 keel hanger bolts
gerdo
Initially Posted - 04/11/2003 :  12:31:52  Show Profile
Somewhere in the back of my head is something about the need to do a "primer" of something on the keel hanger bolts prior to the locktite liquid. Anybody remember?
Buzz Maring
Response Posted - 04/11/2003 :  12:53:53  Show Profile
Hi Gerdo,
When I got replacement keel bolts from Catalina Direct, they included a small tube of goop (I can't remember what it's called) in addition to the locktite. I've heard two reasons for the goop, but I don't know which one is correct ... 1) you need the goop because locktite doesn't work on stainless steel, or 2) you need the goop because locktite doesn't work under water. Whatever the reason, you're right ... you need the goop.
'Sorry I can't remember what that stuff is called ... I suppose you could call Catalina Direct to find out (800-959-7245).
'Hope that helps ... good luck!
Buzz Maring
~~Freya~~
C-25 SK/SR #68
rclift
Response Posted - 04/11/2003 :  15:01:45  Show Profile
The primer they use is Loctite 7649, The threadlocker is Loctite 243.
Ray Clift
Buzz 1361
gerdo
Response Posted - 04/11/2003 :  15:40:47  Show Profile
THANKS
