 Dead light replacement
C25BC
Initially Posted - 05/15/2019 :  20:26:54  Show Profile
Cracked my dead light last weekend , going to replace it this weekend if the weather cooperates. I checked out the search mode and found boat life seal is recommended so that's on the way . I've been searching online to find out the best way to clean old sealent off and prep for new seal without much success . Any tips ?
Angus
S.V.Tempus
#4748
1984 Catalina 25 SK/SR/Trad.
Response Posted - 05/16/2019 :  04:19:07  Show Profile
Is the caulking LifeSeal (polyurethane and silicone) or LifeCaulk (polysulfide)? Big difference.
The former is devilishly resistant to any means of removal while the latter peels off with a putty knife.
This might be a good video to watch, Andy at Boatworks Today
https://youtu.be/GnQG7eUyHxU
I just happened across a place called National Supply. Seems like they have some pretty good pricing.
https://www.nationalsupplydirect.com/
Edited by - Voyager on 05/16/2019 04:25:01
Response Posted - 05/16/2019 :  04:33:17  Show Profile
I just scraped any old sealant off then used acetone to clean the residue. The dead light is made up of two pieces of plexi. One external and one inside. I Removed the interior one that was held in by some screws then pushed the old exterior one out. You may need to run a razor knife around it to help loosen it. After getting it all cleaned up I roughed up the flange that the exterior lens sits in with sandpaper. The new lens may not fit perfectly in the flange and may need to be shaped a little with sand paper. I taped the deck and lens with painters tape so as to make a nice neat bead. After setting the lens in the LifeSeal I smoothed the bead with my finger. I carefully removed the tape after it had set up a little then put a small rock on top to to keep a little downward pressure on it. The next day it was all cured so I reinstalled the interior lens.
Edited by - islander on 05/16/2019 04:48:36
Response Posted - 05/16/2019 :  06:33:34  Show Profile
The former is devilishly resistant to any means of removal while the latter peels off with a putty knife...
But I prefer Life Seal over regular silicone sealers for removability, and it's compatible with plastics, while Life Caulk "attacks" most plastics. And Life seal is clear, while Life Caulk is white or black.
C25BC
Response Posted - 05/16/2019 :  07:09:56  Show Profile
I bought the life caulk first by mistake ( in a hurry and no glasses ) then when I figured out the error picked up the life seal , not sure what was used previously as far as removal goes , I will try the above mentioned technics . I was thinking of leaving the interior lens since it's in tact and a extra layer of protection in the event of a passing showers .
Angus
Angus
S.V.Tempus
#4748
Response Posted - 05/16/2019 :  07:30:47  Show Profile
The reason I removed the interior lense was so I could push up on the old lense to remove it. Also debris will sit on it and the risk of the LifeSeal dripping on it. Also you may need to tidy up the LifeSeal on the interior side if it squeezes out. It's not a big deal to remove the screws and take it off. You will put it back on when your done. On my boat the screws we're the only thing holding it in place. The interior lense is only cosmetic. There is a gap between the two lenses. The exterior lense is fixed to the deck. The interior lense is fixed to the liner. The interior lense does nothing to seal out water.
Edited by - islander on 05/16/2019 07:44:46
C25BC
Response Posted - 05/16/2019 :  08:09:49  Show Profile
Points taken , mine has no screws, it has quite a bit of clear sealent , hence my theory on keeping interior dry . I imagine when installing new one I could keep it in place with painters tape .
Angus
S.V.Tempus
#4748
Response Posted - 05/16/2019 :  08:28:56  Show Profile
Goes to show you that no two boats are identical.
Actually the drawing shows sealant holding the interior lens in place. Catalina called it Sili-Glaze. You could leave it in place and just clean out the debris off the top of it before you install the exterior lens. You'll have to remove the old exterior lens from the outside. Maybe pry it up or cut a hole in it to get a finger in to pull it up. Since its already cracked it shouldn't be to difficult to get out.
Edited by - islander on 05/16/2019 08:32:40
Response Posted - 05/16/2019 :  12:10:11  Show Profile
Originally posted by C25BC
...I was thinking of leaving the interior lens since it's in tact and a extra layer of protection in the event of a passing showers...
I would suggest that if "passing showers" get past the outer lens, you don't want water secretly accumulating on the inner one and then soaking into the the wood core around it. Properly installed, the outer lens should be the most water-tight item on the boat. I didn't install the inner one when I replaced mine.
sethp001
Mainsheet C-25 Tech Editor
Response Posted - 05/16/2019 :  13:28:58  Show Profile
In the ten years I've had my boat it has never had the interior lens. This was helpful in alerting me to the lens leaking when the cushions started to get wet.
Seth
"Nomad" 1980 Prindle 16
C25BC
Response Posted - 05/16/2019 :  16:20:20  Show Profile
i
It's cracked down the middle at the moment so getting the plexi out shouldn't be a problem ( we will see I guess )
The acetone tip helped , I was trying to find out the best substance to remove residue after scraping that doesn't affect the bond of the new seal
What to do about the inner piece ? I'll see how it goes I guess .
Either way I'm sailing this weekend
Angus
S.V.Tempus
#4748
Akenumber
Response Posted - 05/30/2019 :  18:46:46  Show Profile
Life caulk is no good for the deadlight. Found that out. I used uv 4000. Worked great.
Ken
San Diego
84 C25 SR/FK 4116
The KRAKEN
