Hi all; i'm fixing window leaks...again..again...i would like to get some facts straight...i called catalina direct to buy the window glass seals..which are available. they said i should also use silicon on the new rubber gasket ???? because they leaked
Check the archives. This has come up a lot before, though not, I think recently. I used a sealant purchased at an auto parts store and laid down a thin bead betwwen the rubber gasket and the glass. I did have major leaks before. Now my windows ar
If you plan on using sealants, this site at SailNet looks to be very helpful in choosing the right one. I've got a 1989 C25 with new windows now but had a C22 with the aluminum frames before. I did use Marine Silicon once for a minor leak but have no id
hi Gerard: I had the same problem on Windwhisper 1980 sk. Fixed the problem three or four years ago and no repeats! I used a product from an auto parts store that is sold to fix windshield leaks, flowable silicon. It is a thin product that is applied b
There is an alternative that will take more time but one that give me more confidence in a "permanent" fix. Remove the windows from their openings. Disassemble them and discard the rubber seals. Completely clean the frames and glass. Fill the channels
