 Wincher Self Tailers
Tray
Namibia
Initially Posted - 04/24/2003 :  21:11:30  Show Profile
Has anyone tried those rubber things that slip over your winches and convert them to self tailers? Seems like a cheap interim setup until I have enough units for replacement winches.
Tray
C-250WB #554
"Weeny Bean"
<img src="http://im1.shutterfly.com/procserv/47b3da37b3127cce963eb621ece90000001010" border=0>
Response Posted - 04/24/2003 :  21:25:32  Show Profile
I asked this very question last season when I considered spending a West Marine rebate on a pair, but since a consensus couldn't be reached on their effectiveness, I passed. If winchers garner a passing grade this time around I may try them.
Here's a link to the Wincher topic, which also contains Derek's boat sinking story. Isn't there some superstition about sailing with someone who survived a shipwreck? <img src=icon_smile_wink.gif border=0 align=middle>
http://www.catalina25-250.org/forum/topic.asp?TOPIC_ID=1725
North Star SR/FK
Mark Loyacano
Response Posted - 04/24/2003 :  23:00:20  Show Profile
I've used them for years. They work ok ... some times a little slipping and, well, they aren't $800. self tailing winches, either.
Very thin sheet lines will form too many coils and cause binding. I use 3/8th lines now. "Winchers" worked better with 1/2 inch.
We made canvas covers to protect them from UV damage when not in use.
Regards,
Mark L.
Cat 25 SR/SK #549
RichardG
Response Posted - 04/24/2003 :  23:23:28  Show Profile
Mine work well with 7/16" jib sheets -- 3 wraps below, 4th held tight in the groove.
I don't race. And while I rarely tack, if at all, on a typical weekend outing of 45+ miles (furling/unfurling the jib is a much more common exercize), I often adjust sail trim and for this I feel they are significantly more convenient than without them.
I think comparing winchers vs. no winchers ($30 differential) is much more meaningful than comparing winchers to self-tailers (roughly $770 differential).
<img src="http://im1.shutterfly.com/procserv/47b2d725b3127cce907c278fec7f0000001610" border=0>
Edited by - RichardG on 04/24/2003 23:58:35
Bill Holcomb
Response Posted - 04/25/2003 :  09:22:38  Show Profile
Hi Tray,
I've had 'em on Snickerdoodle for years. They don't do much as self tailers IMO. But, they do cleat off the line on the winch for light breeze conditions - instead of having to secure the sheet to the cleat near the winch.
MattL
Response Posted - 04/26/2003 :  00:37:41  Show Profile
Not meaning to change the subject, but I have to ask Richard a question. I see you have netting up, I do too, and it looks like the cushions on your cockpit lifelines have a skirt. If this is so how are they attached at the bottom.
IMHO I think the winchers aren't worth the effort. I have to work at it to tail and winch by myself, but can do it. It is easier to have a crew do the job. After reading the previous threads I don't think I'll make the purchace.
Matt/Brigitte Loeffler
E.C. Rider
Cat 25 86'
FK/SR _/)
RichardG
Response Posted - 04/26/2003 :  11:43:09  Show Profile
Matt:
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote> cushions on your cockpit lifelines have a skirt...how are they attached at the bottom.
I think they're called windcloths. Came with the boat -- three sections (2 sides and the back). They attach at the bottom with snaps and to the top lifeline/rail and sides/together with straps (they're designed to fit better without the lifeline cushion). There's a zipper for quick access to the engine.
We didn't use them until after we had kids, but we found they're nice regardless -- helps block cool winter/spring winds, spray, waves, plus creates more privacy in a crowded anchorage.
<img src="http://im1.shutterfly.com/procserv/47b2cf39b3127cce92448cf3849f0000001610" border=0>
<img src="http://im1.shutterfly.com/procserv/47b2cf07b3127cce926b784b6aae0000001610" border=0>
MattL
Response Posted - 04/27/2003 :  03:13:16  Show Profile
Thanks Richard,
Oh great photos too.<img src=icon_smile.gif border=0 align=middle>
E.C. Rider
Cat 25 86'
FK/SR _/)
Response Posted - 04/27/2003 :  09:58:32  Show Profile
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote>I think they're called windcloths.<hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote>
In the Navy, they were referred to as "windscreens".
North Star SR/FK
