As I prepare for a series of winter repairs I have noticed a small separation of the liner above the aft starboard window. It's really a pucker about 6 inches long and has pulled away by about 3/4". I think I'll need to remove the window to do the repair,
John, Taking the windows out of a C-25 is a piece of cake. Just remove the screws from the frame on the inside, lift the bezel off and gently push the window out of the hole cut in the side of the cabin. You should be able to access your problem pretty
I would be very curious to find out what has made the liner seperate from the hull. Heat might work but dont forget this is a resin/fiberglass and once set is fairly solid so be carefull.
