 Has anyone put a loos gauge on their shrouds?
Sublime
Initially Posted - 07/20/2018 :  13:47:49  Show Profile
“A 50 lb push should deflect the upper by 1 inch” is pretty useless for me. If anyone has converted this to a measurement on a loos gauge, I’d be highly appreciative!
***This post is made of recycled electrons
Response Posted - 07/20/2018 :  19:46:46  Show Profile
As I recall, the loos gauge instructions tell you what the readings should be for the various sizes of wire.
Peregrine
Response Posted - 07/21/2018 :  05:43:02  Show Profile  Visit Peregrine's Homepage
This might help.
http://www.theannemarie.com/Loos-Gauge-manual.pdf
John Gisondi
Peregrine
#4762
jduck00
Response Posted - 07/21/2018 :  07:01:47  Show Profile
Yes, I keep two on the boat for mast tuning. There's not a single gauge that I know of that will get all of the rigging on our boats. I pull mine down to about 15% using the guide in the tech tips. Always works out nicely. http://www.catalina-capri-25s.org/tech/tech25/snkmast.asp
Jeremy Duck
The Lucky Duck
1980 SKSR Hull # 1850
Response Posted - 07/21/2018 :  07:52:49  Show Profile
I guess that I'm the odd one here, I used just the small Loos gauge on all the shrouds without a problem. I kept a very loose rig and did not bother to convert the front gauge readings to the poundage on the back.
I kept the aft lowers at 20, the uppers at 30 and the forward lowers at 25. Probably too loose for most but great for a hard core racer...
Chief Measurer C25-250 2008
San Antonio, Texas
Sublime
Response Posted - 07/22/2018 :  00:05:27  Show Profile
So that's around 600 lbs?
I've got two loos gauges. One is for smaller rigging. The other is for larger rigging lol! So I'm trying to figure out what reading would be on what I have.
Sublime
Response Posted - 07/22/2018 :  00:11:51  Show Profile
Originally posted by Peregrine
This might help.
Good info! I'm struggling with some sail shape and I think it's the tuning on my rig. This is my first go with a masthead rig so I'm learning.
JB
Response Posted - 07/23/2018 :  08:28:00  Show Profile
We only use the gauge to even up the tension after setting it while sailing on various points of sail. When we take the mast down we mark the toggles with tape so that adjustments are minor. We try to run as loose a possible without too much slack on the lee side.
1988 C25 Wing Keel Std Rig Tohatsu 9.9 Tiller Steering and 2003 C250 Wing Keel Std Rig Inboard Diesel Wheel Steering
Response Posted - 07/23/2018 :  10:43:29  Show Profile
You can find articles on how to tune your rig in our tech tips section. A loos gauge doesn't tell you how to tune the rig. As JB said, it only helps you make the tensions uniform and consistent.
Also, tuning the rig makes the rig erect, straight and resistant to the loads imposed on it, and makes the boat perform equally well on either tack. It balances the CE of the sails against the CLR of the keel. An imbalance causes a heavy helm or inadequate weather helm.
Tuning the rig has only an incidental effect on sail shape. If you'll describe the problems you're having with sail shape, we might be able to offer some suggestions.
Sublime
Response Posted - 08/21/2018 :  21:28:50  Show Profile
Thanks for the explanation.
I'm aware that a loos gauge doesn't tell you how to tune your rig.
My experience has been that the rigging can have quite a profound effect on sail shape.
I was simply pulling some bagginess out of my sail and it looks much better after making some adjustments. With the loos gauge, I know I'm within a recommended working load for the shrouds which makes me sleep good. I tend to like a tighter rig but I don't want to go by plucking sounds and such. I generally set it to a starting point, see how it sails. The loos gauge lets me make accurate and consistent adjustments if I feel it needs it.
All I was looking for was a consensus on an actual number for the range of tension most are having luck with. Because I'm lazy.
Response Posted - 08/22/2018 :  04:47:35  Show Profile
I have the Loose guages and they are helpful in letting you know precisely how much tension you have on the wires. Plucking or pushing is just a feel and can be very different between different people.They also let you know that the tension is the same on both sides and that you haven't over tensioned any wires that is easy to do. Anyway I used the method suggested on the forum and used the guages to check and adjust.
Response Posted - 08/22/2018 :  18:08:26  Show Profile
It is not properly sized for the forestay, backstay and the upper shrouds, but I've found that the gauge is most useful in determining if opposing cables are of the same (or nearly) tension.
Jerry
AlMo
Response Posted - 05/09/2019 :  10:35:58  Show Profile
Anybody have advice on using a roller furler (adds 30-35 lbs to the forestay) and a good bit of wind drag, and how that would affect tuning recommendations? A new jib plus a fairly old main would suggest to me based on reading http://www.catalina-capri-25s.org/tech/tech25/snkmast.asp that I would want forward rake, just wondering how much the furler luff weight may affect the amount of forward rake I would start with. The article represents mast tuning as an iterative, "feel-based" art, and I get that, just looking for any advice from C25 owners that do their own tuning. Thanks!
1978 C25 "X Lives" #1035
SR/SK
Response Posted - 05/09/2019 :  13:39:10  Show Profile
There is very little difference between tuning a rig with or without a furler. Here's an answer that I gave to that question previously:
"The general purposes of rig tuning are: (1) To firm up the rig so that it supports the sails so that you can shape the sails correctly. (If, for example, the forestay is too loose, the sail can't be depowered enough in strong winds, and the sail won't present a clean entry to the wind, enabling the boat to point well.) (2) To adjust the center of effort of the sailplan so that the amount of force exerted on the sails forward of the center of lateral resistance are balanced properly against the amount of force exerted on the sails aft of the center of lateral resistance, so that the boat has just the ideal amount of weather helm without causing the rudder to produce excess drag to hold the boat on course.
Those goals of rig tuning are exactly the same, regardless of whether or not the boat has a furler, or whether it has a backstay adjuster.
The only difference in tuning a rig with a furler is that you should leave the forestay tension about 1/2 turn of the turnbuckle looser. The reason is that, if the forestay is too taut, it can impede the ability of the furler to turn freely, especially if it doesn't have ball bearings, preventing it from working smoothly and wearing it out prematurely. The forestay should be as taut as it can be while still allowing the furler to turn freely."
The mast should never have a forward rake on any boat. If it is raked at all, it should be raked aft slightly. If a mast is raked forward, the boat will have lee helm. By tilting it aft slightly, you create weather helm. The farther aft you tilt it, the more weather helm.
Too much weather helm is bad. It pulls so hard at the tiller that you become arm-weary just to hold the boat on course. Too little is equally bad. If you let go of the tiller, the boat will keep sailing on an erratic course. With the correct amount of weather helm, if you let go of the tiller, the boat will come into the wind, the sails will luff, and the boat will stop.
That impression is understandable, but not entirely correct. The rig is the structure on which your sails are hung. The way that it is adjusted has a lot to do with the way your sails are shaped. It also has a lot to do with the way your entire sailplan is balanced. Those matters have nothing to do with "feel." They relate to aerodynamics. Where "feel" comes into play is in determining the amount of weather helm that is comfortable to you and that accomplishes your goals for the boat.
Edited by - Steve Milby on 05/09/2019 13:43:48
AlMo
Response Posted - 05/10/2019 :  09:05:42  Show Profile
Great info, Steve!!! Think you hit the nail on the head in many respects, and I'm on the way to the boatyard to get that thing tuned and in the water today. I will take your advice on the forestay tension impeding furler smoothness, as well as putting a small bit of aft rake to aid weather helm. Thank you for the thoughtful and helpful reply!
SR/SK
Response Posted - 05/10/2019 :  13:26:32  Show Profile
Steve I think you mean tensioning the luff of the sail too much puts a strain on the swivel and would impede it's ability to rotate. The RF only rotates on the forstay so forstay tension really has no effect on it. Also the majority of the weight of a RF is supported by the drum.
Response Posted - 05/11/2019 :  01:26:16  Show Profile
You're right. I forgot that.
