 Cleaning up the Teak finishes in the Cabin
drakej
Initially Posted - 07/19/2017 :  16:20:29  Show Profile
Has anyone refurbished the interior teak on their 250? If so do you have any suggestion on technique and products to use.
Drake Johnson
Andiamo
'02 Catalina 250WB #654
Folsom Lake, CA
Response Posted - 07/20/2017 :  03:17:00  Show Profile  Visit OLarryR's Homepage
I use Howard's Restore-A-Finish and then for infrequent periodic maintenance (ie. after 2yrs), I use Howard's Feed-N-Wax.The Restore-A-Finish is a simple wipe on, wipe off action. Same goes for the Feed-N-Wax.
Larry
Peregrine
Response Posted - 07/20/2017 :  07:16:59  Show Profile  Visit Peregrine's Homepage
I also use Howard's but use exterior Cetol on the companionway steps because of the abuse they take.
John Gisondi
Peregrine
#4762
Response Posted - 07/20/2017 :  15:49:33  Show Profile
I second John's suggestion on Cetol for the stairs due to the tough use. If you're concerned about slips, add an adhesive backed sandpaper tread.
Response Posted - 07/20/2017 :  16:13:29  Show Profile
It's Howard's for me also but I use tung oil on the steps that holds up very well and is as easy to apply as Howard's. I recommend the 1inch traction strips also. Peel and stick easy.
Edited by - islander on 07/20/2017 16:16:33
Response Posted - 07/20/2017 :  18:48:35  Show Profile
I use Cetol for trim, hand rails, etc., but consider it to be too soft for something like steps. I'd stick with oil (which penetrates and brings out some color), or if you want a surface finish that will take some abuse, a satin polyurethane or varnish. Non-skid tape or treads are also good ideas--you can't be too safe with steps on a boat.
Howard's gives a nice natural look, while tung oil, with a few coats, will build up to a satin finish.
Edited by - Stinkpotter on 07/20/2017 18:52:47
Response Posted - 07/21/2017 :  03:26:01  Show Profile  Visit OLarryR's Homepage
For now, I have been using the teak oil on the steps.
I use to use Cetol on exterior trim. However, a year or so ago, I started on the companionway boards and adjacent exterior trim, stripping all varnish off, applying teak oil and then utilizing a Sunbrella cover I made up snapping it onto the existing snaps that are on perimeter of the companionway exterior trim. It's now been over a year and I have re-applied teak oil a few times (with no cleanup or real prep required and so a quick 1/2 hr application) and have been satisfied with the results. With my sister's sewing assistance, I finished covers for the rest of the exterior trim this past Spring but have not started stripping varnish off yet...will wait till the fall/winter to continue that project.
I like the teak oil finish but without covers, I found years ago that the teak finish would eventually have to be bleached out before reapplying teak oil - The sun UVs were just too much for the teak oil to last a season. Now with the covers, the teak oil holds up fine and any re-applications do not have to have any prep work beforehand. A companionway cover is no big deal to remove and button up each time but.....covering the rest of the exterior wood is a semi-pain and so I have mixed feeling regarding staying with Cetol versus going with the teak oil...but I am going to give the teak oil a try. I probably will replace the long thin exterior wood trim piece, believe it over 100" long) with plastic. I think Catalina Direct sells the replacement.
Larry
sethp001
Mainsheet C-25 Tech Editor
Response Posted - 07/21/2017 :  18:12:59  Show Profile
Didn't the 250s come with a satin varnish from the factory?
Seth
"Nomad" 1980 Prindle 16
drakej
Response Posted - 07/25/2017 :  12:02:46  Show Profile
Thanks to all for sharing. I'll let you know how it goes.
Drake Johnson
Andiamo
Folsom Lake, CA
drakej
Response Posted - 07/25/2017 :  12:05:33  Show Profile
I don't know. I posed the same question to Catalina and have not received a response.
Drake Johnson
Andiamo
Folsom Lake, CA
Response Posted - 08/01/2017 :  19:29:23  Show Profile
Ha, another Andiamo owner!
Association Member
Andiamo
'89 SR/WK #5862
Kemah,TX
