 Tohatsu 6HP hard starting
FrankV
Initially Posted - 04/20/2021 :  06:21:22  Show Profile
We have a 6hp on out C250 WK. Plenty of motor for our lake sailing, but it is the hardest starting outboard in forever. However standard operating procedure is about at least 20 pulls. Kind of like a 4 stroke dirt bike I had, kick, kick, kick, nothing. Not even a pop, then on about the 50th kick. it would just light up & run fine.
I found the below starting procedure on another forum and tried it and it works like a charm-
Cold starting procedure is to attach fuel line, pump up until I'm reasonably sure the bowl is filled, give the throttle a couple of twists to wide open and back, then set it to the start position (1/3?) , full choke. Usually catches on and runs on the first or second pull. Cut back to half choke for about 15 seconds, then choke off and away we go.
Frank Vaughan
250 WK/SR
Response Posted - 04/20/2021 :  07:30:18  Show Profile
That's a pretty good procedure for starting any make of outboard motor. A lot of people don't pump the line before starting, but when you disconnect the fuel line, some of the gas in the line drains back into the tank, leaving air in the line. Pumping the line gets air out of the line and gets gas to the carburetor.
We often don't think to use the choke, because modern autos have automatic chokes, but any engine that has a manual choke needs you to use it for a cold start.
Outboard motors have a mark on the tiller that indicates how the throttle should be set to "start."
Maybe whenever someone complains that their outboard is hard to start, we should begin by asking if they're following the starting procedure recommended by the manufacturer.
A friend was complaining about his Honda outboard being hard to start. When I tried it, it started on the first pull. The only thing I did different from him was to follow the Honda starting instructions that were printed on the motor. He didn't pump the line, or use the choke, or set the throttle to start.
danandlu
Response Posted - 04/21/2021 :  07:07:51  Show Profile  Visit danandlu's Homepage
Frank,
I don't know if your 6hp is the same as my Tohatsu (9.8hp) but if it is you don't open the throttle any when starting, for cold start just pull the choke fully out (the throttle opens with the choke) and pull. Mine will usually fire on the first or second pull but not run. Then push the choke to the halfway position and pull. IF it's like mine it will start and run at fast idle.
Dan Henderson
1982 FK/TR #3328
"Chesapeake"
Missoula, Flathead Lake, Montana
Response Posted - 04/21/2021 :  12:53:22  Show Profile
Originally posted by Steve Milby
A friend was complaining about his Honda outboard being hard to start. When I tried it, it started on the first pull. The only thing I did different from him was to follow the Honda starting instructions that were printed on the motor...
As we used to say in the computer industry, RTFM!
NautiC25
Response Posted - 05/26/2021 :  12:16:19  Show Profile
I just bought a new (and beautifully white)6hp Tohatsu. However, based on my 8hp, and everyone else having issues no matter the model, I went with the integrated tank. I'm hoping that will cut out the fuel line, primer bulb, and nasty fuel tank from the equation. We shall see if that makes life easier. At least I know my fuel locker won't turn black every month. ;)
1989 C-25 TR/WK #5894
Miss Behavin'
Sittin' in LCYC on Canyon Lake, Texas
Response Posted - 05/27/2021 :  06:12:45  Show Profile
Congrats on the new motor! Using the integrated tank only gives you a little over one quart of gas. Are you going to be OK with that?
NautiC25
Response Posted - 06/07/2021 :  05:25:51  Show Profile
Yea, I only need enough motor to get out of the lake marina. About 300ft. haha
If I need more, I can always throw a can in the gas locker.
Miss Behavin'
NautiC25
Response Posted - 06/08/2021 :  04:39:16  Show Profile
I forgot to mention that it comes with the external fuel tank fitting. So if you need the extra fuel, you can quickly attach the external tank and hose.
Miss Behavin'
