This past season, I noticed my 1992 Yamaha 9.9 4 stroke would smoke fairly heavily after startup , then lightly during normal operation. I removed it from my sailboat and laid it down on the garage floor for about a month; this weekend, I installed it in
I can't answer your question, exactly, but I would be suspecting a cracked ring, perhaps. When you laid it on the garage floor, you put it down the way you're supposed to, right? Most 4 strokes have to be placed one of two ways when laid down. If you'r
Are you aware that there are only two positions that you can "lay down" the Yamaha 9.9 four stroke? See your manual. My motor got minimal use this past summer and I also got a small puff of blue smoke at start up - motor runs great though - with no smok
BTW: To add to my previous post: If this was a car engine, I would suspect the valve guides, just as you have. It does sound like the right diagnosis. Good luck. Gary on Encore!
Steve is on the mark... likely no problem with motor as it just hydro locked with oil in cylinder...funny thing...it wont compress. Be sure to lie the motor only in proper position in future and you will likely be ok.
IMHO the oil in the cylinder was more likey from that seeping thru ring gap than valve guides. Remember...that a cold engine has more ring gap than a hot one. The stored motor had lots of time and when thinking about it...if hydro lock occurred during l
