 New Jib from Loong Sails
JanS48
Initially Posted - 02/07/2021 :  23:02:48  Show Profile
Greetings everyone
My STD rig C25 with CDI furling is in need of a major jib repair. The sun protection is frayed badly. A local sail-maker is quoting a price of $700+ to replace the sun protector. The jib material is in otherwise good condition. The size of the jib is a 125.
I got a quote from Loong sails (in the UK I believe) of $ 700. for an entirely new jib. Has anyone in the group done business with Loong sails?
Recommendations?
Jan
82 C25 SR FK
Sailing out of Newport Harbor.
Roamer
Response Posted - 02/08/2021 :  06:02:45  Show Profile
I purchased a new mainsail and genoa from Loong last spring. Went through the U.S. rep. The sails are well made, set nicely. Made from "warpdrive" by Challenge sailcloth. Would definitely buy from them again!
fadeaway: 1984 TR/FK Trad
Response Posted - 02/08/2021 :  14:02:22  Show Profile
Loong Sails- easy to find - Loong Sails (China) LTD is a Chinese company founded in 1991 according to my web search. Not sure when Loong sails USA was started. Odds are good that your new sail money is going to the communist Chinese, the folks that brought us COVID-19!! Use someone else, if your budget gives you a choice.
DavidP
Response Posted - 02/08/2021 :  17:54:26  Show Profile
If someone tried to charge me $700.00 to repair the sun protection on my sails and then offer to sell me a new sail for the same price I’d go elsewhere. Sounds like they are putting their interests ahead of yours.
You should be able to get that repair done for less than $700, especially if the rest of the sail is in good condition.
Agree with David on the China thing.
Association Member
Andiamo
'89 SR/WK #5862
Kemah,TX
Edited by - GaryB on 02/08/2021 17:56:43
Response Posted - 02/08/2021 :  20:02:44  Show Profile
Replacing sun protection on a sail is very expensive because Sunbrella is very expensive and because the old Sunbrella must be removed, which entails ripping out a gazillion stitches and which is labor intensive. I don't know what it costs currently, but the last time I priced it, I decided to buy a new sail instead.
Sunbrella is very durable, and, if the Sunbrella has deteriorated, you can be sure that all the other stitching holding the sail together is probably UV rotted, and the sail's remaining useful life is limited unless you have the whole sail re-stitched. You can have the sail re-stitched of course, but by the time you pay for the new sun protection and the re-stitching, the cost will approach the cost of a new sail.
Response Posted - 02/08/2021 :  21:51:47  Show Profile  Visit OLarryR's Homepage
In addition to the work involved to repair sails as Steve detailed, above, it is also the labor costs which are almost always higher for locally (USA) repaired/manufactured sails versus sails manufactured overseas in regions with inexpensive labor costs.
There is another consideration: What sailcloth your existing jib is made of and would be similarly utilized to repair it versus the sailcloth material of the new sail you are being quoted. For example, an above posting mentioned new sails in "warp drive" Challenge sailcloth. I did not look into it's details on the Challenge website but you could check to see the durability of the sailcloth versus one of Challenge's 4 Dacron sailcloths. I believe Warp-drive is a laminate but I have not reviewed it's performance versus reliability compared to the other sailcloths. I suspect that the laminate is lighter and possibly more stretch resistant versus the Dacrons materials. The Dacron sailcloths, especially, in the lowest grade sailcloth tends to stretch earlier in it's lifespan but Dacron sailcloths last a very, very long time. Laminates tend to be more resistant to stretch but do not last as long. Anyway, you may want to review the characteristics of the sailcloth of the new sail you are being quoted versus other sailcloth grades that jibs are generally manufactured out of and see if that has any bearing on your decision-making. Eons ago, I have posted info regarding Challenge sailcloth. Another good source of info regarding Challenge sailcloths is in the Mack Sailmaker website. I happen to come across it many years ago and it has beneficial info regarding sailcloth
Larry
Edited by - OLarryR on 02/08/2021 22:20:09
Response Posted - 02/10/2021 :  20:11:32  Show Profile
Well... I guess I’ve been enlightened. LOL
I never thought it would be so expensive for a repair but the comments sure make sense.
Association Member
Andiamo
'89 SR/WK #5862
Kemah,TX
Response Posted - 02/11/2021 :  07:04:04  Show Profile
About 6 years ago I asked the local Nielspryde office here in Stratford CT to replace my UV protection and repair the stitching. I also asked them to wash and make needed cosmetic repairs to both sails. I can’t recall the the exact cost but it must’ve been $8-900 all in.
They returned to me a beautiful genoa and a serviceable mainsail that were both clean. I’m still using them and the UV cover is still in perfect shape. I get them washed there just about every other year and they keep after any loose stitching for about $200. Just the cost of being a sailor.
Response Posted - 02/11/2021 :  09:57:07  Show Profile
I replaced the sun protector (not Sunbrella)on my Ullman 135 head sail last year for $462.00 at Quantum Sails in CT. As I live in an expensive area I would expect the same repair elsewhere would be @$100 less. BTW Ullman Ventura quoted about the same but I would have had shipping costs as well.
Peter Bigelow
Rowayton, Ct
Response Posted - 02/11/2021 :  09:59:51  Show Profile
BTW -- a new Rolly Tasker 135 from National Sail Supply in Florida is $782.00 -- for roughly the same money you could replace
Peter Bigelow
Rowayton, Ct
JanS48
Response Posted - 03/16/2021 :  21:27:19  Show Profile
Thanks for all the replies. I ended up letting my sail-maker re-fit a new sun protection. The price was $ 600. I most likely should have purchased a new one. If I get the 5 or 6 years out of this that the sail-maker claimed I would - I'll be happy with that.
Thanks again for all the input.
Jan
82 C25 SR FK
