charts/guidebooks in it. My 3 cruises in the San Juans annoyed me in those charts and books were always floating around the cockpit/cabin. I wanted them close at hand, but had no storage for them....
1983 Vagabond 14
Response Posted - 09/22/2016 :  17:59:03  Show Profile
The wood is the bulkhead from the quarter berth, the one separating the berth from the dumpster, I replaced it with A-B ply and put the teak on the hull liner with SHORT screws. (yes I had two bulkheads, I have had two 25s). The A-B ply I cut for my air-conditioner but that is another topic. Doubling the fiddle rails makes a great chart holder.
dalelargent
Response Posted - 09/23/2016 :  11:54:39  Show Profile
I don't have those fiddle rails in my 89. I have a flat piece of solid trim.
I suppose I could make a new (taller) one in a section....
1983 Vagabond 14
Response Posted - 09/23/2016 :  15:02:06  Show Profile
Originally posted by dalelargent
I don't have those fiddle rails in my 89. I have a flat piece of solid trim...
Your version might make the shelf wider.
Response Posted - 09/23/2016 :  18:05:17  Show Profile
I always wondered about that. I apparently have the same solid trim you do yet all I've ever seen on this site is the fiddles.
Association Member
Andiamo
'89 SR/WK #5862
Kemah,TX
Response Posted - 09/24/2016 :  15:54:32  Show Profile
I didn't either, the '89 used the teak "battens" instead of fiddle rail. Fiddle rails are common stock at lots of places.
Edited by - pastmember on 09/25/2016 07:08:10
Response Posted - 09/25/2016 :  11:44:59  Show Profile
Originally posted by pastmember
[quote]Originally posted by dalelargent
...Fiddle rails are common stock at lots of places.
I think suppliers call them "pin rails." A fiddle is whatever you put around the edge of a table, counter, or shelf to keep things from sliding off--a wood batten, plastic strip, brass rail, pin rail, or whatever (except when it's a part of a fiddle block.)
Edited by - Stinkpotter on 09/25/2016 11:57:51
