 Help a new 250WK owner - Toilet plumbing
Catalina250
Initially Posted - 03/19/2019 :  14:43:50  Show Profile
Hi all, I have a 2006 Catalina 250 WK I purchased in October (2018), and I bought it knowing it needed the head replaced. The PO sold it to me with a brand new toilet in the box that he hadn't gotten around to replacing. It is a Jabsco twist-n-lock. Unfortunately the Jabsco he provided to me has a discharge with an elbow
My discharge hoses don't allow me the flexibility to connect to that elbow discharge since the Jabsco elbow discharge is pointing upwards, and the original toilet had a strait horizontal discharge.
So I think my options are:
1 - I could buy this, which Raritan has a strait discharge exit for https://www.defender.com/product.jsp?id=10301 but it is pricey, and I don't know if mounting it would be a problem or not.
2 - I could start re-routing the discharge hoses but I'm pretty scared to do this, and I think it would result in having to cut a hole higher up here or something, and quite frankly I feel like this is over my head
3 - I could try and get some sort of fitting to take the elbow discharge back down. I'm afraid of doing this because it seems like the exit would be going upwards, back down, then straitening out, which sounds like a lot of fittings and chances for leaks. This is my crude drawing of what I'd need to do with fittings (in red) for the discharge
Any other ideas? Help!
Edited by - Catalina250 on 03/19/2019 14:46:58
Response Posted - 03/19/2019 :  18:02:00  Show Profile
Just taking a stab at this but it appears that outlet might be able to discharge out straight if you unscrew it and turn it 180 degrees then screw it back on if that is possible.
Edited by - islander on 03/19/2019 18:04:56
Response Posted - 03/19/2019 :  22:10:26  Show Profile
Contact Jabsco. I bet they have alternate fittings that may work better for you.
Catalina250
Response Posted - 03/20/2019 :  04:31:41  Show Profile
Islander, you are correct, you CAN flip it over, but unfortunately the angles in the picture are a bit misleading and that winds up pointing it too far down... so much so that there isn’t enough room to get the hose on. A good and insightful suggestion though for sure!
TakeFive, I paid someone else to look at this for me and he said Jabsco didn’t have a part for this (he recommended I replace the toilet outright), but I think it is worth me calling Jabsco and making sure... I’ll do that.
Thanks for the feedback, much appreciated!
Response Posted - 03/20/2019 :  04:53:28  Show Profile
This is the manual for instalation.http://media.channelblade.com/EProWebsiteMedia/3506/Jabsco%20Twist%20n%20Lock%20Manual%20Toilets.pdf
From the manual it can be rotated to discharge 360 deg.
" Multi-angle discharge elbow for ease of installation".
"The Discharge Elbow (key 34) may be rotated 360° to
suit your installation. Always slacken the 2 securing
screws, adjust the discharge elbow to the required
position and re-tighten the 2 securing screws before
you connect the hose to it"
If this doesn't get it straight or close You can heat the hose to make it flexible and be able to put a bend in it. A heat gun or hot water should do it.
Edited by - islander on 03/20/2019 05:17:13
Catalina250
Response Posted - 03/20/2019 :  09:07:33  Show Profile
Islander, I've taken this off and it does rotate, but only in 90 degree increments. so it can exit up, down, left, or right. As this image shows though, when it exits down, it is exiting almost strait into the floor. I think my issue is the inflexibility of those hoses... I wonder, could I replace those hoses with something more flexible? Is that an option, or do those hoses need to be rigid?
Response Posted - 03/20/2019 :  10:45:37  Show Profile
The sanitation hose really shouldn't be substituted cuz they are mmade to stop smells from permeating through. You can make them more pliable by warming them. I would give that a shot first before buying a new head.
Catalina250
Response Posted - 03/20/2019 :  11:01:44  Show Profile
OK, heating the hose sounds like something I need to give a shot.
I've also got a call into Catalina to see if they have a suggestion... surely other C-250 owners have had to replace a toilet.
Catalina250
Response Posted - 03/20/2019 :  11:18:38  Show Profile
Any thoughts about these products?
https://www.marinesan.com/45-Bend-Kit-p/45-bend-kit.htm
http://www.fawcettboat.com/pc_product_detail.asp?key=88BA0739C632474C88B6CAFC8D5EADFC&_vsrefdom=adwords&gclid=EAIaIQobChMI-6fk46aR4QIVhbrACh2v6QbKEAQYASABEgJqtfD_BwE
Edited by - Catalina250 on 03/20/2019 12:49:53
Response Posted - 03/20/2019 :  13:15:12  Show Profile
The flexible hose looks promising. A piece attached to the toilet that you can then bend straight back and attached to your existing hose with a common 1-1/2" hose Barb.
Catalina250
Response Posted - 03/20/2019 :  13:24:50  Show Profile
Ok, well... it sounds like I have options, and some plumbing in my near future! Thanks
Response Posted - 03/22/2019 :  07:28:58  Show Profile
Just a thought but did you ever look into a rebuild kit for the existing head? Basically it would make it new.
Catalina250
Response Posted - 04/02/2019 :  09:55:35  Show Profile
To answer the question about a rebuild kit for the old pump... that would have been a great idea, but I don't have the old pump, so... no can do there.
I'm headed to the boat this weekend... I've done all the research I think I can, and I think the Raritan Sani/Flex hosing is my best option... so i'm going to chop off a length of the existing hose, and replace it with the sani/flex hosing... from reading some other reviews and discussions on the Raritan hosing, it is pretty flexible, so i think that is pretty promising.
I'm curious about "splicing" those two hoses... Does this seem like a reasonable option to connect those two hoses?
https://www.defender.com/product.jsp?name=marineeast-hose-to-hose-splice-adapter&path=-1&id=2795078&cartId=15174588
Response Posted - 04/02/2019 :  10:58:26  Show Profile
Yep, That is what you will need. Don't forget hose clamps. Make sure the clamps are stamped 'All Stainless' meaning that the worm gear is stainless also.
Edited by - islander on 04/02/2019 11:04:07
Catalina250
Response Posted - 04/15/2019 :  11:36:13  Show Profile
FYI, I did wind up using the Raritan butyl saniflex hosing. I had to do some weird routing of the hose in order to make it work... I'll try and post pictures after this next weekend. Thanks for the help here. I'm not done with it yet (the hose is routed in a circle around the FRONT of the pump... so it is definitely a short term solution), but at least we can use it now, and it isn't leaking or putting any strain on the pump assembly.
Catalina250
Response Posted - 04/24/2019 :  11:27:52  Show Profile
So, this is my solution. Not elegant, but it allowed me to avoid bending the non flexible hose, and since I wasn't sure about drilling a 2.5" hole in the bulkhead behind it... it works. My plan is to drill a 2.5" hole to the right of the 2 smaller hoses, and then take the sani-flex hose directly out and through it and join it to the old hose behind the bulkhead.
Feedback is welcome
Edited by - Catalina250 on 04/24/2019 11:31:23
Response Posted - 04/24/2019 :  12:47:34  Show Profile
Now that there is better photos I see your problem but It looks to me that you could cut the angle part of the tail piece off so it would be straight. Looks like there still will be enough room to slip the hose on. Is that possible?
glivs
Response Posted - 04/24/2019 :  18:58:28  Show Profile
From the photos I assume you have a vented loop in the water supply line. Not an issue, but why not move the water supply lines to the bottom opening and run your waste line through the upper opening directly from the Jabsco pump. You may need to add an elbow behind the bulkhead to continue the run to the holding tank but I suspect it may be in place already. If you have an access port it should be quite doable and a heat gun/hair dryer would make pulling the hoses off very easy...just don't get things too warm or you will distort the Jabsco fittings. A $20 ratcheting hose cutter from Ace or a big box store would also make fitting your waste line (multiple cuts) so much easier. Ignore everything I've said if you are way ahead of me....I'm just thinking out loud without really knowing what you are facing. Good luck.
Catalina250
Response Posted - 04/25/2019 :  08:15:40  Show Profile
I do have a vented loop in the supply line. That is a good thought about swapping the supply lines and waste line. The hole in the bulkhead for the supply lines is smaller, and is too small for the waste line, but could be enlarged slightly, which would be a lot less of an impact than drilling an entirely new hole. With that said, I'm not sure if the supply lines would bend down to go through the hole currently used by the waste line... but it is worth looking into. I could add elbows to the supply lines without any real impact I think, which might make that doable.
Islander, The discharge part coming from the pump is larger at first and then smaller where the hose slips over, so the actual area where you slip the hose over which is fitted to the 1.5" inside diameter hose, is actually fairly small... I wouldn't want to cut any off of it, and trying to fit a hose over the larger part and then reduce it in size seems like a mess too... so I don't think that would work. Thanks for the suggestion though.
Glivs, would this be similar to what you are talking about for cutting that hose?
https://www.homedepot.com/p/General-Tools-Heavy-Duty-Pipe-and-Tubing-Cutter-126/301357632
Edited by - Catalina250 on 04/25/2019 08:17:21
glivs
Response Posted - 04/25/2019 :  10:40:50  Show Profile
Apparently there is no agreed to name (hose cutter, tubing cutter, PVC cutter, ...) so it's hard to search for but this is what you're looking for. I bought mine at Ace Hardware for the same price. The waste hose is not all that easy to fit so an incremental approach is almost needed. I cut mine initially to within 5-6", then within about 1-1.5" and then the final cut. Each cut allows you to get a better feel for how the hose will fit into where you want it to go. Again, a warm day or a little added heat may aid you. I'm sure obvious but don't forget to remove the Jabsco fitting from the pump (2 screws) before connecting it to the waste line .... maximize your degrees of freedom of movement and minimize stress on the pump ... you don't want to break something.
Catalina250
Response Posted - 04/25/2019 :  10:45:25  Show Profile
Thanks a bunch Glivs... good advice, etc.
