 Best item to buy to improve performance?
Bill Sloane
Initially Posted - 08/07/2003 :  14:57:24  Show Profile
Hit the start line last night for Wednesday night races, 'D' class in second position. I was happy with start as my last sailing race had been some 25 years previous. Watched every boat behind me pass me on the first windward leg like I was dragging a sea anchor. My boat is a standard rig swing keel C-25, 1978 vintage. In looking at all the other boats, really the biggest thing that stood out was the age of my main sail. I believe it is original. My thought is that if there is one thing I could buy that would improve my performance most dramatically, it would probably be a new main sail. Next, a new genoa. Any thoughts on this.
I noticed alot of fully battened mains too. Is it allowable to do this on the C-25?
Any thoughts or opinions appreciated.
Bill
'Suede Shoes' C-25 SR/SK No. 496
<img src="http://im1.shutterfly.com/procserv/47b3d837b3127cce89df6a2325840000001010" border=0>
Response Posted - 08/07/2003 :  16:42:14  Show Profile  Visit Champipple's Homepage
Yes, Fully Battened mainsails are allowable in the class. You might also want to look at adjustments that are allowable within your own PHRF rules and regs, but not the class. For example your weight and weight distribution.
Did you leave the table on board? What about the stove? Did you move your anchor off the bow and into the cabin? Was any other unnecessary weight taken off the boat? Did you leave the motor on the back of the boat? Depending on your local PHRF rules you may be able to move or remove many of these items. You can also, in many cases, bring your keel up when going downwind. (be careful here though, some areas make a more definitive distinction between centerboards and swing keels.)
A new main, lighter weight, newer cloth will definitely be beneficial. A few other things you might want to look at, depending on the wind you had:
Was your rig tuned for the weather at hand? Looser in light air, tighter in heavier?
Was your bottom clean, free from algae, seaweed and other muck ?
Did you measure yourself against another Catalina 25, or another similarly rated boat? If not, maybe they are supposed to be flying past you. Sometimes too, various makes and models perform better in different wind conditions. There is also the possibility that you were getting bad air off there sails. In this case, tack away as soon as possible to get a clean breeze. This happens a lot at the start, a boat directly to windward, or ahead and to leeward can “gas” you to the point of almost stalling.
DW
Response Posted - 08/07/2003 :  17:16:07  Show Profile
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote>Was your bottom clean, free from algae, seaweed and other muck ?<hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote>
I just went over to the lake today for the sole purpose of scrubbing the bottom, keel and rudder, in anticipation of the races this Saturday.
Duane's suggestions are all good, but that one is by far the most important. Nobody can win with a slow boat.
Dave B
Mali
Response Posted - 08/07/2003 :  18:18:11  Show Profile
Bill... I don't race our C-25, but I'll offer the suggestion that if you were trying to point with those guys with the crisp, full-battened mains, that may have been a big part of your problem. If the wind wasn't too heavy, your "full" sails could work for you if you don't try to point too high and go for speed at a slight cost in distance. (In the process, it stands to reason you might find cleaner air.) In heavier air, you're probably toast with those sails.
A clean bottom definitely is a prerequisite to competitive speed overall, but good sail shape is the prerequisite to being able to compete on the windward leg.
Response Posted - 08/07/2003 :  19:14:21  Show Profile
Best item to buy to improve performance...hmmmm?...I got it!
Skipper Russell Coutts...
<img src="http://i.cnn.net/cnn/2003/WORLD/sailing/03/27/ac.trophy.tour/story.coutts.trophy.ap.jpg" border=0>
Hey, it worked for Swiss billionaire Ernesto Bertarelli and the Alinghi team.
North Star SR/FK
bnpirate
Response Posted - 08/07/2003 :  19:22:13  Show Profile
Bill,
What size headsail were you flying?
when i bought my boat this year it came with only a 110 jib
all the other c25s were flying 150's and walking away from me.
I bought an old 150 from someone in the marina and am now competitive although I could use some new sails for better shape.
Brian
84 sk/sr
Bill Sloane
Response Posted - 08/07/2003 :  20:40:21  Show Profile
I was flying a 150 head sail in winds about 5 - 15 knots. Going to weather, we were over about 20 - 25 degrees. Just me and my son. Maybe could have used more weight. All my regular stuff was on the boat, i.e. stove, motor, water, beer, peanuts. Some of the other boats had mylar sails or sails with a bunch of black lines in them - looked real high tech. I was the only C-25 out there. But next week, Steve, a fellow South Sounder with a C-25 said he would race.
Definitely need to clean the bottom. Swantown Marina water is pretty darn scummy in August.
Bill.
Dave B
Mali
Response Posted - 08/07/2003 :  22:51:49  Show Profile
Bill: 5-15 is a big range, but even at 15 those heel angles also suggest sagging sails. Newer sails will be flatter in 10-15 knots and above, making more efficient airfoils with less "power" (heeling forces) and better pointing. For the main, do you have a vang? There are other flattening tools, but a vang is probably the most important one.
You don't need mylar to at least get into the game--you need decent shape, which you can get with dacron and full battens. IMHO, the sheeting angles to the rail-mounted track on a C-25 don't allow for that much advantage from a mylar genny, but I'm sure some will disagree. I just question the ROI.
Also for good pointing in a decent breeze, you want the forestay to be pretty tight--do you have a backstay adjuster? If you do, keep the rig loose and yank down down the adjuster when going upwind in a good breeze. (Release the adjuster downwind.) If not, keep your fore/backstay tensions fairly tight (so you can't wave the backstay more than a foot). It'll help with that heeling.
Gary B.
Response Posted - 08/08/2003 :  11:26:29  Show Profile
Bill: Clean bottom, yes! When I sold you the boat, I knew that her sails would be okay for cruising for awhile, but that they were WAY too tired for racing. Shoes needs a new main, and very likely a new headsail as well before you can be competitive on the race course.
I just put a new, single reefed main on Encore! this summer and my upwind performance has REALLY improved. I got a boat show special from Banks Sails in Portland. It's 6.5 oz. for $607. I recommend 'em, and the price is right, but more during high season. Winter is the time to have sails built.
I'd sell you my old main (w 2 reefs), but I think I will keep it for cruising, etc.....
Good luck,
Gary Bruner
Encore! #685 SK/SR
Bill Sloane
Response Posted - 08/08/2003 :  11:28:41  Show Profile
Dave: Good information. I don't have a back stay adjuster. Guess I'll just tighten her down. In my early days when I was racing one designs, our rig used to be tight as a drum. I do have a boom vang. One thing I have not figured out on the C-25 rig is the downhaul. I have one cleat mounted low on the mast in the sail track that I was using to cleat down my Cunningham rope. The cleat is too high for the boom downhaul. I was thinking about getting a second cleat and mounting it lower on the mast. In the one designs I used to sail, I would tighten the downhaul with pulleys until I curled the mast into a soft 'C'. Don't think that will happen on my C-25.
Fully battened Dacron sounds like the right way to go. What is the best source for those? Is there a used market for that kind of sail?
Bill
PS: ROI means?
Dave B
Mali
Response Posted - 08/08/2003 :  11:35:54  Show Profile
PS: ROI means?
O God, I'm so sorry--I regressed to a business acronym! I won't do it again--honest! Please forgive me! I beg of you! I'll be good! <img src=icon_smile_blackeye.gif border=0 align=middle>
Buzz Maring
Response Posted - 08/08/2003 :  12:05:15  Show Profile
<font color=blue>PS: ROI means? - Bill
</font id=blue>
"Return on Investment"
Buzz Maring
~~Freya~~
C-25 SK/SR #68
John Mason
Response Posted - 08/08/2003 :  13:56:21  Show Profile
Hi Bill,
Were you the lone Cat 25 out racing? If you haven't already, you should contact Steve Worcester - 352-9283. The race scorer. You need to register and get a handicap. They need to know your info to get you into the race results properly.
And don't worry about the other boats walking away from you. A lot of them are faster, but based on the handicaps, they owe you a lot of time.
John Mason
<img src="http://www.users.qwest.net/~jamason/ali.jpg" border=0>
pronounced "Ali Paroosa"
1982 - FK/SR #3290
Bill Sloane
Response Posted - 08/08/2003 :  14:58:20  Show Profile
Good to hear from you Gary. Your new sails sound like a bargain. By the way, after my little mishaps stepping the mast, I through bolted the mast step with SS bolts and large washers and blocked out the height difference on the ceiling of the cabin with some wood. Also built a wood mast support crutch to support it initially. Went very smooth. <img src=icon_smile.gif border=0 align=middle>
John: I think I was the only C-25 out there. It was my first race. I will register with South Sound Sailing Society and call up Steve. From Dave Bristle's discussion earlier in this thread, my main sail really is blown out. I doubt even Catalina expected the original mainsail to last 25 years. Catalina just didn't know how cheap C-25 owners could be . . . .
Bill
RichardG
Response Posted - 08/08/2003 :  14:58:38  Show Profile
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote> one thing I could buy that would improve my performance most dramatically<hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote>
I vote for new bottom paint, assuming the old paint is not keeping stuff from growing down there.
A mask, snorkle, fins and a brush might be less expensive in the short term, but certainly would take more effort (although think of the money you could save in health club membership fees! <img src=icon_smile_clown.gif border=0 align=middle>).
tinob
Response Posted - 08/08/2003 :  17:22:52  Show Profile
I agree... nothing's as quick as a slik bottom. All the other goodies would also contribute more to a bottom well groomed.
Val on Calista #3936
Val Bisagni]<img src="http://im1.shutterfly.com/procserv/47b3df11b3127cce94709c5ff2e90000000010" border=0>
