 Sailpro 6hp
Response Posted - 03/12/2019 :  06:34:33  Show Profile
Mine came by FedEx to my door. Comes in a carboard box. He off loaded it and I used a hand truck to my garage. You have to be home for it. Needs a signature. Not difficult. They give you tracking so you'll know what day.
Edited by - islander on 03/12/2019 06:39:52
Response Posted - 03/12/2019 :  13:32:47  Show Profile
Originally posted by bear
OK, pretty much decided on 8HP Tohatsu motor with electric start...
...and no 25" shaft?
Response Posted - 03/14/2019 :  12:19:28  Show Profile
Not much choice anymore for an 8hp 25" shaft. Only Honda still offers it but it is very pricey. Tohatsu dropping the 25" shaft on their 8 and 9.8 leaves the 9.9hp models as the go to for a 25" shaft. Heck, Most don't even have an 8hp in their lineup.
Edited by - islander on 03/14/2019 12:20:54
Boomeroo
Australia
Response Posted - 03/17/2019 :  11:27:58  Show Profile
So much comment but some facts missing .
1 speed thru the water is the important item ,and current slows down a boats speed (over ground) independant of motor size.
A 4 hp will get the boat to hull speed as will a 6 hp or a 9.9 etc the difference will be in engine revs and torque curve position . A high thrust large propellor will have more thrust so maintain speed in waves etc . Basically accelerate the boat to maintain speed .bigger the motor the bigger the propellor the lower revs needed.
I used a 3 hp once on dead flat water and expected a slow trip. After about 5 minutes i noticed the speed was up near 5 knots but the motor was working hard and acceleration very slow when it hit a small wave .
My 9.9 hp digs a hole bow up stern down indicating trying to go over natural hull speed if i get to 3/4 throttle in flat water .
A 6 hp is fine unless climbing mountains ie ocean swell and large waves which slow the boat requiring more totque .
Side mount means you need a 25 inch to motor sail on bothe tacks effectively.
Graeme Bishop boomeroo Australia
C25 SK
