I just purchased a 1978 Catalina 25 and want to make the interior look nice. My plan is to use Interlux Interstain and then varnish with Pettit 1015. I am going to remove all the wood trim and sand it down then stain and varnish. Also, looking to replace the existing veneer with a mahogany veneer. Just wondering if anybody has any tips on what to look out for and if its worth doing.
When you say,"veneer" are you saying you want to replace the counter tops...? I made new counter tops and covered them with formica. Same as most folks have at home on their kitchen counters.
Okay, So we are talking about the bulk heads. I don't think you will have much luck with replacing the veneer. Not that you can't try. I have a lot of wood working experience and my choice was to remove the old bulk heads and make new replacements. Here is a pic of the old ones and of the new ones. I also replaced the partition between the stove area of the galley and the dinette area as well as the small bulk head behind the galley sink. Good luck with your choice and let us know how it goes.
Note that "Blade" (Guy) hadn't yet remounted the chainplates in the second photo, which raises a point: If you buy new veneered plywood, make sure the underlying plywood is good quality--no voids--since it will be supporting your rig. Marine and cabinet-grade plywood satisfy that criterion. Then don't over-tighten the chainplate bolts--you don't want to crush the wood.
The original veneer is teak, as is the trim around the interior. Mahogany can be a perfectly good substitute, and there might be a stain like light cherry that would help match it to teak without darkening it too much.
A number of folks here have removed the bulkheads and used them as patterns for cutting new ones--it's apparently not difficult surgery (although I can't speak from experience). It's also an opportunity to check the condition of the compression post under the mast, against the port bulkhead.
Dave Bristle PO of 1985 C-25 SR/FK #5032 Passage before going over to the Dark Side (2007-2025); now departed from Mystic, CT, and boatless for the first time since 1970.
Good eye Dave, you're right, I had not yet reinstalled the chain plates. And yeah, I was careful to not over tighten them. It wasn't particularly hard to get them out and yes, I just used the old ones as a pattern for the new ones. Before taking them out, I had wrongly assumed they would be 3/4". As it turned out, they are only 1/2". When I went to buy the material, All I could find in half inch, (or any other size) was finished one side only. So it was necessary for me to buy 2 sheets of 1/4" and laminate them up to 1/2" myself. Thereby getting 2 finished sides. And Dave is very right again about marine grade plywood. For any plywood use on a boat, only marine grade plywood should be used. And even then, always be sure to seal not only the flats but especially the edges. I seal everything with resin and still inspect on a regular basis.
I used Restore-a-Finish for 20 years. Very easy to apply. Looks very nice and smells great!
Derek Crawford Chief Measurer C25-250 2008 Previous owner of "This Side UP" 1981 C-25 TR/FK #2262 Used to have an '89 C22 #9483, "Downsized" San Antonio, Texas
Thanks for all the info. I thought about it and am going clean the teak trim pieces. For the veneer bulkhead I was thinking of just painting over them. Maybe light blue to brighten it up a bit. Just hope its not a sin to paint over it!!!
...For the veneer bulkhead I was thinking of just painting over them. Maybe light blue to brighten it up a bit. Just hope its not a sin to paint over it!!!
How about trying a teak cleaner/brightener first, and see what that looks like? You can always paint it... Unpainting it is another matter.
I used teak cleaner and then used Pledge Orange Oil polish. I looked nice with little work and mold and mildew hate orange oil. Little work means more time on the water.
Mike
Mike Roetter '83 C25 #3568 SK/SR Marblehead on Lake Erie
