 Wanted Tiller Tamer
zeil
Initially Posted - 05/12/2019 :  08:43:11  Show Profile
Would like to buy this type of tiller tamer (image compliments of Practical Boat Owner)
Henk & Johanna
Response Posted - 05/12/2019 :  10:14:49  Show Profile
Hi Henk, I can almost tell what the picture is of.
Seems like a stainless steel gizmo that is screwed onto the tiller handle about 1/2-way down that has a brake (the black knob and SS shaft) and holds the tiller stationary.
Can’t tell whether the line is stretchless (like halyard line) or stretchy like bungee line.
I ask because my home-made tiller tamer has some give to it (maybe +/- 4°) that allows the tiller to auto-correct my direction somewhat based on weather-helm variations.
A solid brake with no slack will not auto-correct and will give you no more than 15-20 seconds before you’re off course.
My approach is not an auto pilot but the feedback loop will keep me on course for 1-2 minutes if I set it right. And it costs about $10 for parts.
I’ve posted my photos in the past and can do so again if interested.
Response Posted - 05/12/2019 :  10:39:39  Show Profile
My approach, which I first saw years ago on Trailersailor.com and used on two boats, was very simple and functional as tamers go... It was shock cord with a loop on each end that went on the stern cleats, and then the cord was wrapped around the tiller 3-4 times. To disengage it, I gripped and slid the wraps aft on the handle, slackening the cord. To engage, slide them forward. To make a slight adjustment, grip the wraps and turn them one way or the other. To make a course change (including tacking), push or pull the tiller, stretching the cord, then release to hold course again (probably requiring adjustment to the new point of sail). Total cost: ~$15.
zeil
Response Posted - 05/12/2019 :  10:43:03  Show Profile
Yes... I'd like to see the photo's. What I liked about the one shown in the photo is the instant release enabling to control the boat manually
On our boats even by shifting position a course adjustment is required. This tiller tamer needs frequent adjustments and is only good for short periods but it steadies as she goes.
Henk & Johanna
Response Posted - 05/12/2019 :  15:49:35  Show Profile
Henk, the type I created is shown here in this thread. I included some photos.
http://catalina-capri-25s.org/forum/topic.asp?TOPIC_ID=31290
Edited by - Voyager on 05/12/2019 18:13:51
Response Posted - 05/12/2019 :  17:36:55  Show Profile
Henk -- FWIW -- for simple, something like what Dave described would be the way to go. For reliable, a true tiller autopilot is the way to go. May cost a little more, but needs less (not none) supervision.
Peter Bigelow
Rowayton, Ct
Response Posted - 05/13/2019 :  06:42:16  Show Profile
Henk, That was called the TillerLock and was made in Canada. Did a search for it and found out it is no longer made. Here is a better photo.
A similar substitute that might work for you is the TillerClutch seen here.http://www.wavefrontmarine.com/
Edited by - islander on 05/13/2019 06:48:55
Response Posted - 05/13/2019 :  06:44:34  Show Profile
I'm with Dave on this one. A 6' bungee cord is the way to go - inexpensive, easy to set and remove, works well - and you can still use a tiller cover without the hassle of having to dismantle/re-install a piece of equipment.
Chief Measurer C25-250 2008
San Antonio, Texas
Response Posted - 05/13/2019 :  11:05:45  Show Profile
Not sure what you mean. I have a tiller tamer and just like the bungee cord I just disconnect the two lines from a pair of clam cleats then wrap the two lines around the tiller and slide the cover on over the lines, tamer and tiller. What I do like about the tamer is that you can set the drag once just enough to hold the tiller in what ever position you want then let go. No need to loosen,tighten,slide or twist anything for the rest of the day.
zeil
Response Posted - 05/14/2019 :  14:04:26  Show Profile
Scott that's exactly the TillerLock I had on my other boat. It would be wonderful to get another one.
Perhaps someone of this forum is not using the TillerLock and is willing to sell it to us
Henk & Johanna
jmadd
Response Posted - 05/14/2019 :  14:26:04  Show Profile
You guys are fortunate that kind of static tiller control works for you. I have a way to lock my tiller in place, but it is largely useless on a Capri 25. The boat is so light any small wave will knock you off course and require immediate adjustment.
Response Posted - 05/14/2019 :  21:47:34  Show Profile
That’s why the small amount of play in my home made approach, or Dave’s bungee approach, works so well - negative feedback. If the tiller is locked rigidly in place then it’s absolutely sure to be wrong by a small amount and very shortly the error builds up and you’ll be off course. With some wiggle, the boat will start to turn but the negative feedback will compensate and bring the boat back on course - then overshoot, which adds more negative feedback the other way and rights the course, hence averaging out the variations. It’s a little magic and it doesn’t always work, but if you get just the right touch, it’ll keep you on course for a minute or two, sometimes longer.
Edited by - Voyager on 05/14/2019 21:51:02
Response Posted - 05/15/2019 :  08:19:35  Show Profile
Scott, my tiller cover was just wide enough to go over the tiller.It wouldn't fit over any accessories,
San Antonio, Texas
Response Posted - 05/15/2019 :  17:00:03  Show Profile
Defender Tiller Lock Option?
Association Member
Andiamo
'89 SR/WK #5862
Kemah,TX
