 Swim ladder-no latch?
Sublime
Initially Posted - 11/03/2017 :  09:27:24  Show Profile
I just bought a '77 Catalina 25. It has a swim ladder but I don't see anything that keeps the swim ladder from falling down and dragging in the water. Is there something more suave than just lashing it down with rope?
***This post is made of recycled electrons
Response Posted - 11/03/2017 :  14:20:59  Show Profile
There isn't any latch. I use a small velcro strap that is strapped around the ladder and the upright stanchion. Just make sure what ever you use it is low enough that you can get to it from the water. In case you fall in that is. Blue strap in the photo. WM has them for a buck or so.
dalelargent
Response Posted - 11/03/2017 :  16:47:36  Show Profile
Similar to Scott, I use a ball bungee. I have it permanently on the pushpit stanchion with a lark’s head hitch, then wraps around the ladder when in the upright position.
1989 c25 WK/TR #5838
1998 Catalina 36 mkii
1983 Vagabond 14
Response Posted - 11/03/2017 :  18:24:49  Show Profile
Velcro and bungee - God's gift (along with duct tape) to convenience!
Peter Bigelow
Rowayton, Ct
Response Posted - 11/03/2017 :  18:47:07  Show Profile
I use a piece of 1/8" line that is fixed to the ladder, is wrapped around the stanchion and loops down into the water where I can yank on it if I'm in the water. I'd like to be able to rescue myself if I fall in.
Response Posted - 11/03/2017 :  21:28:29  Show Profile
I have a long piece of velcro tied to the stanchion and around the top of the ladder that makes a loop and is released by a cord hanging down to the waterline.
1978 C25 SR/FK "Gypsy"
Sublime
Response Posted - 11/04/2017 :  22:43:03  Show Profile
Well alrighty. Velcro sounds like a great option then. I think the PO just let it drag in the water. I have some cleaning to do. :/
Response Posted - 11/05/2017 :  08:13:50  Show Profile
Mine had just enough friction and tilted just enough toward the rail that it hardly ever (if ever) fell into the water. I figured the easier it was to pull down from water level, the better.
Lee Panza
Response Posted - 11/05/2017 :  09:07:57  Show Profile  Visit Lee Panza's Homepage
I keep a throw-line bag hanging from the pushpit rail and I slide it over to the raised ladder, drooping it over a rung. It flops out of the way easily when the ladder is pulled-down, but it provides enough resistance to retain the ladder upright otherwise. Plus, it's always readily available for emergency use. The one I have hangs from the rail by a strap with a quick-release clip. Similar to:
https://www.westmarine.com/buy/west-marine--throw-ropes--P008_242_003_503?recordNum=12
Generally, I think if I ever needed to deploy the throw-bag I'd want to lower the ladder anyway. But I strongly support allowing the ladder to be easily lowered from in the water - even at the dock: I'm more likely to fall overboard at the dock, when I'm doing maintenance, and if I land on the wet side I'd be hard-pressed to climb onto the dock.
Lee Panza
SR/SK #2134
San Francisco Bay
(Brisbane, CA)
Response Posted - 11/06/2017 :  11:45:28  Show Profile
Lee, A few years ago my Marina installed multiple aluminum pull down ladders on the docks. Good idea but I'm not sure if insurance or some regulation was behind it.
Response Posted - 11/06/2017 :  19:39:48  Show Profile
I wish our City Dock had installed those ladders. This summer I was stepping up onto the dock when my kayak slid underneath the dock and I wound up in the drink! The docks are all about 12" off the water with nothing, not a line, not a board or a rung to get a foothold on to get out of the water. I called for help and a 16 year old kid (bless his heart) who must've weighed 99 pounds ran over and reached down to pull me out. I was afraid we'd have both gone in the water.
Luckily a jet skier helped me up onto his stern and got me back onto the dock. In all the confusion I seem to have snapped a lower rib (ouch).
I visited the marina office later that day and we discussed what they should do to prevent that happening again. I advised all they need is attach a loop of line to most of the dock cleats and you can readily step into the loop and pull yourself up. The next week the dock hands strung them up as a temporary measure, I hope they'll request funding for half a dozen boarding ladders in 2018.
Response Posted - 11/07/2017 :  04:29:38  Show Profile  Visit OLarryR's Homepage
My marina also installed those swing up aluminum ladders at the end of some of the finger slips.
The PO had a Velcro strap to hold the ladder against the top of the transom rail. I removed it and hooked up a piece of starboard clamped onto the ladder support about 8-12" away from the ladder swing support. I initially installed a wedge cleat onto the piece of starboard and then attached one end of a line to the base of the transom rail support and then thru the wedge cleat. The line would loosen over time utilizing the wedge cleat and so I eventually replaced it with a small cam cleat. The line is held firmly by the cam cleat and then drops down to a point above the waterline and then loops back up and it's end also attached to the base of the transom support rail.
Larry
sethp001
Mainsheet C-25 Tech Editor
Response Posted - 11/13/2017 :  17:49:49  Show Profile
Scott, your boat looks fantastic!
Seth
"Nomad" 1980 Prindle 16
Response Posted - 11/13/2017 :  18:29:43  Show Profile
Thanks Seth though I give a lot of credit to my PO's. It was well cared for.
