 Bilge vents
Initially Posted - 03/16/2019 :  09:51:30  Show Profile
I have a bilge problem on Passage, mostly related to a trickle of rainwater coming in through various cracks, crevices, and stanchion bases. I occasionally get a few cups of water after a heavy rain. I’m on a plan to rebed the stanchions and portlights once the weather warms up.
But it’s not the water, it’s the mildew smell that overwhelms once the weather warms up.
I have a dinette style cabin. You can see the entire bilge when you open the boards. It smells.
Also, if you remove the galley drawers, woof!! Open the fender locker, same thing.
The smell isn’t bad beneath the Vee berth. All good in the quarterberth.
So I’m wondering, what’s the best way to ventilate the entire area down below with either passive or active vents? I’m thinking I can cut some 3” holes in different areas like:
+ the side of the forward dinette seat
+ the area beside the galley drawers under the rotary switch
+ the side of the port side cockpit seat
+ somewhere else?
I’d like to add a 12VDC fan on one of these vents that would run off a small 8W solar panel and a separate 2AH gel battery.
Has anybody done anything like this on their boats?
Edited by - Voyager on 03/16/2019 09:52:41
Response Posted - 03/16/2019 :  10:52:12  Show Profile
I wouldn't start chopping holes in the boat. The problem is the leaks. If your going to address the leaks I would pour half gallon of the nice smelling floral scented bleach in the bilge and load some into a spray bottle and spray everything below the floor. That will get rid of the mold and smell until you can fix the leaks. I usually put a cup or two in my bilge as a just in case through the season. It sloshes around with the boat movement and keeps everything smelling nice.
Edited by - islander on 03/16/2019 15:58:27
Response Posted - 03/16/2019 :  13:47:18  Show Profile
I second Scott's suggestion. FWIW i get water in the bilge and floor area from the companion way and sometimes from my old style vent in the head area. Most seasons the bilge is dry but the cabin floor has puddles, this past year -- a rainy one -- fresh water was frequently in the bilge. I have, to date, never had a smelly cabin or unusually smelly bilge -- but have had some mildew. Using Tilex to clean the mildew works, and I would suggest if you spray the tilex then even before you get to cleaning much of the smell will dissipate and cleaning will be easier. Separately, if you suspect the stantion bases or window's are leaking, then fix them ASAP as they could be hiding other, far more serious problems.
Peter Bigelow
Rowayton, Ct
glivs
Response Posted - 03/16/2019 :  16:10:19  Show Profile
fwiw....When we purchased our boat, the smell was rank..serious. I removed all hoses (head and freshwater system) but the smell remained. At that point I took the drawers and frames in the galley and all removable locker covers off the boat and used a garden hose and spray nozzle to hose down between the hull and the liner behind the seats and under the sole from bow to stern the best I could. I was amazed by how much what appeared to be fiberglass dust (?) I presume was left over from when the hull was laid up washed into the bilge...and it clearly was at least one source of the smell. I followed up by spraying a mild bleach solution as Scott suggests. Nearly 13 years later...and I've tackled several leaks but the boat still smells fresh.
Response Posted - 03/16/2019 :  18:08:22  Show Profile
Thanks for your generous advice on this. Here are a few points:
+ The cabin doesn’t currently smell badly because there’s sufficient ventilation with my forward hatch passive Nicro Vent and companionway board slats.
+ I have a hygrometer in the cabin and during the boating season it rarely reads less than 70% humidity.
+ It only smells when you open up the down-below. This has been consistent since my early days with Passage.
+ It’s gotten a little worse, or with age, maybe I’ve gotten a little more intolerant.
+ I agree a good inspection of the core will find the usual amount of bad core, however, that’s not going to sink Passage.
+. I am starting with the six stanchions first, then the portlights.
I like the idea of using a mildew killer to reduce the total mold quotient. Tilex is good cleaner, flavored chlorine bleach is good too.
When we had a basement flood last summer the ServPro folks recommended “concrobium” spray, a fogger actually, and that worked quite well at preventing mold and mildew.
It’s claimed to be nontoxic made of natural ingredients. Perhaps it is, but the stuff works! I also have a 16oz spray bottle.
See: https://www.lowes.com/pd/concrobium-32-oz-liquid-mold-remover/50053503
But I’m really considering adding a few ports like these for bilge ventilation:
https://www.westmarine.com/buy/sea-dog--3-thru-vent--10729531
I think I can add a basic computer fan to the back of one end. Not sure how many CFM I’ll get from one of those. I could add a gas locker exhaust fan, but that would take a few amps to run it, so it’s not a great solar-panel kind of thing...
Edited by - Voyager on 03/16/2019 18:14:30
Response Posted - 03/18/2019 :  11:04:52  Show Profile
I added hinges to the bilge cover and an opening
Then I removed the top drawer of the two aft drawers. I use the bottom storage drawer faster and easier because I usually don't have to open it, I can just reach in.
This allows cross ventilation of the bilge area as well as the area behind the counter. Keeps most of the area dry and allows the bilge to dry faster.
Response Posted - 03/18/2019 :  12:23:07  Show Profile
In addition to attacking the leaks and giving the bilge a dose of lemon-scented chlorine (and then letting the boat air out for a while), I think I'd do something like Ray did so the bilge can be left pretty open when I'm not aboard, and closed off when I'm there. Small permanent vents from the bilge into the cabin probably aren't going to make or keep things dry, but they might spread odor when you're there as well as when you're not. This is where the solar vents really help--they pull the moist daytime air out overnight before it cools and "dews" all over the interior (including the bilge), replacing it with cooler night air that has already dropped its dew. And wind or no wind, you have a constant 24x7 air exchange. I know Nicros have been problematic, but when the work, they work.
(I recall the area under the quarterberth is open to the rest of the bilge, although water runs to the keel sump, so I don't know why you don't have the same smell under there.)
Edited by - Stinkpotter on 03/18/2019 12:25:56
Response Posted - 03/21/2019 :  05:19:57  Show Profile
I like the idea of the sea dog vents, with screens, as a way to add vents. Thank You
Response Posted - 03/21/2019 :  05:59:50  Show Profile
@ Dave — it seems I forgot to mention the space beneath the quarterberth in my original note, but it’s musty in there too. The quarterberth itself however is not particularly musty smelling because it’s open to the cabin area.
I am going to try a test this week: open the boards up that cover the bilge area, take out the drawers and open the dumpster. She’s still under a tarp so I doubt any rain will get in.
Then I’ll run my 12VDC fan using my spare solar panel to ventilate the cabin. I’ll let it run for a few days then check the smell and relative humidity.
If that reduces the smell to a tolerable level and drops the RH below 60%, then I’ll have my answer.
I’d need some kind of hinged hatch to allow for air circulation down below. I would add a few Sea Dog vents inside.
I have a spare 20W solar panel and an 8W panel. The fan is a 10” O2-Cool fan. Should do the trick
Edited by - Voyager on 03/21/2019 06:03:32
Response Posted - 03/21/2019 :  09:13:26  Show Profile  Visit OLarryR's Homepage
Another area to check is a leak coming down the mast column - look on the flooring for a water stain leading to the bilge.
Larry
Response Posted - 03/21/2019 :  10:54:23  Show Profile
Through the winter lay up all my hatches and drawers are open. Nothing is left closed for maximum air circulation. The cushions are all raised up on pool noodles so if water did get in they wouldn't be sitting in a pool of water. I've nerey yet opened the boat and found mold or smells.
Response Posted - 03/23/2019 :  16:21:23  Show Profile
After all the discussion I stopped at Passage today and opened all the bilge covers. The seats, the quarterberth panel and the fender locker. No smells at all.
I looked down and it was completely dry down below. Relative humidity was about 40% in the cabin. I didn’t check the RH in the bilge.
So I started on rebedding the stanchions. The first one was in there very tight, after I removed the nuts, the bolts were pretty snug.
I scraped off the old bedding. I checked on the core and it was firm and not rotten.
I’m looking forward to replacing the rest.
Response Posted - 03/24/2019 :  13:08:17  Show Profile
The window frames are at least as suspect.
Response Posted - 03/24/2019 :  13:45:26  Show Profile
Or worse yet the car tracks. A zillion screws and nuts and 30+ year old caulk. I figure that caulk is non existent or just dust by now. To make it worse the screw heads are recessed slightly into the track creating tiny little pools of water. It's enough to keep you awake at night.
Edited by - islander on 03/24/2019 13:50:18
Response Posted - 03/24/2019 :  17:07:38  Show Profile
The window frames are next on my list, I’ve gotten through two out of six stanchions. Good news, no rot yet.
