 Fittings for seacock drainage on hull
vdotmatrix
Initially Posted - 02/24/2018 :  06:35:31  Show Profile
Hi,
Does anyone know what the white plastic fittings for the seacock above the waterline are called?
Response Posted - 02/24/2018 :  08:03:24  Show Profile
Search terms would be through-hull, thru-hull, or mushroom head. That latter may generate some incorrect hits.
https://www.westmarine.com/buy/forespar--marelon-mushroom-heads-barbed--P011_332_002_513?recordNum=3
vdotmatrix
Response Posted - 04/04/2018 :  20:38:11  Show Profile
THANK YOU!!!! Thank you so much for your help......
Response Posted - 04/04/2018 :  20:52:17  Show Profile
Here's the story of how/why I knew the answer: I had bought the very item that I linked on sale for $1 at a Kmart end-of-season sale 20 years ago. I had planned to put it in the transom of my fishing boat as a bilge pump outlet. Ultimately I just ran the bilge pump hose over the transom, and the item sat in my workbench for 20 years.
When I bought my C34 18 months ago, the air conditioner outlet through-hull was noted in the survey as needing replacement due to severe UV degradation. It was the exact same part I had sitting in my workbench.
Moral of the story: Don't ever throw anything away. (Just hope you can find it when you need it.)
My ultimate goal is to find a use for every single piece of stuff that I have sitting around that I never got around to using. Then I can die peacefully. lol
Edited by - TakeFive on 04/04/2018 20:53:48
