 Kitty litter for porta potty
Initially Posted - 04/29/2020 :  23:23:32  Show Profile
Was cleaning out the cat box recently and I wondered whether kitty litter’s ability to absorb moisture and smells would be useful in a portapotty?
Now my tank only opens to receive and expel fluids and solids, but if I could saw the tank in half (bottom half and top half), and I could partially fill it with kitty litter.
Then, if it were used for #1 the media would absorb wetness and smells and maybe clump up a little. But it would not be sloshing around.
For #2, using a minimum of flush water or blue water, the litter would basically dry out the solid residue as it does for the cat, I reckon.
When it’s time to empty it out, no more trips to the rest room with a 40 pound container to flush down the toilet (watch your aim my friend, don’t get any on your shoes!).
Instead you just get a green garbage bag, separate the two halves of the container and carefully empty the litter into the bag.
Then it’s just a quick rinse with the hose and voila! Ready for a new adventure with some fresh kitty litter.
I’d imagine you could dispose of the trash bag in the dumpster, no?
There’s gotta be sometime wrong with this plan, it’s too easy!!?
Response Posted - 04/30/2020 :  08:47:03  Show Profile
A kitty litter box is open to the air in a house where the litter can dry out. Evaporation of the liquids and moisture in #2 will be a problem in a closed potty environment. You are also talking about a much smaller air space in the boat and significantly larger quantities of liquid and solids than a cat produces. If you try it, be sure to let us know how it turns out.
DavidP
Response Posted - 04/30/2020 :  18:30:35  Show Profile
Hmmm, David - you’re right! I doubt anything would dry out in that situation.
Now it would be possible and perhaps desirable to use the container ports to supply some negative pressure ventilation.
There’s a pumpout port and a pour-out port on the tank.
I could find a piece of dryer hose and a 12VDC box fan and a bunch of duct tape to rig up a smell suction device to blow the moisture-filled air outside somehow.
I wonder whether replacing the tank air with cabin air would do the trick, or if I need some outside air as a source?
I have proven to myself that a 12VDC fan, a 30W solar panel plus a small 12VDC battery would keep the boat cabin dry.
Edited by - Voyager on 04/30/2020 18:33:39
