 Poli Glow
Initially Posted - 05/14/2019 :  19:19:24  Show Profile
Continuing the discussion from another thread... how long does it take for each coat of Poli Glow to dry? I wanted to try and apply it this weekend but we're supposed to have some off and on showers this weekend.
On average how many coats does it usually take to get good coverage?
How many coats can one get from a bottle?
Also, do you apply it to the smooth areas on the coach top (not on non-skid)?
Association Member
Andiamo
'89 SR/WK #5862
Kemah,TX
DavidBuoy
Response Posted - 05/14/2019 :  20:34:33  Show Profile
Dry by the time you get to the end. One bottle is more than enough. I don’t think it’s good to put on the top. Love the stuff though
Captain Rob & Admiral Alyson
Response Posted - 05/14/2019 :  20:51:01  Show Profile
My recollections from more than a few years ago:
Each coat dries about as fast as you can start the next on the same side. You only need to stop to rest. I recall doing 5 coats on one side in about 45 minutes. I did the whole boat (5 coats) with one bottle, with a little left over. I only ever used it on the hull. I’d be wary about rain—PG is water soluble until it sets up, so a sudden shower could mess up a little bit of your work.
Be aware the first coat almost vanishes... the second looks streaky... the third less so... the fourth very good, and the fifth makes you proud! A yard worker was paste waxing a boat next to where I was doing doing a dress-coat one spring—I was done before she finished the transom. She was envious!
Edited by - Stinkpotter on 05/14/2019 20:56:44
DavidBuoy
Response Posted - 05/15/2019 :  04:46:35  Show Profile
I agree with everything Dave mentioned, and the stuff really does do miracles:
Response Posted - 05/15/2019 :  07:57:08  Show Profile
GaryB, the most important prep with PolyGlow is to remove every "imperfection" in the hull because it will still persist under 5 coats! The supplied PolyPrep does a good job on that. I agree with Dave on what it looks like after each coat - so be prepared. After the 5th coat you can use the hull as a mirror. When I used it, each coat was dry on the first side by the time I finished the second side. (Our Texas sunshine sure helps).
After a year or so, you can apply a refresher coat after washing the hull well with soap and water.
Chief Measurer C25-250 2008
San Antonio, Texas
sethp001
Mainsheet C-25 Tech Editor
Response Posted - 05/16/2019 :  13:25:17  Show Profile
Here's a video of my boat in the water after applying Poli Glo per the instructions.
https://whichsailboat.com/2016/10/18/poli-glow-works/
Seth
"Nomad" 1980 Prindle 16
Response Posted - 05/16/2019 :  17:52:05  Show Profile
Thanks all for your comments! Rob and Seth... WOW! They look like new!
Hoping I can do mine this weekend but now they say we have a 70% chance of rain Saturday and we're going to my grand-daughters recital on Sunday so not sure if it's going to happen.
What should I do about the sides of the cabin where the gelcoat is smooth?
Association Member
Andiamo
'89 SR/WK #5862
Kemah,TX
Edited by - GaryB on 05/16/2019 17:53:04
sethp001
Response Posted - 05/17/2019 :  15:44:07  Show Profile
You can put Poli Glo there too.
Seth
Akenumber
Response Posted - 05/30/2019 :  18:31:48  Show Profile
In harsh climates be ware of using it on top sides. I did a small test and was glad I didn't do the whole thing. Also pay attention to recoating. If it looses it's uv protection it can go bad. It did that to me and I pretty much had to wet sand it off. I put it back on though. Great product for a tired hull.
Ken
San Diego
84 C25 SR/FK 4116
The KRAKEN
Response Posted - 05/30/2019 :  20:39:06  Show Profile
Not sure I follow. What about the harsh environment created the problem? What was the problem?
Association Member
Andiamo
'89 SR/WK #5862
Kemah,TX
Response Posted - 05/30/2019 :  20:43:25  Show Profile
...I pretty much had to wet sand it off.
You might want to try their Strip product next time--might be easier on the gelcoat.
Response Posted - 05/31/2019 :  15:38:47  Show Profile
So this weekend is going to be the big weekend... I read the directions on the bottle but still have questions.
1. How easy does the Poli Prep clean the hull of wax and dirt? (I noticed my hull has some areas that show swirl marks from where the wax has worn off since I had the hull cleaned and waxed a little over a year ago).
2. What's the best way to apply the Poli Prep?
3. Should I use a bottle with a trigger or a pump sprayer?
4. I assume I do a small area at a time?
5. When applying the Poli Glow is it best to use the mitt or the applicator that appears to go on the end of a handle?
Any and all suggestions are welcomed!
Thanks in advance!
Association Member
Andiamo
'89 SR/WK #5862
Kemah,TX
Response Posted - 06/01/2019 :  12:26:13  Show Profile
I used the applicator on a broom handle--good for a fin-keel hull on the hard. Keep the coats thin, avoiding drips--as said before, be patient--by five coats you'll be pleased--you might want to do six. You just go around and around and around... the boat. You're done, and I mean DONE, before you can imagine. Next year, one "dress coat" should be all you need, except in spots where fenders, for example, have worn through.
I'd be reluctant to spray Poly Prep on--it's pretty harsh stuff, and could affect your bottom paint (not to mention your lungs). I think I used to apply it with a fine Scotch-brite pad, using rubber gloves. What do the instructions say?
Edited by - Stinkpotter on 06/01/2019 12:30:59
Response Posted - 06/01/2019 :  17:25:58  Show Profile
Forgot to mention the boat is in the water. Is it doable with the boat in the water?
Association Member
Andiamo
'89 SR/WK #5862
Kemah,TX
Response Posted - 06/01/2019 :  18:40:36  Show Profile
Wear a harness and clip in. I just question whether you'll be able to see what you're doing. If you have finger docks on both sides or are working from a dinghy, then yes. From you're own deck....
Response Posted - 06/01/2019 :  19:41:49  Show Profile
I've got 3' or 4' wide, full length floating finger docks on both sides. My slip is 12' wide x 30' long so I was planning on adjusting the lines so I could get the hull near one side of the slip and then adjust accordingly as needed to keep it within arms length.
Above you mentioned you would be reluctant to spray it on but mentioned using a scotch-brite pad. Does that mean you just sprayed or poured the Poli-Prep on the pad?
Association Member
Andiamo
'89 SR/WK #5862
Kemah,TX
Response Posted - 06/02/2019 :  08:36:08  Show Profile
GaryB, the easiest way to do it in the slip is to take the main halyard (with another line tied to it to extend it) a couple of slips over around a creek and then haul on it - sort of a semi-careen. If you move the boat close to the slip before doing this, it makes it easy to access all of the topsides (that's the hull, not the deck!) I bought the kit from PolyGlow and it came with a chamois and a block as an applicator. BTW the PloyPrep does a very good job of cleaning the hull and especially gets all the oxidation off.
San Antonio, Texas
Response Posted - 06/02/2019 :  09:46:30  Show Profile
Sorry--that was a lot of years ago... (I also can't remember how many. ) BTW, Derek's halyard idea, which I would liken to "kedging", would probably make it easier to work down along the boot stripe--Poly Glow can make that look better, too.
Edited by - Stinkpotter on 06/02/2019 12:26:01
