 Catalina 250 burner cover/ cutting board
jefferydfloyd
Initially Posted - 04/23/2018 :  13:34:45  Show Profile  Visit jefferydfloyd's Homepage
My son took the burner cover/ cutting board that was on our boat from the previous owner and CNC'd the Catalina 250 logo on it.
After a couple of coats of epoxy
After polish/ wax
Installed in our galley
Jeff Floyd
Response Posted - 04/23/2018 :  14:54:07  Show Profile
Looks great! I hope your epoxy is formulated for good UV resistance. If not, even modest amounts of UV (which will come in through the windows) may cause pretty bad yellowing and possibly cracking/delamination. If so, this could be prevented with an overcoat of spar varnish (or polyurethane) that's formulated to adhere and protect against UV.
Russ.Johnson
Commodore
Response Posted - 04/23/2018 :  20:52:12  Show Profile
Jeff,
That’s a nice project.
Over the years, Catalina had several versions of stoves.
Earlier models had Propane stoves behind the sink, the “Princess” stove.
It looks like you have a Butane stove, which is from a later year.
I would guess your hull is over 800 and after 2005.
Russ Johnson
2005 C250WB Hull 793
Edited by - Russ.Johnson on 04/23/2018 20:53:43
jefferydfloyd
Response Posted - 04/24/2018 :  07:56:25  Show Profile  Visit jefferydfloyd's Homepage
Originally posted by Russ.Johnson
Jeff,
Right on all counts... Butane stove, Hull # 811, 2005 !
Jeff Floyd
