 Repairing a delaminated tiller
Initially Posted - 05/29/2019 :  08:49:10  Show Profile
How do I repair my spare, delaminated C-25 tiller?
Is it simply a matter of filling each space with epoxy and clamping until completely hardened?
I plan on fixing it to have a working spare.
1978 C25 SR/FK "Gypsy"
Response Posted - 05/29/2019 :  09:03:59  Show Profile
I used white carpenter's glue to repair mine and then coated it with polyurethane.
I fabricated a replacement out of 2X10 mahogany. I selected a plank that had a curve in the grain in the right place to accommodate the curve in the tiller. I also made the tiller's cross-section thicker to make it stronger.
Response Posted - 05/29/2019 :  09:17:13  Show Profile
Probably what I would do just make sure the epoxy is runny enough to get into the nooks and crannies then clamp it up real good. After it cures sand it down and coat it. Heck it might be stronger than ever. The exterior wood glue probably would work just as well
Edited by - islander on 05/29/2019 09:21:12
Response Posted - 05/29/2019 :  13:26:27  Show Profile
Titebond makes a white glue, however, that’s not waterproof. They also make a waterproof glue as well.
Their website has a product selector that gives you the recommended products for your application.
Nothing wrong with epoxy either, however, it probably pays to clean the surfaces well before gluing, as recommended by the manufacturers
Edited by - Voyager on 05/29/2019 13:30:17
Response Posted - 05/29/2019 :  17:36:16  Show Profile  Visit Leon Sisson's Homepage
I'd go with a liquid epoxy such as WEST (my favorite) with a relatively slow hardener (206 or 209). First, clean the wood thoroughly with acetone. Planning ahead a bit, have the tiller heated up all the way through before applying the mixed epoxy. Then let the wood cool. As the air in the gaps and inside the wood cells contracts from cooling, it will pull the epoxy deeper into the places you need it to go.
— Leon Sisson
Response Posted - 05/30/2019 :  04:27:45  Show Profile
Gorilla Glue. Make sure the wood is wet when you do it. Clamp it after you apply, trying to keep the clamps clear from the wood as much as possible so you can wipe the seams, and stay with it over the first two hours wiping off the excess as the glue expands out of the layers. It is pretty hard stuff after it dries, difficult to sand down without a large grit.
With most glues it is important to clamp it up well, with Gorilla glue that's not the case, so I would not be worried about not having enough clamps.
After sanding apply several coats of a sanding sealer first which fills gaps but is soft to sand down and dries really fast between coats, otherwise your poly will just flow into the laminate and not cover the edges.
Then give it three coats of polyurethane sanding with an extremely fine grit between coats.
Response Posted - 05/30/2019 :  20:34:16  Show Profile
I used Gorilla Glue on the tiller I'm now trying to find (see my post in another thread). LOL
Worked great.
Association Member
Andiamo
'89 SR/WK #5862
Kemah,TX
Response Posted - 05/31/2019 :  10:30:14  Show Profile
Hey, guys, thanks for all the good suggestions.
