I'm preparing a backing plate while Garhauer rebuilds my old mount. There was no backing plate previously, just 1" washers on the 4 bolts. I cut a piece of 3/4" exterior plywood (about 12" x 9") and put on a coat of thined satin varnish. I decided to do a trial fit before I put more coats on. But it seems the inside of the transom is not perfectly flat, as the board wobbles a little (maybe 1/8") when placed back there (starboard quarterberth). The board wobbles the same when I turned the board over. The transom appears dry and solid.
I installed a backer, but don't recall if the liner in that area was perfectly flat or not. I'd suggest using a belt sander to remove material from the high spot until it quits rocking. When you tighten the bolts it should draw down some anyway. I also coated the inside of the bolt holes with epoxy to seal the ply there. I bedded the thing with lots of polysulphide caulk and used large SS fender washers under the nuts on the inside. So far, so good.
Richard: Because the transom is not flat--particularly inside--a very stiff backer can put more stress on the liner than no backer. As you tighen the mounting bolts, all of the pressure may be applied to the liner at the corners of the backer. I suggest:
1. Split the backer so the halves can conform better to the curve.
2. Round each corner to a 2" radius curve to reduce point pressure at the corners.
3. ALthough you've already made the inside backer, I'd suggest a thinner material, such as 1/2" or 3/8" plywood to allow some bend. 3/4" is actually too strong, and can damage the fiberglass instead of spreading the load.
4. Add a 1/2" Starboard backer to the outside of the transom to distribute the load of the bracket base. On our boat, the bottom of the PO's bracket was digging into the fiberglass on the outside of the transom.
