 Spinnaker Pole Topping-Lift / Up-Haul
Gunner
Initially Posted - 06/17/2019 :  15:38:31  Show Profile
Hi guys, me again.
How are you guys running the rigging for your spinnaker pole? Specifically I am trying to find a way to mount an up-haul / topping-lift, however you call it to keep the spinnaker pole level so it doesn't nosedive the sail nearly into the water.
The best I can think of would be a dedicated block mounted to the mast, half way up or more. But for now i’m using a track car at the top of my foremast track with a block attached. It works, but not well, and the $100 track car I purchased is a poor use of money. I kind of want to return it if I can find a better solution. Any thoughts?
dasreboot
Response Posted - 06/18/2019 :  04:10:06  Show Profile  Visit dasreboot's Homepage
mine is just what you say. a block halfway up the mast. i think it needs to be higher so you have a little more up in the angle, and less back towards the mast.
Todd Lewis
Eowyn 87 TR/WK C25 #5656
ARWEN 84 TR/SK C25 #4031
www.mainsailsailingschool.com
Response Posted - 06/18/2019 :  19:34:09  Show Profile  Visit Leon Sisson's Homepage
I think spinnaker pole topping-lift blocks are usually located a little below the spreaders. There they're pulling against the aft lower shrouds, not pulling the mast out of column mid-panel.
Yes, I understand the normal loads aren't very high. However, I used mine to hoist one end of a heavy dinghy on deck.
— Leon
— Leon Sisson
