 New floor
NCBrew
Initially Posted - 01/02/2021 :  08:54:50  Show Profile
I have a 1998 250 WK.
I would like to cover the floor with wood of some kind.
I see newer boats have a wooden floor.
Is there any laminate floors that will work?
1998 Catalina 250WK
Ravaging
Albemarle Sound,NC
I spent most of my money on boats and beer, the rest I just wasted.
Response Posted - 01/02/2021 :  09:24:44  Show Profile
I thought about that too, but decided against it. I started thinking about the "what ifs." What if the boat leaks water inside and ruins the floor's finish? Do I really want to have to sand it and refinish it? What if the adhesive softens in the summer heat and the floor starts to come loose? My C&C 35 has a teak sole, and it's nearing the time when it will need refinishing, and I'm not looking forward to it.
I decided long ago that the more functional approach is to use small throw rugs or runners. I like the looks of oriental or Persian rugs on a boat. They feel soft and warm under your feet and you can usually just shake them outside to clean them. Even without a rubber backing they don't seem to slide much when under way unless it's really vigorous, in which case I just toss them out of the way until I get back to the slip. I try not to spend too much on them, so I will feel free to dispose of them if they start to get musty or soiled.
Once you glue planking to your cabin sole, if you later decide it was a mistake, the cleanup of the adhesive would be very difficult. My suggestion is that you consider alternatives.
Response Posted - 01/02/2021 :  10:15:57  Show Profile
On "This Side Up" I would go to the local carpet remnant store and buy an appropriate colored piece (usually 4' x 12') for about $10, and cut it to fit. I never had a problem with it sliding underfoot. After a couple of years I would replace it and use the old one as a template for the new.
Chief Measurer C25-250 2008
San Antonio, Texas
Response Posted - 01/02/2021 :  12:03:13  Show Profile
I have a C25 that has a cabin sole with lower areas (near the galley and in the head) and has a curved surface by design, so in my case it would not be practical to try to glue down any rigid flooring. Is the cabin sole in a C250 flat and level?
When I originally acquired Passage it came with a nice runner-style rug, reminiscent of an oriental rug, that was trimmed to fit the cabin sole. While the rug is no more, I saved the pattern using some cardboard so I could replace it.
When I replace it I’ll look for a remnant or indoor-outdoor carpet. The rubber rug backing material will prevent slips.
Response Posted - 01/02/2021 :  12:08:36  Show Profile
Looking at flooring I see these interlocking panels that might be handy on a boat.
https://www.amazon.com/V488-Interlocking-Plantation-Hardwood-10-Pack/dp/B003BEERZQ/ref=asc_df_B003BEERZQ/
I wonder whether you could trim these to fit somehow?
Response Posted - 01/02/2021 :  12:43:21  Show Profile
One other thought - I recently bought two of the thick foam backed rugs that are primarily made to use in front of your kitchen sink. They're very soft and feel nice under your feet. I have one in my saloon and one where I step out of my bunk. Some of them have garish designs, but I bought two in a plain blue green color that looks good with my upholstery.
NCBrew
Response Posted - 01/02/2021 :  16:45:54  Show Profile
That is a terrific idea.
1998 Catalina 250WK
Ravaging
Albemarle Sound,NC
TCurran
Response Posted - 01/03/2021 :  05:18:05  Show Profile
Have you looked into the SeaDek type flooring? I found some on amazon and replaced the laminate in my Capri 25 with it. Non-skid, easy on barefoot, water proof, easy to cut and trim, and peal and stick to install. Seadek is just one brand, you can find the same type of flooring in many colors and designs.
Tom Curran
1981 Capri 25 Hull #101 "Dirty Debbie"
1988 Watkins 30
PAFB, FL
Edited by - TCurran on 01/03/2021 05:20:38
NCBrew
Response Posted - 01/03/2021 :  08:56:52  Show Profile
I have thought of SeaDek. I put it on my kayak. How did you measure it and install it. Any hints
1998 Catalina 250WK
Ravaging
Albemarle Sound,NC
TCurran
Response Posted - 01/04/2021 :  08:08:56  Show Profile
[/quote]
[/quote]
[/quote]
had the old laminate as a template and used a new razor to cut it. The peal and stick was pretty easy, you just have to take your time. I installed it over gelcoat, I just really cleaned the surface and then a good rubbing with alcohol. I was lucky and didn't need to bevel an edge.
Tom Curran
1988 Watkins 30
PAFB, FL
NCBrew
Response Posted - 01/04/2021 :  18:26:43  Show Profile
[/quote]
[/quote]
[/quote]
I bought some carpeting at Lowes.
Installed it and it looks good.
1998 Catalina 250WK
Ravaging
Albemarle Sound,NC
