I have never had a boat with a "pop top". I have opened the one on our "new" C25 and it has made quite a racket and hit my head. My question would be," How do they stay Up?"
It pivots forward as you lift until the supports pass vertical and lowers against the mast. There is a bracket that slides in the mast slot to lock it in place. Some owners pass a line around the supports and mast for additional security. Do not sail with it up except in a virtual calm with flat water - essentially, don't sail with it up.
Dave B. aboard Pearl 1982 TR/SK/Trad. #3399 Lake Erie/Florida Panhandle
If you are coastal sailing, you do not want to consider converting to a pop-top. It would be expensive, too, lots of cabin-top cutting involved. I'm 5'7" tall, and we only raised our pop-top once in the 5 years we owned Recess.
DavidP 1975 C-22 SK #5459 "Shadowfax" Fleet 52 PO of 1984 C-25 SK/TR #4142 "Recess" Percy Priest Yacht Club, Hamilton Creek Marina, Nashville, TN
Victor the pop top sounds like a great idea but unless you plan on doing a lot of camping with the boat you really don't use it. I haven't had mine up in over 5 years.
My boat has a pop top and while I find it great for more head room and an increase in ventilation, I would never consider sailing with it up. However, you can see plenty of others doing so on youtube. Oh well. Here is a link to the pop top mast lock available from CD. Good sailing. http://www.catalinadirect.com/index.cfm/product/318_925/pop-top-mast-lock-assembly.cfm
Thankyou all for your comments and advice about the pop top conversion, based on them I will put many sailing hours on my shoulders before thinking about it once again; it helps that interior height is not a problem for the wife. Thanks.
Victor Salcedo 1978 C25. #453. FK. SR. L. CTYK0453M78C
Also, the conversion could be tricky... The factory model has a ridge molded into the cabin top around the pop-top opening, such that a lip around the edge of the pop-top goes down over the ridge, making it (theoretically) weather-proof and "green-water" resistant. I can report that it does resist green-water--I've had it come all the way over the cabin top into the cockpit.
Because the factory pop-top has inner and outer fiberglass moldings with a plywood core and the sliding companionway hatch, it's quite heavy. (The buyer of my boat hurt his back lifting it.) For that reason, CD offers a gas strut system to assist with maybe half the weight, and probably reduce some of the danger of an unexpected fall (which is why most folks here caution not to sail with it up). It is a hunk!
Dave Bristle PO of 1985 C-25 SR/FK #5032 Passage before going over to the Dark Side (2007-2025); now departed from Mystic, CT, and boatless for the first time since 1970.
I'd like to emphasize this recommendation. The hut on the mast that you tighten by hand to secure the top against the mast tends to vibrate loose. I can't believe I didn't break my neck the day I was standing under the pop-top when it fell on my head.
I like the pop top and I use it once or twice a season. It's nice to have. I would prefer, however, that the pop top was much better secured than two itty bitty dogs holding it down. I'd prefer something that would hold up in case of a capsize or a surprise squall.
My 1990 has 4 dogs. Was the earlier standard just 2 dogs?
That might answer a question for me. I had noticed that Catalina Direct says their gas strut assist mod is only compatible with 1988 and prior years. If it's just the two additional dogs that interfere with the pistons, I bet the dogs could be relocated. Is there a weight difference between the earlier and later pop-tops?
Kav Eldredge 1990 TR/WK #6001 "Ocean Liner" Birmingham, AL
...Catalina Direct says their gas strut assist mod is only compatible with 1988 and prior years. If it's just the two additional dogs that interfere with the pistons, I bet the dogs could be relocated. Is there a weight difference between the earlier and later pop-tops?
Two questions CD could probably answer. There are maybe a couple of people here who've had both a pre-89 and a post-88.
2 dogs or 4 Hmm. My 87 has 2. CD recommends to add 2 more towards the front if having 2 bothers you. I guess Catalina put 4 on in the final years? If I was crossing an ocean I would add 2 more but my top hasn't ever accidentally opened in the past 30yrs and like a keel falling off I've never heard of it happening to anybody else so I think I'll leave it with 2. Seth, That's funny that yours has 3 and mine has 2 since mine was built after yours. Another mystery!
Is the one that is centered on the forward edge a scalp scraper?
That would be the track for the folding door to the head.
I like my poptop for camper sailing. I have the tent cover too, great addition. Last year we went on an 8 day trip, staying in CA Delta marinas. 6 at night, 7 sailing during day.
At 6'4" I can't live without the pop-top. In mild conditions I always sail with it up! When the wind picks up, I immediately drop it. I find it not very heavy, since I am strong as an ox.
For safety considerations, since there are so many factors in all the situations one finds oneself, the use of the pop-top while under sail or motoring is merely a small part of the whole. If you think the C25 pop-top is a tedious inconvenience that requires inordinate strength to raise, secure, or lower, then I recommend never bothering with it. I added a wing nut over the circular nut that secures the pop-top slider, and it always stays in place.
In my opinion, knowing the weather forecast, observing the changing weather patterns, knowing the sailing venue, knowing the status of all your boat's equipment, wearing PFDs, knowing the traffic patterns on the water, knowing your own and your crew's limitations in handling the boat, and calculating the associated risks with all these factors makes your sailing adventure as safe as it can be!
For example, my friend and I sailed back on a beam reach and a broad reach from Block Island in pleasant 5' swells and 5-7 kt breezes to the Narragansett Bay in his 1980 C25 the week before last. We had the pop-top up. We were aware of all those factors and had a very nice time. With a new inflatable dinghy in tow we were safer than without it. I think the main risks we ran were encountering a 10' rogue wave on top of those swells, or perhaps a nuclear submarine surfacing underneath our boat. In such cases we were prepared to step up into the dinghy.
There are so many pleasures in sailing, like good company and the sights and sounds and smells on the water, and having sufficient headroom to move about the cabin safely is certainly one of them in my experience. I would like to have a big boat with lots of space, but the C25 with a pop-top fits my needs perfectly for the moment.
I do not recommend anyone else sailing with the pop-top up, however.
Fair winds and smooth sailing!
JohnP 1978 C25 SR/FK "Gypsy" Mill Creek off the Magothy River, Chesapeake Bay Port Captain, northern Chesapeake Bay
The support legs on the 89 and 90 are shorter than the early models, the lift kit will not work on them, been there tried that.
