 I need parts for 15hp Johnson circa 1990
albert
Initially Posted - 06/12/2003 :  01:04:50  Show Profile  Visit albert's Homepage
I've got a 15hp Johnson Long Shaft outboard. It came with my C25-I can't find a serial number, date, etc. I'm guessing that its around a 1990 outboard. It was originally installed with a remote throttle. I've removed it and would like to use it stand alone, but I need a twist throttle.
Any ideas where I could get replacement parts?
I'll post some pictures tomorrow.
Albert Iturrey
al@comhertz.com
Edited by - albert on 06/12/2003 01:11:15
svmoxie
Response Posted - 06/12/2003 :  07:36:08  Show Profile  Visit svmoxie's Homepage
Hi Albert,
Check your local yellow pages for a dealer that carries OMC or Evinrude or Johnson. They might be able to fix or replace what you need. Also a internet search for Johnson outboards might turn up some used part dealers. For instance try these guys:
http://www.outboardmotorparts.com/parts/johnson/
It sounds like this may be a difficult thing to locate so good luck.
On my Evinrude the model number / serial number is on a small tag that is mounted on the left side of the transom bracket, it isn't on the motor at all. If you don't have one there should be a number somewhere on the motor itself that can help identify it. Again, I would call the local dealer for advice because you are going to need to know exactly what year and model you have to find the correct throttle arm.
Clif Thompson
Treasurer C-25/250 National Association.
svMoxie '81 25 sk
Ed Montague
Response Posted - 06/12/2003 :  12:25:02  Show Profile
Albert, I was able to get parts for my 1978 Evinrude 15hp from Seaway Marine in Seattle. They specialize in older motors of all makes. Their phone number is 206-937-7373.
Ed Montague on 'Yahoo'
