I have a 1990 Catalina 25. I also am a victim of the Seaward/Princess alcohol stove and yes it leaks around the bottom of the burners. I know the typical answer is to convert it to propane, replace it with an Origo or bury it at sea.
Does anyone have an owners manual, parts list and most important where to get replacement parts?
Thank you Richard. I assume I'll need new parts. I had a Catalina dealer service manager look at it. He simply said it srays alcohol out from under a burner when you turn it up. Don't try and use it. I was hoping since it was a 1990 that I wouldn't have this problem. If anyone knows anything to try I would I would sure appreciate the imput.
My PR replaced the curtain burner with a microwave. Our dock this year does not have power. I'd like to replace the stove and have been looking for a unit that I can rebuild to put in Free Spirit. If anyone has one that I can have to attempt a rebuild please email me with your price. Thanks RL
Dock, I am often referred to as a purist and a die-hard. We use a charcoal grill on OJ, always have and always will. We also spent a lot of time and money trying to get our Princess alcohol stove running correctly. We shipped it back and forth to California three times before it performed at a <i>borderline</i> acceptable level. Then we had dinner on a Catlina 25 which had the propane conversion - the next day our alcohol stove components were at the curb. Haven't looked back once . . . good luck with whatever fuel you chose.
My alcool stove caused me lots of problems. So I experimented with it at home. I even got a second one frome Dave B. I eventually called a chemist and he told me to try a mixture of Methyl hydrate and Ethanol in a proportion of 60/40. I did that and the stove works very well. I used it for four months in the Exumas this last winter and it never gave up on me , I mean us (my wife did most of the cooking , even bread in the pressure cooker). To start it, I poor a small amount of alcool from a plastic bottle at the bottom of the burner, give about 10 pumps , lite the fluid and when it has almost all burned out, I turn on the burner and voila. Most important, I put the pot over the burner so that in DOES NOT burn my curtains. Now I am the proud owner of 2 alcool stoves.
The curtain burner runs much better if you fill the tank to no more than about 2/3 full -- this allows room in the tank for the alcohol vapor to be properly pressurized when you pump it up. Then, proper priming is the key to successful operation.
I do not now use my curtainburner, which is sitting in the garage. However, have used both alcohol and kerosene in the past extensively. Two tips: (1) I do believe it is easier to prime from a small bottle into the primer cup, than to do so by weeping it in with the knob. We found it much easier, and had a small plastic bottle that was originally supplied with Primus stoves in Europe, and was given to us by some kind sailor, (2) There used to br a felt-like circular clip, made--I believe--of asbestos, that one could saturate with alcohol and place in the priming cup. This held just the right amount to fully heat the vaporizer element. Using both or either of these, we never had flareups again iof proper pressure was pumped in. I must say that although we cooked successfully on the damned things for years, I would never go back, either Origo or propane or butane is my choice, good luck, ron srsk #2343 Orion SW FL
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote> If you can't wait five minutes for a stove to warm up, you should buy a stinkpot so you can turn the key and go! <img src=icon_smile_big.gif border=0 align=middle>
<font color=blue><font size=4> Woooe, now that's waaay over the line <img src=icon_smile_wink.gif border=0 align=middle> !</font id=blue></font id=size4>
If I cooked a lot, I'd probably convert to propane.
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote> My alcool stove caused me lots of problems. So I experimented with it at home. I even got a second one frome Dave B. ... Now I am the proud owner of 2 alcool stoves. <hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote> Glad it worked out for you, Jean... We're happy as clams with our Origo--click, it's on. Safe and reliable. No pumps, seals, leaks, flare-ups, explosive fuel, or storage problems.
Jim, I have the manual and will gladly send you a copy. Send your mailing address to me at wupdike@hotmail.com and I'll get one out to you. I have been using the stove successfully for 3 years, although, I take it home each year and clean it up. There is a cleaning wire for the orifices, I think it is .018" wire. I find it necessary to poke out the orifices about once a month while in use.
The last time I tried to get parts from our local Sewared dealer, I was told they are not available anymore. I don't know if that is true, but have not had any success.
The Origo pressureless 2-burner is an option, and those who have used it like it. For my money, I'd rather propane because it is hotter than alcohol. As for the ethanol, I'm no chemist, but my guess is that it is un-denatured alcohol. Stove fuel, like other alcohols sold over the counter are "de-natured," a rude process that renders it unsuitable for drinking purposes. Perhaps the additive is a source of combustion products that serve to clog the Princess more so than pure ethanol.
