 Guiding posts on trailer
dmarion
Initially Posted - 01/05/2018 :  08:06:59  Show Profile
Hauling the boat onto the trailer can be a very frustrating experience, epecially when the wind blows it sideways.
Has anyone installed guiding posts on the trailer so that they keep the boat straight during the manoeuver?
Thank you and Happy Sailing to everyone for this new year!!
Daniel Marion
Zendo
Cat 250 WB 2001 Hull #592
Valleyfield, QC,
zeil
Response Posted - 01/05/2018 :  10:06:33  Show Profile
These guides are very helpful loading the boat.
Henk & Johanna
dmarion
Response Posted - 01/05/2018 :  11:55:41  Show Profile
They look great! Did you make them yourself?
Daniel Marion
Zendo
Valleyfield, QC,
zeil
Response Posted - 01/06/2018 :  10:31:18  Show Profile
The sturdy and flexible guide posts came with trailer.
Henk & Johanna
Edited by - zeil on 01/06/2018 10:32:50
dmarion
Response Posted - 01/06/2018 :  12:57:40  Show Profile
I will have to have them manufactured. But it's ok.
Daniel Marion
Zendo
Valleyfield, QC,
Response Posted - 01/07/2018 :  11:38:45  Show Profile
On Amazon, enter "boat trailer guides" and sit back... Want 'em with LED lights on top? How about foam pads with canvas covers?...
Response Posted - 01/07/2018 :  11:55:23  Show Profile
Be careful, Many of the guides are just that, A visual guide when the trailer is submerged and are just PVC pipe. They are not intended to take much sideward force.
Response Posted - 01/07/2018 :  12:11:55  Show Profile
Ya, that inward angle of the bottom half of Henk's guides is probably intended to strengthen them against sideways pressure--almost like knee-braces but with a little more "give". A 5000+ lb. sailboat, mast up in a cross-wind, could push pretty hard on a post like that.
dmarion
Response Posted - 01/07/2018 :  12:17:02  Show Profile
You are correct. I am looking more at posts that will keep the boat straight than only be for guiding. I found a trailer manufacturer not far from my place that will probably be able to fit my trailer with sturdy posts. I will post pictures when it will be done in the spring. If I can find my boat under the snow...
Daniel Marion
Zendo
Valleyfield, QC,
Response Posted - 01/07/2018 :  17:24:49  Show Profile
The guides that Henk showed in his photo are Fultons I would guess. Don't know if they are steel lined though. See them here. https://m.overtons.com/modperl/product/details.cgi?pdesc=Fulton-50-Boat-Guides-pair&i=317300#reviewsInfo
Edited by - islander on 01/07/2018 17:27:00
Response Posted - 01/07/2018 :  21:16:25  Show Profile
Looks like them... Looking at that pic, I'm thinking the reason for the inward angle might be to make it more likely the guide will contact the rub-rail rather than the hull--a worthwhile idea.
Response Posted - 01/08/2018 :  11:04:05  Show Profile
I have had the curved Fulton guides on my C-22 trailer for many years. The curved design is to add strength, and they do not have metal rods inside the PVC pipe.They work very well. Positioning them aft of the widest point of your boat's beam is a good idea. You do not want your hull touching them while traveling as they will fub and damage the gel coat. With a tandem axle trailer, you will want them aft of the wheels which will negate the problem I mentioned. On my single axle C-22 trailer I originally placed them in front of the wheel well where the widest part of the hull was. Bad idea! Now they are behind the wheels.
DavidP
Edited by - dmpilc on 01/08/2018 11:07:48
zeil
Response Posted - 01/10/2018 :  15:42:35  Show Profile
With the trailer submerged out of sight in often murky water the guides clearly show the location of the boat in relation to the trailer. I fact the boat can be hand-held in place while the truck and trailer move forward while settling the boat on the trailer.
We usually stop on the ramp and still partly in the water with the boat just touching the bunks and hand-crank the boat further forward.
Henk & Johanna
dmarion
Response Posted - 01/11/2018 :  06:22:20  Show Profile
Thanks for your comments and suggestions. I will let you know the outcome.
Daniel Marion
Zendo
Valleyfield, QC,
