 Level?
Digger
Initially Posted - 01/06/2017 :  14:15:45  Show Profile
I am wondering about the correct level of my boat. The galley sink and the ice chest both hold a little water towards the stern. Does that mean the boat is sitting stern heavy, and if so, is that a problem of any significance? Should I move he center of gravity forward.
Steve Digby
1983 Catalina 25
Standard Rig
Fin Keel
Response Posted - 01/06/2017 :  15:17:38  Show Profile
Boats in the size range of the C25 are especially susceptible to that sort of thing, but even big 18,000 lb boats are affected by an imbalance in the boat. When 3-4 passengers are sitting in the cockpit while the boat is under sail, the boat will be oriented stern-down. If someone goes forward to use the head, the boat's orientation will change. Likewise, the boat's orientation is affected by the way you stow food and equipment.
Generally, a boat sails it's best on it's lines, but for ordinary cruising purposes, most people probably won't notice a difference in the boat's performance if it's off a bit. If you're a racer, you'll pay more attention to the boat's orientation, because it will affect the boat's performance slightly. In stronger winds, the boat sails better if it heels less. In light air, it sails better if it heels a bit, and if it is oriented slightly bow-down.
The best way to correct it is to move some storage around, or to move your crew weight around.
For ordinary cruising, I wouldn't pay much attention to it. Just enjoy sailing. If you're a racer, or enjoy maximizing boat performance, then you'll probably be more attentive to it.
Response Posted - 01/06/2017 :  16:20:26  Show Profile
To add to what Steve said, You want the boat to be slightly stern down for water to drain off the decks and so the cockpit will drain towards the scuppers. I also doubt Catalina was very concerned about getting the galley sink and Ice box dead on level
Edited by - islander on 01/06/2017 16:28:18
dalelargent
Response Posted - 01/06/2017 :  21:30:11  Show Profile
Well written Steve M!
1989 c25 WK/TR #5838
1998 Catalina 36 mkii
1983 Vagabond 14
Peregrine
Response Posted - 01/07/2017 :  00:06:29  Show Profile  Visit Peregrine's Homepage
I wouldn’t try to ascertain if your boat is sitting level by the sink or ice chest.
Take a look from the water both port/starboard and fore/aft. You boot stripe will help you with this.
I changed to a four stroke engine and heavier motor mount that changed the balance and I had to compensate for it.
Redistributing weight and/or eliminating weight is the easiest fix.
Distributing your crew correctly will be a big help when under sail.
IMO – This is not inconsequential, boats as small as ours will handle and sail much better if they are properly balanced.
Sailing a C-25 properly balanced vs. an imbalanced boat is night and day.
John Gisondi
Peregrine
#4762
Digger
Response Posted - 01/07/2017 :  00:51:43  Show Profile
Thanks for the replies. I replaced the 6 horse 2 stroke with a heavier 9.9 horse electric start 4 stroke and suspect that is the genesis of the balance issue. I hadn't thought about the trim issue related to light and heavy wind. Looks like I'll be shifting some of the weight forward. Although I have yet to race, I do concur with what a friend maintains, "If there are two sailboats on the water, there is a race going on."
Steve Digby
1983 Catalina 25
Standard Rig
Fin Keel
Response Posted - 01/07/2017 :  08:39:19  Show Profile
Don't judge anything by the icebox. On This Side Up the drainage hole was the highest point of the floor, as was the anchor locker.
Chief Measurer C25-250 2008
San Antonio, Texas
Response Posted - 01/08/2017 :  08:27:49  Show Profile
I noted that Passage sat lower in the stern than desired so I thought about what heavier storage items I could stow in the area under the vee berth? Maybe a spare anchor, water jugs for drinking and washing, tool boxes, etc. Then I noticed the head sink through hull fitting which stopped me dead in my tracks. What if an anchor slid down the space in heavy seas and whacked the heck out of the through hull fitting? Blub!?!?!
Response Posted - 01/08/2017 :  09:59:32  Show Profile
Well, You wouldn't have to worry about the balance anymore I remember some guys posting pictures of thru hull protection. Plastic boxes or a piece of large PVC pipe epoxyed to the hull.
