 Replacing Rudder gudgeons
Initially Posted - 05/16/2022 :  19:25:58  Show Profile
This is a frequent inquiry on the forum. I just found a short, well done video showing how to do it on a C25.
https://youtu.be/ZypCsj3OeTM
Response Posted - 05/16/2022 :  21:09:07  Show Profile  Visit OLarryR's Homepage
Steve,
So far my rudder hardware appears okay. But nice video to ease tackling this potential job.
Larry
Response Posted - 05/17/2022 :  07:36:26  Show Profile
Great video -- they make it look so easy!
Peter Bigelow
C-25 TR/FK #2092 Limerick
Rowayton, Ct
Response Posted - 05/17/2022 :  10:17:57  Show Profile
What the video doesn't warn you of is that the new Gudgeons are shaped like barrels with nylon inserts. The old ones are just a hole punched through flat stainless. The new gudgeons and pintles need to be in perfect virtical alignment or the pintles will bind and not seat when you go to hang the rudder. Similar to having two door hinges on different angles. It happened to me.
Edited by - islander on 05/17/2022 10:19:27
Happy D
Response Posted - 10/29/2022 :  09:13:12  Show Profile
This is how I did mine. I replaced my original gudgeons with the new upgraded ones with the bushings. I removed the existing gudgeons without cutting any holes in the liner. I just reached up there and removed it.
Then I cut the lip off the old gudgeons and welded nuts to the old gudgeons and used them as backing plates for the new ones.
To install the top backing plate, I pushed two pieces of stranded wire through the two end holes in the transom. Inside the boat I put the two wires through the two end holes of the backing plate and tied a knot in the end of the wires. Outside the boat, I used the wires to pull the backing plate up against the inside of the transom and started a long stud in the center hole. The I replaced each wire with a long stud, one at a time. Then slathered the new gudgeon with sealant. Slid the new gudgeon over the studs. Then I replaced the studs with bolts, one bolt one at a time.
1977 SK/SR Dinette Hull #29
1979 ChrisCraft 251
1965 Chris Craft Cutalss
mheds5116
Response Posted - 11/02/2022 :  19:16:19  Show Profile
Great video if you have access to the lower gudgeon from inside the aft quarter berth. My 1982 doesn't have any access so I'm not sure how I fix the broken or missing left lower gudgeon bolt. It'll have to wait until Spring 2023. I think think bolt sheared off and I'm not sure how I get it out so it can be replaced.
Two Pisces
1982 C-25 SR/SK #2740
Lake Pepin
