 Wood filler...Off topic but would love your advice
dalelargent
Initially Posted - 04/19/2019 :  09:58:07  Show Profile
Hi all,
I have a porch rail that is in sad shape after this winter. The rail is a 2x6 laying flat/horizontal and acts as a cap rail around the porch. One area, approximately 6 sq inches, has rotted horribly, but only about 1/2 inch down. I would like to replace the specific board, but the carpentry will be sort of nightmarish and I have been dreading it.
I awoke with a thought this morning. Surely there is some product I can mix up and pour into the affected area (after removing rotted material). I thought of this in relation to how some have drilled rotting deck cores and poured in epoxies or what have you.
Any recommendations on what I could do? By the way, the finished product will be painted with house paint.
1989 c25 WK/TR #5838
1998 Catalina 36 mkii
1983 Vagabond 14
Edited by - dalelargent on 04/19/2019 09:59:02
Response Posted - 04/19/2019 :  11:15:19  Show Profile
I fixed a rot area in a window sill by filling it with epoxy. I filled it full then let it soak in. After it hardend I re filled it to level it out then painted it. The cap rail should be on an angel to shed water. Sounds like water is pooling on the level cap rail causing the rot.
Edited by - islander on 04/19/2019 11:19:10
dalelargent
Response Posted - 04/19/2019 :  13:09:21  Show Profile
Thanks for the encouragement, Scott. I will give it a try.
I have some g flex laying around. Do you suppose that is suitable?
The specific spot had a knot which seems to have dramatically increased the issue. The rest of the cap railing is fine.
1983 Vagabond 14
Response Posted - 04/19/2019 :  14:19:00  Show Profile
G flex is what I used I think. Only because it was what I had laying around. You want it to flow and soak into the wood so having it warm will help.
Chief RA
Chief Technical Advisor
Response Posted - 05/04/2019 :  08:02:40  Show Profile
Use auto body filler (Bondo) as it won't absorb water and will fill well. Might be good to pour in liquid epoxy first to soak in and seal weak areas. Chief
COMPASS ROSE C250WK
Tall Mast, Wing keel
PORT CHIEF, Bodega Bay Ca.
IE,EE,FCC lic #1890
Response Posted - 05/04/2019 :  08:50:16  Show Profile
Git Rot is a "penetrating" epoxy--very fluid, which soaks into the fibers of rotting wood and (hopefully) stops the sub-surface spread. I would suggest that as the first step, and then thickened G-Flex as needed to level and smooth the area.
Edited by - Stinkpotter on 05/04/2019 08:50:56
Peregrine
Response Posted - 05/04/2019 :  09:24:23  Show Profile  Visit Peregrine's Homepage
Someone mentioned it above. Bondo!
Easy to work with. Will need painting as it is greenish. If possible take a plane or belt sander and give the entire cap a peak sloping off to each side. It will keep water from pooling on the flat surface.
Use a primer and good exterior paint.
John Gisondi
Peregrine
#4762
Response Posted - 05/04/2019 :  09:41:11  Show Profile
There are a couple of products on the market (one is called Penetrating Wood Filler) which solidify rotten wood. It pours into the area and sets so solid that you can not get a screw into it!
Chief Measurer C25-250 2008
San Antonio, Texas
