 Shroud Rollers
vdotmatrix
Initially Posted - 09/05/2017 :  15:10:31  Show Profile
Now that I figured out the name for these, I cant find any except from the UK. everyone has them them on the shrouds and cap shrouds to protect the jib sheets from abrasion on the shrouds....We are in Alexandria, VA...where can I get these?
Response Posted - 09/05/2017 :  16:34:50  Show Profile
I have no idea what the quality is but here's a few links
http://www.bete-fleming.com/rigging.htm
http://www.allspars.co.uk/shroud_roller.html
https://www.jimmygreen.co.uk/item/57323/shroud-rollers
Seems they're popular in the UK. Maybe some foam noodles might work?
TEM58
Response Posted - 09/05/2017 :  16:55:30  Show Profile
A couple of additional options:
http://search.defender.com/?expression=shroud%20rollers&s=1&Trigger=ac
http://www.defender.com/product3.jsp?path=-1%7C118%7C2358491%7C2358503&id=75009
Tim M
“Perfect Match II”
2003 C350 #35
Cruising FL
PO "Wine Down"
2000 C250 WK #453
PO "Perfect Match"
1983 C25 SR/SK #3932
Lake Belton
Belton, TX
Response Posted - 09/05/2017 :  17:43:18  Show Profile
How big is your genoa? With the swept back spreaders and no forward lowers, it takes a pretty big one to actually reach them. Most C250s I have seen have rubber spreader tips, but not rollers.
Edited by - TakeFive on 09/05/2017 18:00:21
Response Posted - 09/05/2017 :  17:44:37  Show Profile
If your handy they are easily made out of PVC pipe, Two PVC caps and a nylon washer.
Response Posted - 09/06/2017 :  08:31:24  Show Profile
Scott - what size PVC pipe, 1"?
Response Posted - 09/06/2017 :  09:40:19  Show Profile
Bruce it was 1" or 1 1/4. I can measure them if you want. You will have to remove the turnbucle on the forward lowers, Not a big deal just count the turns. Drill a hole in the center of the two caps that is slightly larger than the swaging on the end of the shroud. Drill the nylon washer out so it is slightly larger that the threads on the swaging. Slide 1 cap onto the shroud then the pipe then the other cap and finally the washer. Re-assemble the turnbuckle. The washer will sit on top of the turnbuckle giving the pipe a flat smooth surface to rotate on. You can glue the caps to the pipe if needed. I made mine 7 yrs ago and I would say they are better than any that you can buy.
Response Posted - 09/06/2017 :  10:32:52  Show Profile
Scott, as usual, your fabrication abilities are top notch! Like everything on Impulse.
vdotmatrix
Response Posted - 09/07/2017 :  13:04:50  Show Profile
OUTSTANDING! Love it
I would say probably 1", probably all I would need.....keeping count of the turns is the only issue I can see.
Edited by - vdotmatrix on 09/07/2017 13:07:05
Response Posted - 09/12/2017 :  08:41:53  Show Profile
I checked and I used 1" That gives you an outside diameter of @ 1 5/8"
