 Head sink shut off valve
zebra50
Initially Posted - 06/24/2003 :  21:36:21  Show Profile
Short story is- after filling the fresh water takn with 12 gal. of water I found about 5 of it in the bilge. Traced the problem to the shut off valve below the sink-cracked from the valve to the lower water line inlet. Any ideas as to where to purchase another? West Marine here didnt have anything even close. I did email Dave at Catalina but have not heard from him as yet. Any help would be appreciated since we have to keep the water level below the water line at the sink until it is fixed. By the way, the blaster pump worked just great as an emergency bilge pump.
Jay
Papa's Boat II
250WB #370
frankr
Response Posted - 06/24/2003 :  21:53:52  Show Profile
Mine looks like a standard 1/2 inch cpvc shut off valve from any hardware store. Question why does the head sink have a shut off and the galley sink doesn't??
Edited by - frankr on 06/25/2003 07:47:55
Response Posted - 06/24/2003 :  22:57:42  Show Profile
Wondered that too.
Arlyn C-250 W/B #224
N/E Texas and Great Lakes
zebra50
Response Posted - 06/26/2003 :  14:39:00  Show Profile
That same question crossed my mind also. Why would there be a need to shut off the head sink and/or not the main galley. Does it have something to do with using both at the same time? I never tried that.
Jay
Papa's Boat II
250WB #370
Tray
Namibia
Response Posted - 06/29/2003 :  08:58:22  Show Profile
Aren't the shut off valves on the drain side? I know mine are/were. I'm not sure how that would have been the cause of your leak.
Tray
(Boatless in Florida)
zebra50
Response Posted - 06/29/2003 :  10:57:22  Show Profile
no, the shut off valve is on the water inlet hose as it enters the sink cabinet and runs up to the pump faucet. Probably split due to water in the line over the winter freezing. Found a lot of the water still in the area under the sink heading to the bilge.
Jay
Papa's Boat II
250WB #370
Response Posted - 06/29/2003 :  12:06:21  Show Profile
Wow... my memory is failing me... I recall now what the deal is. The valve was necessary when the fresh water tank was under the galley as during port heel the water tank would be above the lav spicket.
Ray Seitz
Response Posted - 07/01/2003 :  10:19:24  Show Profile
Neat tidbit of info Arlyn. I was also trying to figure out why the head sink had a shut off valve and not the galley sink. It did come in handy when I changed the leaking hand pump in the head sink.
<img src="http://im1.shutterfly.com/procserv/47b3d831b3127cce891ba4a976e00000001010" border=0>On the water
C250 WB Sea Major #628
zebra50
Response Posted - 07/02/2003 :  11:48:47  Show Profile
Arlyn, thanks for the insight. That actually makes sense, but with the fresh water tank now in the bow area midship, I guess it is not really needed. I will try to find a replacement and failing that I will just splice the two hoses.
Jay
Papa's Boat II
250WB #370
zebra50
Response Posted - 07/03/2003 :  13:23:20  Show Profile
FYI bought a replacement at a local plumbing supply $3.50. Never heard from Catalina or the part manf.
Jay
Papa's Boat II
250WB #370
Rubin Hawkins
Response Posted - 07/09/2003 :  10:24:32  Show Profile
I just installed a washdown pump. Instead of putting check valves before each outlet, I put in a shutoff valve before the galley sink. I shut off both valves before using the washdown pump. Something to think about.
Rubin
Windy Joy
C250 WB #591
Response Posted - 07/09/2003 :  11:36:27  Show Profile
Interesting point... my wash down pump would suck the rubber flapper of the sink faucet (katty wampus) but doesn't bother the lav. My pump is installed fairly close to the galley. I first installed a valve as you did... but use the blaster pump so much... that a check valve was added to avoid fooling with the valve.
Rubin Hawkins
Response Posted - 07/09/2003 :  14:24:22  Show Profile
I could not find any pvc check valves. I would install them if I could find them. The only Y valves I could find were mail order and a lot more expensive than I though reasonable. I don't have a seacock yet but when I do (winter project) I will likely make my own manifold from T's and shutoff valves.
Rubin
Windy Joy
C250 WB #591
Response Posted - 07/09/2003 :  17:35:26  Show Profile
I suspect that pvc check valves exist...but couldn't find one either so used brass.
The Y valve is available at most marine chandlers, actually its called a 3 way valve. They come with a restraint that allows either Y valve or removed, it allows 3 way operation. The three way was preffered in my settup because; it allows opening the seacock and setting the valve to a number three position which will drain the water tanks. Course this wouldn't be cool to do accidentally but works great for refreshing the tanks and draining for winter. That same position with the seacock closed, allows the marine head to draw fresh water while using the boat as a camper while traveling.
Bryan Beamer
Response Posted - 07/09/2003 :  17:58:45  Show Profile
Arlyn,
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote> using the boat as a camper while traveling.<hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote>
What do you do with the boom and the rudder?
I have thought about using the boat as a camper while traveling on occasions. I would have to do something different with the storage of the rudder and boom.
Bryan Beamer
<img src="http://im1.shutterfly.com/procserv/47b3da35b3127cce961d8ff3fd0b0000001010" border=0>
Daylight Again
C250wk #495
2003 National Champion
Response Posted - 07/09/2003 :  18:31:53  Show Profile
When traveling, the rudder goes in the bed of the truck. The boom can be carried in one of two ways... if the main is still on, it goes below with the goose neck up against the bulkhead in the V berth with aft end sittin on a pillow near the corner of the galley. Actually this leaves just enough room for two adults to sleep in the V berth though its slightly cramped. With the wing, your aft berth is much easier to get into so it could be used for sleeping. The other option which I would use for more than just one night on the road would be to remove the main from the boom and put it away. Then strap the boom to the mast. I have a mid mast support that goes into my mast step with two cradle points, one for the mast and one for the boom. The other end straps to the mast.
Remember, my mast sets on a carrier on the pulpit rather than on a riser off the bow roller. which allows it to be launched without raising the mast.
zebra50
Response Posted - 11/24/2003 :  16:19:01  Show Profile
For future reference to others that may develope this problem due to cold weather, I never did hear from Catalina. I took the valve to the local plumbing supply store and got a replacement for under $4. The bad on looked like this:
note the crack at the bottom that allowed the fresh water to leak in as I was filling.
