 Any downsides to using blended oil on the outboard
vdotmatrix
Initially Posted - 07/26/2019 :  06:26:21  Show Profile
They were out of regular marine 10-40w motor oil at west marine and i picked up the blended... will have to change oil out anyway on the new motor..
Any downsides to using a blend?
Response Posted - 07/26/2019 :  06:56:19  Show Profile
No downside but since it uses a quart or less I always use full synthetic. Also it doesn't have to be bought at a marine store. You can buy oil from an auto parts store as long as the oil meets the viscosity and the API numbers required by the engine.
glivs
Response Posted - 07/26/2019 :  12:39:26  Show Profile
My Mercury Owners Manual does not recommend the use of synthetic oil...but I don't recall the explanation if any. ??? I'll check when I get a chance.
Edited by - glivs on 07/26/2019 12:40:28
Response Posted - 07/26/2019 :  16:09:53  Show Profile
You shouldn't use synthetic oil in any engine until it's completely broken-in (unless the owners manual says it's OK). If you use it too early there's a possibility the rings will never seat and you will have higher than normal oil consumption.
Association Member
Andiamo
'89 SR/WK #5862
Kemah,TX
Response Posted - 07/26/2019 :  17:22:53  Show Profile
If it's an older engine and you always used conventional oil then stay with that. Some say changing an older engine to synthetic could cause oil leaks due to it's cleaning ability. I don't know how true that is.
