 Bimini Hardware
Istion1
Initially Posted - 06/15/2019 :  07:11:58  Show Profile
Looking to attach a Bimini to the top of the Catalina 250.
Never have done this. It didn't come with bolts or screws and I'm wondering what to use to install it.
Wondering if anyone can provide me some information do I just use wood screws does it have to be Bolts Etc do I need a backing plate.
Of course my boat is about a four-hour drive away and it's hard to check it prior to going so I'm just hoping to have the right Hardware when I get there
Dubhe originally out of texas, c250 wk
Response Posted - 06/16/2019 :  16:26:26  Show Profile
I've used both but I prefer Stainless steel machine screws, with the drill bit very close to the size of the screws. Resin does not give at all so it cracks if your hole is too small.
I think I've bought my machine screws to fit the hardware ( bimini ) and then checked the fit somewhere unseen inside the boat in the fiberglass, using both metric and SAE bits till I found something that fit well.
Response Posted - 06/19/2019 :  15:28:28  Show Profile
A bimini frame can be subjected to some significant stresses from being grabbed, fallen against, or caught in high wind. Wood screws, self-tappers, and sheet metal screws aren't a good idea. It should be through-bolted with machine screws, although a backing plate probably isn't necessary--just use the largest washers you can fit (up to "fender washer" size) and nylock nuts. Then use a proper sealant such as BoatLife Life Caulk or butyl tape to bed the bases and prevent water from migrating down the bolts. You can find Youtube discussions on bedding hardward--the method with butyl tape is somewhat different from doing it with caulk/sealant. I recommend chamfering the top edges of the bolt holes (a few turns of a larger drill bit) to allow a better seal around the bolt.
Edited by - Stinkpotter on 06/19/2019 15:35:25
