 Bits for cutting fiberglass
Initially Posted - 01/07/2002 :  13:56:58  Show Profile
Getting my ducks in order to convert to-hulls to thru-hulls. The thru-hulls I purchased are the flush-mounts which require you to cut a recess for the flange. Anyone ever find a grinding bit that stands up reasonably well to fiberglass? Or am I better
Response Posted - 01/07/2002 :  15:08:51  Show Profile  Visit Leon Sisson's Homepage
Steve,
I also installed the flush head thru-hulls. I started by using a hole saw to make the straight cut for the bronze thru-hull threads. Then to cut the "countersink", I used a 4" disk on a Makita right-angle grinder to rough in the taper. I then
JD van Wyhe
Response Posted - 01/07/2002 :  15:13:12  Show Profile
Steve,
When I did mine, I used a router with a 45 degree chamfer bit; one with a pilot bearing. Cut the glass like butter. To be on the safe side, I think I cut a shallow bevel to start, then progressively deeper with each pass. Leaves a very smooth a
